Best Mufflers for a 302
Discussion in 'The Hokey Ass Message Board' started by rustyfords, Nov 27, 2012.
  1. rustyfords
    rustyfords
    from Conroe, TX
    I'll be installing exhaust soon on the 302 in my 54 Ford tudor and DON'T want it to sound like a 5.0 Mustang.
    Instead, I'd like something more mellow sounding.
    I'm thinking maybe Flowmasters with a crossover pipe.
    Any suggestions?
  2. landseaandair
    landseaandair
    from phoenix
    That's the exact opposite of what you wan't.
  3. landseaandair
    landseaandair
    from phoenix
    Maybe true duals and gl*** packs would sound right.
  4. Joey7319
    Joey7319
    with flowmasters and a crossover it will sound just like most 5.0 mustangs, because thats what most of them run.
  5. 53sled
    53sled
    from KCMO
    Single exhaust or use 2.5" back to gl***packs then step down to 2.0" tails. It with give a more nostalgic rap. I have never seen a 5.0 that didn't put in a x pipe and flowmasters.
  6. rustyfords
    rustyfords
    from Conroe, TX
    Thanks for the info. I've never had a Mustang so that's all news to me. (ok....let me edit that...my dad and I built a 66 fastback drag car in 1986 with a 289)
    I'd considered gl*** packs....I just don't want a roar in the cabin going down the road. That was ok when I was a teenager, but these days I want to listen to my tunes.
  7. Flowmasters will make it sound like a 5.0 Mustang.
    Put a pair of large bore ( 2.5?0 exhaust pipes on it with a pair of Cherry bombs as far back as possible (right in front of the rear end), then run it out to the bumper.
  8. landseaandair
    landseaandair
    from phoenix
    A good old fasioned turbo style muffler would hush it up quite a bit.
  9. rustyfords
    rustyfords
    from Conroe, TX
    The little roadster I built several years ago had duals with Smithy's. It also had a 302 in it.
    It was a cool sound for a roadster but I'm wanting something more mellow than that.
  10. JasonK
    JasonK
    Better run long tailpipes. I have a 347 headers and bolt on Flowtech gl***packs, it's loud as hell.
    And if you go with this type of muffler, let me know I'll sell them. pm me.
  11. rustyfords
    rustyfords
    from Conroe, TX
    This is actually pretty nice and mellow. It may be a bit much at speed though. I wonder how much of it I could block out of the cabin with good insulation though.
    http://www.youtube.com/watch?v=r6OsqQn5RW0
  12. unkledaddy
    unkledaddy
    I'm thinkin' turbos as landseaandair said.
  13. Mike51Merc
    Mike51Merc
    I just put a set of Thrush Turbos with 2 1/4 pipes on the 302 in my Falcon. Frankly, I'm disappointed that it sounds too much like a 5.0 Mustang.
    If I were you, I'd get gl***packs and small pipes, 2" max. If you want it quieter, get some 26" long ones or double up with two in front and two out back.
  14. millersgarage
    millersgarage
  15. rustyfords
    rustyfords
    from Conroe, TX
    Yeah...that's what I'm trying to avoid.
    What I've heard so far has me leaning towards some mild gl***packs. The Bronco in the video I linked to above almost has a flathead sound at idle...which is cool.
  16. millersgarage
    millersgarage
  17. rustyfords
    rustyfords
    from Conroe, TX
    Aw hell yes....that is sweet. And not obnoxious sounding in the cabin either.
    What are the specifics on your exhaust?
  18. Kamp
    Kamp
    from Peoria, IL
    Most 5.0 Mustangs, as everyone said, have 2.5" pipe with either an H or X pipe and 2 chamber flowmasters. 3 chambers are a bit less noisy, but still have the same "mustang" sound.
    I've got 2 1/2" ****** Aerochambers on my 5.0 Mustang, it still sounds like a 5.0, but not like all the other Mustangs - if that makes sense.
    Smaller is better for an old school sound, and you definately want 2" or maybe 2 1/4" pipes. I've got a 289 in my '31, with 2" pipes and 14" gl*** packs. It's loud, but I like the way it sounds, and it's not like a Mustang. If you're wanting it a bit quieter, maybe try 2" pipes and a pair of Porter's or something like that? The longer the quieter. That would be my recommendation. For a mild street car, 2" is probably fine. Mine's not stock, and there are only a couple mild bends in the exhaust, but it will turn 8,000 rpm through the 2" pipes.
    Hope this helps,
    Kamp
  19. nathan289
    nathan289
    from spokane,wa
    Im running 2.25" pipe with h pipe and dyno max turbo mufflers..
    it has a nice sound at idle and isnt loud inside the cab.. but its a wagon and the exhaust tips are a long ways away from the drivers seat..
    Ive never heard it driving away so i have no idea if it sounds like a mustang 5.0 at cruise..
    If i knew how to post videos to face book... lol or you tube i would so you could have a sample.
    How about the flowmaster hushpower mufflers?
  20. HOTRODPRIMER
    HOTRODPRIMER
    I have Flow Masters on the wagon,,40's I think but I didn't use any crossover pipes,,sounds good to me and not too loud just a nice rumble. HRP
  21. JeffB2
    JeffB2
    from Phoenix,AZ
    Try this link and crank it up:http://www.summitracing.com/parts/ofy-6009dp or http://www.youtube.com/results?sear....0.0.0.14229.0.0.0.0.0.0.0.0..0.0...0.0...1ac. longer sounds more mellow,I like the sound of my '54 with 24" Cherry Bombs deep purr at idle and a snarl when you goose it, pipes are 2 1/4" it will probably be a little less louder after I add the tailpipes.Cl***ic Exhaust has dual tailpipes for a '54 contact Him at (440) 466-5460 quoted them at $120 plus shipping,be sure and tell Him you are a 52-59 Ford Social Group member.Flowmasters= Muscle car era,Gl***packs= HAMB friendly
  22. DadsBlueFord
    DadsBlueFord
    from Hayden, ID
  23. lol ...i give up ... i cant deal ... dude ... flowmaster ?? not sound like a 5 .0 ......nite
  24. autometrics
    autometrics
    if you have room put magnaflows with a magniflow resonator, a little pricy but flows and sounds good
  25. Red Dragon Racing
    Red Dragon Racing
    from Indiana
    I run Thrush Gl***packs on my 289. Had a lot of comments on the sound. Definitely doesn't sound like a 5.0.
  26. millersgarage
    millersgarage
    block hugger headers, 2" pipe, no name gl*** packs, and 24" megaphones.
    Keep in mind, your engine makes a difference too, High compression, vs low compression motors sound different.
  27. JeffB2
    JeffB2
    from Phoenix,AZ
  28. Muttley
    Muttley
    Here's a video of my Comet, its running a stock 289, 2 1/4 duals and an old set of Cherry Bomb's. This should be close to the sound you'd get out of the 302:
  29. Diavolo
    Diavolo
    Turbos in stock location. If you want it even quieter, use a gl***pack close to the engine.
    In an O/T truck that had a 3" exhaust and a flowmaster, I put a 24" gl***pack in the location where the Cat used to be. It brought the noise down to a low hum but was still too loud for my taste so I pulled the flowmaster and stuck a generic turbo muffler on it and it was very nice and mellow.
    As an aside, Cadillac used to put "resonators" at the end of their exhaust systems (after the muffler) in the 60s to pull the noise level down another notch. The resonators were, essentially, gl*** packs.
  30. Nick Flores
    Nick Flores
    Here's a link to my 64 F100 with a 351w in it. I cut up some old side-pipes and used the gl*** pack sections (24") along with 2-1/4" tubing. Turn downs under the bed, ahead of the axle. Tends to drone a bit at speed because of the exit location, but sounds pretty good. No headers yet, just some 80's truck manifolds for now.
    http://www.youtube.com/watch?v=Ay4c4BxL8ic
