Glass Thickness-- Fact or BS?
Discussion in 'The Hokey Ass Message Board' started by Dan Hay, Nov 25, 2012.
  1. Dan Hay
    Dan Hay
    I had a new door gl*** cut for my 38 chevy by a mobile gl*** guy, when I put it back in the regulator, it's all bound up in the channel and the power window will not roll it up.
    Upon further inspection, the new gl*** is 1/4" thickness and the old gl*** is 3/16" thickness. The gl*** guy says they don't make 3/16' gl*** anymore and I need to get new window channel to fit the thicker gl***... :confused:
    Is this true? Or is there still 3/16'" door gl*** available for a 38 chevy coupe?
  2. 53 COE
    53 COE
    from PNW
  3. EnragedHawk
    EnragedHawk
    from Waco, TX
    I couldn't tell you if it's true or not, but it seems like the gl*** guy should kinda take the hit for selling you gl*** that doesn't fit your application.
  4. Dan Hay
    Dan Hay
    I agree, or at least let me know the difference when he was cutting the gl***. The guy seems kinda full of shyte, so that's why I came here to ask.
  5. manyolcars
    manyolcars
  6. Dan Hay
    Dan Hay
    That's what I thought! But apparently, it's enough for a bind. Also, seems like he cut it slightly too big, it has no front to back wiggle room. Maybe he'll trim it for me.
  7. slddnmatt
    slddnmatt
    He is full of ****. You can get it either way...he just doesn't want to fix it.
  8. HOTRODPRIMER
    HOTRODPRIMER
    I have encountered the same problem and all I hear is that they don't offer or stock the 3/16" gl*** anymore.
    I had all kinds of problems. HRP
  9. tooljunkie
    tooljunkie
    from manitoba
    laminated gl***? i saw a guy belt sanding the edge of a window for clearance.
    tempered? if not,why not? you cant sand tempered gl***,its too risky for shattering.
    most side gl*** is tempered,single layer.
    i had some gl*** done for a boat application last summer,18" square,3/16.including tempering was 45.00.it also needs a stamp showing its safety gl***.
    saying they dont make it anymore is B.S.
    he just doesent stock it.
    gl*** is a huge markup,i guess due to waste and breakage,when i was cutting gl*** it was usually tripled from cost.
    i want to replace all the gl*** in the studie,i may buy a sheet and cut it myself,then send it away for tempering.
    biggest thing is building a bench big enough to set the sheet on.
  10. Dan Hay
    Dan Hay
    Just talked to Bob's Cl***ic Auto Gl***.... Helluva nice guy.. He says they do make original thickness gl*** and it's usually used for heavy equipment.. He said to call a local gl*** company and ask who does heavy equipment.. then call that person and they will probably cut a pattern. He said heavy equipment used the thinner laminate gl***.
    Great info, Next time I'll call them first! As far as my gl*** goes, I'm going to have the guy trim it a little, I think most of my binding issue is because it's to tight.. hopefully a trim will work and I can call it good.
  11. wheels777
    wheels777
    from York, PA
    I had new thin gl*** cut last year. I think it is referred to as A2.
  12. hotrodgypsy
    hotrodgypsy
    from reading,pa
    id talk to chris blattie on this site..got gl*** from him for my 48 chevy sedan delivery...my original gl*** was a bit thicker..no problem with the istallation tho...
  13. MRTS33
    MRTS33
    Why did the numskull put the 1/4" gl*** in knowing that it needed 3/16" gl***. Should have waited for you a change the channel. Rather than break something else.
  14. haychrishay
    haychrishay
    Been down that road on a car.....you are going to have to bite the bullitt and buy the thinner gl***
  15. bobkatrods
    bobkatrods
    from aledo tx
    I buy gl*** all the time in Dallas that is 3/16 tempered clear,, It is not laminate, single glaze tempered.He is wrong.
  16. R&C RON
    R&C RON
    I,ve been in the gl*** business for 40 years, I can get 3/16" & 1/4 "lami. or tempered, from any wholesaler.However I think your binding is more of a size problem than a difference of 1/16" in thickness.
  17. This guy knows his gl***. He's cut two of my cars gl*** and will be doing a third one soon. He has custom makes them tempered or laminated and has over a 100o factory templates. He also polishes all edges!!!
  18. BarryA
    BarryA
    Where I am the thinner laminated gl*** (4.3mm) is special order and hard to find. 6.3mm is the standard. It is regular plate gl*** with a membrane between - hence the additional 0.3mm.
    My question is shouldn't you be going for toughened. Pretty much standard gl*** which is cut to size - 3,4,5,6 & 8mm plate gl*** is all available - then effectively heat treated to render it suitable for side gl***.
    I just had some done for the truck in my avatar (5mm) and it cost about 30% more than regular laminated cut at the corner jobber gl*** store. I provided a template in thin MDF. Took about a week.
    (apologies for all the metric, but I'm sure you'll figure it out)
  19. Unkl Ian
    Unkl Ian
    I call ******** on the gl*** guy.
  20. Moonequipt13
    Moonequipt13
    25.4 mm per inch
