30 ford coupe body cart
Discussion in 'The Hokey Ass Message Board' started by fxstc127ci, Nov 27, 2012.
  1. fxstc127ci
    fxstc127ci
    I'm getting ready to take my body off the frame. I would like to have a cart made and ready when this happens. Does anyone have any dimensions and pictures of there's that I could work from.
  2. dirt t
    dirt t
    Wescott has the dimensions of the frame. Use the dimensions to build a 2X4 frame for the body add wheels.
  3. Flop
    Flop
    4x8 sheet of plywood and some 2x4s . run you about 60 bux if you have to buy all the wood and casters .
  4. Don's Hot Rods
    Don's Hot Rods
    from florida
    If you want the cart to be wide enough to support the entire body, here is a picture of our tudor body on my 4 x 6 foot utility trailer. You can see from this how it fits that dimension:
    But I made two body carts for our shop out of 2 x 4 , 4 x 4, and 2 x 6 lumber plus a couple of caster wheels and I think a coupe body would go on it too. So far I have used it for my 27 roadster body and a 30 Model A rpu body and those fit fine. It is 2 feet wide and 4 feet long.
    I think for a coupe body I would make it a little wider and longer though, at least longer.
    Don
  5. 32 hudson
    32 hudson
    Thanks for the ideas. I need to build one for my 32 Es*** coupe.
  6. fxstc127ci
    fxstc127ci
    Thank's, just need to dive into this project now! Keep you guy's posted with build thread!
  7. chopt top kid
    chopt top kid
    I just made a simple four foot by eight foot cart out of some 2X4's and a sheet of 1/2" osb. I ended up putting some leveling jacks and frame fixtures on it and using it as a half-***ed frame table...
  8. dirty old man
    dirty old man
    Can't take pix of my body cart because a friend has it borrowed for a project. But even if I had it @ my shop, I wouldn't be able to take pix because I built it (2X4s & 4X4s like others depicted here. Only I bolted it together so I can dissasemble and store in shop attic when not needed. Saves a lot of space when not in use.
  9. Crankhole
    Crankhole
    I built a perimeter frame out of wood 2x3s with some casters on the corners. Dirt cheap.
  10. junk yard kid
    junk yard kid
    I built mine out of a bunch of steal that i had. I just had three cross pieces to support the body some legs and wheels. But my body was pretty sturdy. I made mine really high Like 3-4 feet high so it was easy to do all the rust repair that was down low. The roof was kinda high though.
  11. loudpedal
    loudpedal
    from SLC Utah
    I built mine from a pitted (junk) Model A frame. Whacked off the front about an inch or two in front of the cowl and welded legs to it. The legs are connected at the bottom with braces and then I added wheels. It's dimensionally accurate to jig up a body as well. Which comes in handy when you do as many Model A's as I do.
  12. Yea and as cheap as they are you can't beat that.
