Hanging dual pedals
Discussion in 'The Hokey Ass Message Board' started by jaaricp, Nov 28, 2012.
  1. jaaricp
    jaaricp
    Does anyone know of any hanging dual pedal bracket ***emblies for Apache trucks? Any pics would be really appreciated. I plan to run a
    hydraulic clutch set up with internal slave and bearing. All the brackets I seem to find are for brake pedal and automatics. does anyone not like to
    bang gears anymore?
    Joel
  2. Sumfuncomet
    Sumfuncomet
    Try Ch***is Engineering in Iowa
  3. Streight8
    Streight8
    if you are cheapskate do it yourselfer like me. Some of the full sized 90's chevy truck's with the v-6 came with 5 speeds. Shouldn't be hard to modify the pedal ***embly to work for you.
  4. propwash
    propwash
    from Las Vegas
    there was a single hydraulic cylinder with two outlets for clutch and brake that was used in some GMC pickups. We used to grab the hanging pedals and cylinders whenever we spotted them in the wrecking yards. I think they were 60-66, but may have been earlier, my memory ain't what it used to be.
  5. Buzznut
    Buzznut
    I thought I saw one from Lokar that includes a provision for mounting the master cylinder sideways behind the dash so that you don't have to clutter up the firewall.
  6. el Scotto
    el Scotto
    from Tracy, CA
    Use one from an early 60's Chevy truck, a little work and it'll bolt right in.
    I have the pedal ***embly and master cylinder from one I got out of a 1962 Chevy K10 in my 1931 Ford.
    Great stuff! :D
  7. GUMMEDUP CARBINATOR
    GUMMEDUP CARBINATOR
    from Detroit
    Jeep Wrangler 97 - 06 , cheap & plentiful.
  8. chevydave1965
    chevydave1965
    from Iowa
    How about the ones that ***us on here make & sells ?
