The Official English Wheel Thread
Discussion in 'The Hokey Ass Message Board' started by BAILEIGH INC, Jun 2, 2011.
  1. iammarvin
    iammarvin
    from Tulare, Ca
    Just a question...do the pipe/tubing ones need less bracing as compared to the cut steel ones? ( If that made sence). Welding preformed pipe looks way easier to build.
  2. scootermcrad
    scootermcrad
    HAHA! No problem! :D:D
  3. scootermcrad
    scootermcrad
  4. pimpin paint
    pimpin paint
    from so cal
    Hey,
    Pipe doesn't resist torsional loads as well as square tubing, and that's pretty important in the design of a wheel. I'm gonna guess that each of those pipe fittings & the pipe as well is atleast schedule 40 and may well have some high nickle contant. Unless you have access to cheap pipe fittings & high alloy pipe & are a good pipe welder, that could wind up being one expensive wheel!
    '' Humpty Dumpty was pushed "
  5. iNVisionPrototypes
    iNVisionPrototypes
    Hi guys!
    Here's my wheel. 32" throat, upper adjuster. Cl***ic shape...2 C's fabricated from 1/2" plate with a 4"x1/2"tk spacer rolled around the perimeter.
  6. mojo boogie
    mojo boogie
    Check out this Excel English Wheel . It belongs to Steve Hogue down in Torrance , Ca. ....
    Steve has done some great metal work on some of my cars .
    www.stevehogueenterprises.com
      239.9 KB
      281.8 KB
      224.3 KB
  7. jvo
    jvo
    There have been some questions about the through shaft on the cast iron e-wheels above. If you look at the photos in the link I posted, a little more than halfway down the photos, you will see a white e-wheel in Wray's shop that has a tipping attachment on the lower yoke.
    Anyone can build one of these attachments, as it simply unbolts and Wray can put the upper wheel back on that e-wheel in a couple minutes. It has a small wheel that you turn by hand with a tipping wheel on it. Neat idea, and it works really good.
    Not many of us can afford to buy a cast iron e-wheel, but if you can build a car, you can build an e-wheel frame. Have a look at the white e-wheel in the list of photos.
    There are several pics almost at the bottom of the list of photos. Sorry for the link. I looked on MetalMeet, but I couldn't find any photos of it on there
    http://cgi.ebay.com/Sheet-Metal-Sha...tDomain_0&hash=item588eab48a2#ht_67216wt_1398
  8. hasty
    hasty
    THis thread makes me weak at the knees. I must learn how to use one of these
  9. choppedmerc
    choppedmerc
    from Spokane
    Thought I would share this little gem. Cast Aluminum frame, br*** tension-er with br*** wheel and slide plate. brand name on it is FNDROL I came across an add once that advertised 3 sizes this being the middle size. sold to service stations to take out minor dents. The original paintless dent repair! I have used it and it worked pretty good! ( $10 garage sale score, covered in thick black grease didnt really realize it was aluminium until I got it home and cleaned it)
    and a pic of my wheel that I made. nothing real special but it works great and I use it often. I used Hoosier Pattern wheels. there wheels are spendy but real nice. I absolutly love the old school C shaped cast iron english wheels and would love to try one just to see if there is a difference?
    What I could use is a trained partner to wheel out larger panels!
  10. Unkl Ian
    Unkl Ian
  11. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    VERY COOL! :cool:
  12. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Any more homemade wheels?
  13. FrozenMerc
    FrozenMerc
    Here is my homemade attempt.
  14. yetiskustoms
    yetiskustoms
    This is a great thread....
  15. dechrome
    dechrome
    Here is my low dollar wheel. Made from 3/16 in plate with a 4x8 box section. The lower upright is a truck driveshaft with a 2 in spline to stop rotation. Upper wheel is a roller bearing with a 2 1/2 in bore and an offset shaft for a quick release feature. Flanges welded to frame allow various other tools to be mounted.
    deChrome
  16. simon g-s
    simon g-s
    Heres mine, quite small but good for motorcycle fenders and tanks etc. Handles ally no prob but too flexy to do much with steel. OK for what I need but will sell on soon to finance a bigger one now I know ( sort of ) what I'm doing.
    Laser cut 3/16" plate welded up from an ebay kit here in UK a few years ago.
      229.1 KB
      228.9 KB
  17. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    That's huge!
    Sent from my SCH-I500 using Tapatalk 2
  18. donut29
    donut29
    from canton MI
    Here's mine used all Hoosier patterns parts and a radial arm saw adjuster. 4X4 1/4 tube 36'' deep. Lots of flake and some panel's I painted
      489.6 KB
      482.8 KB
      390.4 KB
  19. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Look at this monster!
  20. driverrrr
    driverrrr
    I post this because I was there I am the younger guy learning from my friend Vince Wright. you can find him on facebook. he did the metal shaping and wheeling on the hard top he designed. thought the video had some pics of him at the english wheel but I will get some pics later. He did an inner and outer door skin. I think he might be superman. he hammered for 8 hours atleast a day with no lunch break for weeks. My name is Sonny and I am new to the site but love cars and metal working. wanted to share. I will share more thanks for viewing. hope the link works.http://youtu.be/IyNzylqpz-c
  21. driverrrr
    driverrrr
    I finally found the pics. here are some projects my friend Vince Wright used this English wheel on. Thanks for looking.[​IMG][​IMG][​IMG]
  22. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    what is the machine to the left of the wheel in this pic :confused:
  23. driverrrr
    driverrrr
    it is a mechanical press. you turn the handle on top and it screws the screw down and presses. the coller on the screw allows you to repeat the same depth press. He has some punch dies and a square tube bender he made with three half round mandrels and some other stuff. The ball on the handle is solid steel.
  24. dread
    dread
    came up with this one still a little to do on it hoping she works out well[​IMG]
  25. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    I think it looks bad *** :cool:
  26. lippy
    lippy
    from Ks
    Great thread. Gotta get one. Lippy
  27. bruffsup
    bruffsup
    from CANADA
    some little jobs I picked up at a flea market
  28. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    cute :)
  29. ratamahata
    ratamahata
    from Argentina
    E-wheel in progress!!
  30. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    right on :cool:
