Hot Rods Tip for a smelly garage!
Discussion in 'The Hokey Ass Message Board' started by modified, Nov 19, 2012.
  1. Randy in Oklahoma
    Randy in Oklahoma
    from Oklahoma
    If you can smell gas there is potentially a lot bigger problem....explosion and fire.
    Listen to the women.
  2. Rickybop
    Rickybop
    She laughed pretty good when I told her what you said. :D
  3. What the Hell, is she doing in the Garage ?
  4. Checkerwagon
    Checkerwagon
    Wife ? That was your choice dude. Receipt of Complaints is your tax for said choice.
    I appreciate the tip. I'll try to tell my married friends.
    All the best,
    Dale
    Cleveland OH
  5. HotWare
    HotWare
    Hey Modified, How bout some details on that car in your Avatar?
  6. 1971BB427
    1971BB427
    from Oregon
    I've always stuck a cheap inline fuel filter on the end of my gas tank vent line and never had any fuel smell in the garage.
  7. saltflats
    saltflats
    from Missouri
    When my wife complains I tell her I can move her washer and dryer outside. She gets over it pretty quick.
  8. 296 V8
    296 V8
    from Nor~Cal
    Someone doesn’t own a carburetor :rolleyes:
  9. hotroddon
    hotroddon
    Another choice for a cheap carbon canister is one from a California Harley. You can usually find them at the swap meet for next to nothing, and some shops will give them to you!
  10. dirt t
    dirt t
    And when you regained consciousness and the swelling went down and you could open your eyes you realized your mistake.
  11. modified
    modified
    I have a coil of tubing in my vent line just above my tank, that doesn't seem to help. Someone on the H.A.M.B. suggested attaching a fuel filter w/1/4" fittings to the vent line so the tank could breath. That seems to help, but it's not the cure all.
    It was also suggested to run a vent line as high above the tank as I could and create a 180 then back down, kind of like a upside down J trap. I don't see how that would make any difference.
    Again, the fuel filter on the end of the vent line does seem to help!
    ANY OTHER IDEAS?????
  12. Mjrdude
    Mjrdude
    I have kept my old heap in the garage for years, the only time I smell gas is when I have a leak, or spilled some. Had a carb seeping once that smelled real bad, was tough to find cause it made no mess anywhere. I had to use a flashlight to find the glossy area. The gas evaporated almost as fast as it seeped out.
    Just a thought. :)
  13. 94hoghead
    94hoghead
    I've always liked the smell of gas in the garage........
  14. MeanGene427
    MeanGene427
    from Napa
    And what is your wife's car doing in the garage? :confused: She already has the kitchen- AND the laundry room. Put your foot down man....
  15. falcongeorge
    falcongeorge
    from BC
    My dad spends alot of time in my garage, and he can get pretty ripe. My wife has been complaining a lot. Do you think it would help if I fed him dryer sheets? Or maybe I should install a charcoal canister on his vent?
  16. modified
    modified
    OK! Here is what I have and have done today! Hope the hell it works! I used a puke tank and screened the lines inside and filled it with activated charcoal and attached it to a fuel filter and then on to the curley-q on top of the tank!
  17. GAOldsman
    GAOldsman
    from Perry, GA
    Charcoal canister
  18. 40FordGuy
    40FordGuy
    I like the cannister idea......I'm in agreement about the vapor pressure buildup....An extreme example was a customer's truck, the pressure forced enough fuel thru the carb to overfill to the crankcase; Fortunately, he noticed a puddle under it, and did not try to start it, had it towed in.
    4TTRUK
  19. Lone Star Mopar
    Lone Star Mopar
    Tell her to put a mask on while she's in the garage. Seems a whole lot easier and cheaper.
  20. Hairy Olds
    Hairy Olds
  21. HOTRODPRIMER
    HOTRODPRIMER
    A fart fan works pretty good!:D HRP
  22. Roger Walling
    Roger Walling
    Every time you return from a car meet, Spray the p***enger seat with a different cheap purfume.
    Trust me, she won't complain about the gas fumes.
  23. Weird. I thought that was part of having an old car in your garage.
  24. Blue One
    Blue One
    from Alberta
    Adriatic Machine likes this.
  25. CW's40TPU
    CW's40TPU
    Gas smell in the garage: years ago one of my neighbors had a gas smell in his garage, it was coming from a OT car (VW) the neighbor didn't think to much about it, he also had a garden tool charging in a wall socket, 12 hours of not opening the garage door to let the fumes out caused the garage blow up, he lost everything in that garage fire, fire dept told him the charger has a spark inside the charger and that's what ignited the fumes.
  26. fastcar1953
    fastcar1953
    just asking, why is the battery turned on it's side?
  27. modified
    modified
    Best fit, could be mounted anyway but up-side-down.
  28. fastcar1953
    fastcar1953
    i thought they had to be upright for acid to cover the plates. learn something new.
  29. modified
    modified
    OK! This was this mornings project. Still smelled gas, off came the canister.
    I came off the curley-q with 3 loops as high as and behind the tank.
    Then I dropped through the floor and attached a fuel filter with 1/4"
    fittings then from the filter a 3' line terminating in the frame rail.
    This afternoon it was 84 degrees---2 days, No smell!
    Blue One likes this.
