Really cool engine bay accessories...
Discussion in 'The Hokey Ass Message Board' started by 3wLarry, Feb 15, 2010.
  1. mart3406
    mart3406
    from Canada
    I don't have a picture of it, but several
    years ago I made a - (I think) rather
    cool radiator overflow bottle for a
    friend's NHRA-legal stock cl*** race car,
    using an old aluminium army canteen
    that we found for free in in a s****
    aluminum pile. For a mounting bracket,
    to bolt the canteen to the upper rad
    support, I mounted the canteen upside
    down, so the original chain-connected
    cap faced down and then tig-welded a
    piece of s**** 3/16 inch thick aluminum
    plate to the (now) top side of the canteen
    . For a hose fitting, I drilled the flat bottom
    ( now, top) of the canteen and tig-welded
    in a 90-dreee -3 aluminum AN hose fitting.
    Then I drilled out the overflow opening in
    the radiator neck and tig welded in a
    straight - 3 AN hose fitting and connected
    the two with a short length of braided line.
    It looked slick, it weighed virtually nothing
    and it cost even less! :)
    Mart3406
  2. cully33
    cully33
    I made my bracket out of a section of torque tube I had let over after shorting a 48 unit to fit the 32, the overflow tank gets more comments than any over thing on the car.
  3. propwash
    propwash
    from Las Vegas
    I was hoping to see at least one of those old military finned coils. All over the place back in the 50s and 60s but I haven't seen one in forever. I think they were GMC
  4. tommy
    tommy
    Even a 6V coil can be used as a holder for a modern coil. Cut the upper band that holds it and warm it up with a torch until the tar melts and the 6V guts falls into a bucket. (It's messy) Bead blast it and epoxy your new coil in place. The Ampco coil is an electronic coil used on a Chrysler ign.
  5. mart3406
    mart3406
    from Canada
    You mean those big finned Delco coils,
    like this one?? They weren't just GMC
    or "military". Besides some heavy-duty
    GM trucks and various military apps,
    they were also used as OEM equipment
    on numerous other makes models and
    brands of medium and heavy-duty
    trucks and on numerous makes of
    industrial and heavy-duty marine
    engines - from sometime in the late
    1930's and early-'40's, right up through
    into at least the early 1960's. 'Back in
    the day', circa early and mid-'70's, I used
    to regularly scrounge a local "'big-truck"
    boneyard for them and I used them on
    several rods and hot 'street-strip' cars.
    Besides looking cool, they could throw
    one hell of a spark, yet they didn't draw
    so much current as to be excessively
    hard on the points. They still show up
    on epay and at swapmeets from time
    to time and they're a good deal all
    around if you can find one. :)
    Mart3406
      486.9 KB
      478.9 KB
      443.8 KB
      406.6 KB
      40 KB
  6. Mart3406,
    I have one, but don't know if the coil is still good (just need to test it). If it IS bad, is it possible to remove the coil from the fins and replace with a newer one?
  7. NickJT
    NickJT
    from S.E. PA
    HAMB experts:
    I don't know if this piece that I recently purchased is a bogus hunk or if it fits in this thread as a cool old vintage fuel block. I like it anyway since it reminds me of Meyers history, but I'd appreciate your experienced comments on this fuel block:
  8. mart3406
    mart3406
    from Canada
    I've read about some guys here
    doing that, but if the coil works, I'd try
    running it "as is". You'd be surprised at
    how much spark they can throw out. If
    the coil checks out, you might what to
    experiment with opening up the plug
    gap a bit to take advantage of the coil's
    output potential. I used to run the plug
    gap opened up to .040 with one of these
    coils on a built 283 and and it would pull
    hard right through 7000 rpm,. With the
    stock Chevy coil I could only run about
    a .028 or .030 plug or it would start to lose
    power above 6000 rpm.
    Mart3406
  9. tommy
    tommy
    I've never done this brand but the ones I have gutted were very easy. Cut the shiny band around the top and remove it, hold the coil in a vise upside down over a trash can and warm it up with a torch until the guts fall out into the trash can.
  10. BLUMEANIE
    BLUMEANIE
    from St. Louis
  11. tommy
    tommy
    It is not a period piece if that matters to you. It was made in the last 20 years.
  12. NickJT
    NickJT
    from S.E. PA
    Thanks for that info, tommy. I like it anyway but now I know where it stands.
  13. propwash
    propwash
    from Las Vegas
    mart3406 - yep - that's it. Like you, we would scrounge around for those things - not only serious spark, but just cool looking as heck, especially if your car had other finned stuff - beehive, cylinder heads (or valve covers), regulator covers, etc.
    thanks for posting that picture
  14. 3rd Gen Hot Rodder
    3rd Gen Hot Rodder
    from Indiana
    Marvel Mystery Oiler for the Judson Supercharger on our family's flathead powered with Ardun conversation 48 Mercury. Also, the use of the H-D air cleaner for clearance makes for a different look....
  15. Normbc9
    Normbc9
    Here are some more that had a lot of thought too. Not to mention expense.
    Normbc9
  16. RussTee
    RussTee
    Were Veda Equipped hub caps traditional old style or someones modern idea?
  17. I have an old Stewart Warner fuel pump I will use for my A Banger. My Dad had it on his old 1946 Packard with a 1948 straight 8 race car (1956). I put new electrical wires on it and it works fine.
    Mike
  18. RussTee
    RussTee
    that air filter fits right in on that motor
  19. Slick Steve
    Slick Steve
    from Indy
    Here are a few things that are all going on my '39 Ford as we speak
    Malp***i Filter King
    Original Marvel Mystery Oiler
    Sun Tach & Sender and Grant/Saplding Flamethrower
    Polished Fenton Intake, Velocity Stacks on 94's
    Engine on the test stand
    Who knows what else we can dig up before we are done!
  20. Kona Cruisers
    Kona Cruisers
    Bumping an oldie...
  21. Kinky6
    Kinky6
    Thanks, I'd missed this one earlier. :cool:
  22. k1w1rodder
    k1w1rodder
    found this the other day, dunno what its off but looks cool
  23. n847
    n847
    That marvel mystery oil bottle might be the coolest damn thing I've ever seen!
    Thanks for bringing this to the top!
  24. I always liked this one:
    We had a Bijur oiler in our '30 Packard- pull the handle once a week while driving and most of the major ch***is joints got a shot of heavy oil :D
  25. carrera600
    carrera600
    Alchemy,
    very nice engine, dual WEIAND INTAKE, and the Klaxon Horn are a bonus. I love those vintage Hellings bell style air cleaners, i have been looking to find a pair for myself, for quite some time. WOLK design have good reproductions but im looking for original vintage ones !
    Q: Your thump screw hose clamps, what size are they (i`ve got sharp cylinder heads, should be the same size) ?
    Regards Randolf
