Incredible Rivets
Discussion in 'The Hokey Ass Message Board' started by nico32, Jun 8, 2009.
  1. scootermcrad
    scootermcrad
    Just for fun, you may enjoy this, if you haven't seen it... :D
    http://youtu.be/dyXEjn7f330
    (can't figure out how to embed the damn thing :eek:)
    <iframe width="420" height="315" src="http://www.youtube.com/embed/dyXEjn7f330" frameborder="0" allowfullscreen></iframe>
  2. Jim Dieter
    Jim Dieter
    from Joliet
  3. willymakeit
    willymakeit
    Great thread. Lotsa good info. May never use any of it, but doesnt hurt to have a good basic knowledge. Keep posting.
  4. 1gearhead
    1gearhead
    Attached is a riveted aluminum dash that I just made for my 1928 RPU
  5. BCCHOPIT
    BCCHOPIT
    What year did they start to use flush rivets?
  6. Ramblur
    Ramblur
    Well,we could probably debate this till the cows come home but one of the first would have to be Howard Hughes H-1 of 1935. And yes, it was all about the speed...:D
  7. BCCHOPIT
    BCCHOPIT
    Thanks...
    that works for me :D I had no clue is it was 30 - 40 or 50s
    Now I need to find some tools and get to it. I see a speedster in my drive way this summer:D
  8. Some really incredible work there, Thanks for posting guys. I don't have riveting equipment, so I made my battery box with small ****on head stainless screws and nyloc nuts. I'm happy with the result.
    chop job and Stogy like this.
  9. nico32
    nico32
    from fdl, wi
    Very cool stuff guys, keep it coming!
  10. Flathead Johnny
    Flathead Johnny
    from MA
    I'm wondering if you guys could tell me what size rivet gun was used on Back Seat Betty. I'm guessing its either a 3x or 4x. I'm looking at buying a rivet gun asap to play around with. Also what size rivets do you think was used to get that rivet head size on Back Seat Betty? Thanks!
  11. tikiwagon13
    tikiwagon13
    A really good source for riveting instruction, what to use, spacing, etc. is Carroll Smith's Prepare to Win. Racecar based but the theory is the same.
    Gret thread, doing some riveting work on my daughter's truck.
  12. ownster
    ownster
  13. 340HilbornDuster
    340HilbornDuster
    Awesome Ride!...
    Killer details, Stance, Gauges, Shifter! POLY!!!
  14. 29bowtie
    29bowtie
    Very informative series of books on car building, "Prepare to Win" and "Engineer to Win". Like you said, race car oriented, but lots of ideas that can be applied to hot rod building.
  15. 117harv
    117harv
  16. 24 Dodge
    24 Dodge
    here are some battery boxes and tool boxes I made for guys on here,my stuff is for sale in the cl***ified in miscellaneous section. Thanks Mike alum toolbox 2.jpg foz box 003.jpg new tool box 3.JPG toolbox12.jpg coffin 2.jpg toolbox12.jpg coffin 2.jpg
    Stogy and 117harv like this.
  17. Stogy
    Stogy
    Working on a glove-box for the 29 to go along with the theme...
    Patterned with bristol board, pencil, scissors and tape
    1) Material: Aluminum sheet (soft)/ Metal Supermarket
    2) Rivets: #30 (1/8") 'A' type/ Aircraft Spruce
    1/8" pop rivets
    Hole Size #30 with 1/8" clecos using cleco pliers
    Holes deburred with 1/4" countersink (best) or 3/16" drill bit (will do)
    3) Cut with Beverly shear, aviation snips, hack saw
    4) finished with file, sandpaper
    5) Bent up with angle iron, square tubing, round tube, mallet, hammer and vise
    6) Rivets hammer bucked and squeezed with pneumatic C squeeze
    7) Engine turn done with burnish tool with pilot removed(Brown Tool)
    on drill press with angle iron clamped to table for fence
    the latch I will be using
    Still have to get it in but happy with progress so far...
    Dash is 36 ford. Indented corner is to clear 29 tank skin.​
    Phillips likes this.
  18. Stogy
    Stogy
    You get your dash in 1gearhead?
  19. bengeltiger
    bengeltiger
    That is brilliant!
    Stogy likes this.
  20. 55willys
    55willys
    I will be riveting my 32 frame together including the boxing plates for a factory look.
  21. chop job
    chop job
    from Wisconsin
    bct likes this.
