who running a Blower with 6 or 8 ford carbs W671 ?
Discussion in 'The Hokey Ass Message Board' started by 60 Belair, Nov 22, 2012.
  1. Tudor
    Tudor
    from GA
    Damn - Ya'll are getting right along with the second COUPE!
  2. E.C.
    E.C.
    from Tx
    Here is a picture of my Weiand W-671-8 that I was running at one time and will use again in the near future.:)
  3. thats the one the howard timing cover is way cool to.
  4. 60 Belair
    60 Belair
    That sure is ***y!
    Now This thread is gettin intresting.
    Thats the first good pic Ive seen of a 8
    thanks for the pic E.C.
    you got a nice collection of speed jewelry I see from your pics Cool!​
  5. QQMOON
    QQMOON
  6. QQMOON
    QQMOON
  7. SIX_94Y
    SIX_94Y
    from Australia
    Running 4 old grubby/corroded/rusty/damaged 94's on my y block not one matched pair! I run my largest jets in the front as a gm blower screws to the rear. Spent a bit of time cleaning and shaping throttle plates to get good seal but idles and runs with no dramas......now! The rear 2 are off and I'm sorting them out to run all 6. I cannot imagine it would be too much problem having mismatched and different carbs as it all gets smashed around by the blower and then thrown into what normally is a rather poor distribution manifold. The carbs do not flow that great as witnessed by how the intake ices up on my car after a hard run. Lots of air speed will do that. A good large single 4 barrel would be better than most 6 carb setups but I still have less money in my carbs than a dominator or the like would have been, plus it looks better!
  8. SIX_94Y
    SIX_94Y
    from Australia
    Yeah, they'll probably leak too!
  9. 60 Belair
    60 Belair
    hey SIX_94Y Thats cool whose adapter is that ( manufacturer)
  10. 60 Belair
    60 Belair
    these are pics of racer-x blown plymouth coupe
    looks Sweet
    I love what you did with the rear fenders
    later Andy ​
  11. SIX_94Y
    SIX_94Y
    from Australia
    All made by me.
  12. hey 60 bel air just saw the pics thats not my car. my car is on that forum but at post 47 the orange coupe. sorry for the confusion.
  13. cracker head
    cracker head
    FED ???:D
    Do you know how to tune one of these things??????? :rolleyes::D
  14. 60 Belair
    60 Belair
    OK sorry for the confusion these are pics of racer-x plymouth coupe​
  15. the best way to tune these things that i have found is a air fuel gauge. with todays fuels its hard to read plugs. with a blower if you run too lean detonation can occur on a big time basis. in severe cases plugs can close up piston tops removed roller lifter bearings smashed burned combustion chambers just to name a few. i have done all these things until i got a a/f gauge. now its all very easy. runs and drives great and i can put my foot into it with no worries. it really is the hot set up. pays for itself in fuel savings and no broken parts. the learning curve can be expensive.
  16. thanks for posting the new pics. the car is a 1931 chrysler cm-6 coupe. the pics are a few years old. i now run the 12 inch wide 32 inch tall radirs. the engine runs methanol inj. now. the wheelie bars are only for racing not street use.
  17. dashman
    dashman
    from Viroqua WI
    Here is an adapter for a 6-71 blower that we just finished up to customer specs, the only difference is that both customers opted for 4" tall Edmund's risers.
    I would have put all 8 carburetors on but the throttle shafts are too long. The holes in the top plate are for heim joints that will be coming in shortly, and a linkage kit will be available if needed. The way this is designed is that 8 Holley 94's or 8 Stromberg 97's can be used. Even a whole different carb layout could be done, it's possible for 8 small Rochester 2g carbs to be used.
    If you are interested in an 8x2 or 6x2 setup just send me a pm.
    Dashman's Hot Rod & Speed Parts www.dashman.net
  18. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    My box of 8x2 Goodness arrived today, Early DragStar and the Weiand 6-71 intake..........Littleman
  19. Congrats on the rare find
  20. blue57ford
    blue57ford
    Awesome! For what may either of these be going on?
  21. 60 Belair
    60 Belair
    BTT come on I know there more of you guys out there
  22. cracker head
    cracker head
    There are. We just are possibly shy and just want to have secrets???????
  23. Nailhead Jeff
    Nailhead Jeff
    from fresno
    Savage speed repops the W671 6x2 blower top
  24. 60 Belair
    60 Belair
    I have emailed savage speed no response, called savage speed phone disconnected, Good Luck .
  25. SAVAGE
    SAVAGE
    Alliance Vendor
  26. flatheadpete
    flatheadpete
    from Burton, MI
    Any pics of the bases of these, Dave? Even from the bottom of one. Just curious.
  27. SAVAGE
    SAVAGE
    Alliance Vendor
    my phone number and email have not ever changed. You can PM me also.
    Thanks
  28. hemi rodder
    hemi rodder
    from NB Canada
    not on a blower but 8x2 dragstar
    Jet96 likes this.
  29. dyersblowers
    dyersblowers
    from Summit, IL
    Just had a guy trade in a bunch of vintage weiand stuff including one of the 8 carb adapters. He also traded in a front one piece weiand drive with 2 x 2" pulleys and a mint / new finned rear bearing plate cover. Even has the flat head level plug screw. Only thing missing is the belt, crank accessory pulley and idler arm. Give me a call if interested. Will clean it all up (sitting in garage for 20+ years) and post pics.
  30. jailbird
    jailbird
    We removed a 6 de'lorto set up from a 6-71 went to 2 4 barrels they look similar to webers
