Turn Signal Help ~ Arrow 286 in a '53 Ford PU
Discussion in 'The Hokey Ass Message Board' started by wolfex1, Nov 21, 2012.
  1. wolfex1
    wolfex1
    I am helping a friend get a '53 Ford PU back on the road after 14 years of garage life. I have encountered a problem, in that the front turn signals come on when I hit the brakes. He had paid someone previously to rewire the lights. No doubt, the turn signal switch has the front and rear lights wired together. I would love to have a schematic for the arrow 286 turn signal switch, so I can sort this problem out. Anybody on the HAMB have such an monster?
  2. Ole don
    Ole don
    A 53 Ford pickup had a factory turn signal switch in the column. Replace it with factory parts and the wiring will be correct.
  3. dirt t
    dirt t
    This should help.
  4. wolfex1
    wolfex1
    Thanks! Is this generic, or is this specifically for the Arrow 286? I see the '56 at the bottom of the schematic. ~WX1
  5. wolfex1
    wolfex1
    Sure, but this thing has been rewired from one end to the other, by someone else , with no record of what they did. The system in the truck seems to be working somewhat. If I can get the color codes for the Arrow 286, I can sort it out.
  6. curbspeed
    curbspeed
    Do yourself a favor and buy a new rewire kit and start over. Then you will know what the hell you got and not just a bunch of hodge podge. Fixing someone else's mess is a pain.
  7. wolfex1
    wolfex1
    I am not the type of person to just throw money at a problem. The wiring for all the lights is new, and I have the skills, but a schematic of the Arrow 286 with color codes will be helpful. I have, however, started from scratch on two occasions when repairs were not feasible. Speedway has a kit with 20 circuits for cheap and all wires are marked. Thanks! ~WX1
  8. dirt t
    dirt t
    thats a 53 to 56 ford wire diagram.
  9. wolfex1
    wolfex1
    Thanks! I'm on it. ~WX1
