56 truck
Discussion in 'The Hokey Ass Message Board' started by myforty40, Nov 24, 2012.
  1. myforty40
    myforty40
    from Hebron, in
    I've got a situation that is continuously causing some headaches so maybe someone can ***ist. I've got a 56 truck, with a Camaro front clip, (front steer). I've been told that's a 70 to 76 front end. Numbers on the upper control arms are: (driver) 78HL and the (p***enger) is G22J8R. Rotors I have to use come from a 79 to 81 Camaro (due to the bearings that came out of the old rotors. Can anyone tell me the year or years of the front end for sure or can these rotors be used on the 70 to 76 front end that I presumably have?
    thanks
  2. chaddilac
    chaddilac
    Post a pic!
    On the 58 I'm working on for my buddy we just googled camaro frontends until we found the correct one that matched ours. It turned out to be a 81-2 I believe and we just bought rotors and calipers from Advance auto pretty cheap.
  3. SHughes
    SHughes
    I always thought the rotors/bearings were the same from 70-81, all front end parts actually. I'd check my Haynes manual (better than nothing LOL ) if I was at home.
  4. myforty40
    myforty40
    from Hebron, in
    thanks for the help, I didn't know what to be looking for. appreciate your help.
  5. myforty40
    myforty40
    from Hebron, in
    That's appreciated. Can that be found on the internet??
  6. myforty40
    myforty40
    from Hebron, in
    I thought the same but maybe I'm wrong about the year of the front end to begin with. What year then is the front steer for Camaros?? Maybe 70 to 76 isn't correct.
  7. myforty40
    myforty40
    from Hebron, in
    If you can check your Haynes Manual, let me know OK
  8. 1970 -'81 are the same front steer suspension. My 45th edition of Hollanders says 1 rotor (a)for '70-'78, another (b) for '79-'82, but b also fits a.
    Charlie
  9. SHughes
    SHughes
    I'm half way around the world from my books, but now that you mention it Charlie...I want to say the 79-81 rotors are thicker/wider due to the car being heavier. And therefore the thinner rotors would "fit" but not meat specs if interchanged.
  10. That could be...the note in Hollander's didn't give any instructions.
  11. APACHE FS
    APACHE FS
    The spindles are all the same, the rotors use different bearings (OD is different) get everything from the same year whatever you choose. If you have a bearing you can check the number and figure out what year it is and get corresponding rotors.
  12. myforty40
    myforty40
    from Hebron, in
    Hey thanks, that helps a lot. so the front end steer is the same for 70 to 81 but the rotors can be different in thickness due to the weight. I found out the bearings only fit a few years so I went to that as my determination for new rotors. They fit perfect. So brake hoses should be from 79 to 81, or is there a difference
  13. myforty40
    myforty40
    from Hebron, in
    that's how I found out what rotors I needed. thanks
  14. myforty40
    myforty40
    from Hebron, in
    question? if I were to want to go to 2" dropped spindles, should I ask for 79 to 81 or 70 to 79??
  15. 32fenderless
    32fenderless
    I just went through this with my stubbed 49 chevy. The spindle(knuckle) are the same from 70-79. The 79-81 are the same. The difference being the outer wheel bearing. I pulled my bearing then compared measurements listed on that auction site to determine which year range I had.
  16. APACHE FS
    APACHE FS
    ^^exactly^^ so order the spindle that corresponds with the bearings you have. I wasn't aware the spindles were different at all. I know 67-69 were but thought 70-81 were the same.
  17. myforty40
    myforty40
    from Hebron, in
    hey thanks, the outer wheel bearing was the problem. thanks for the good word.
  18. myforty40
    myforty40
    from Hebron, in
    thanks for the help. I could use all I can get.
