Identify this engine Please
Discussion in 'The Hokey Ass Message Board' started by Dave Gray, Nov 27, 2012.
  1. gwhite
    gwhite
    SUPER MODERATOR
    I think this is an American truck/industrial engine - probably early 30's vintage. S.F. Co. casting mark also shows up on Waukesha-Ricardo Cylinder heads from the mid-20's.
  2. So how high from pan to rocker cover & how long is the head ?
  3. Dave Gray
    Dave Gray
    So it looks like the SF Co. is the foundry that cast the head and block
    and is probably not an indication of the engine manufacturer.
    Dave
  4. 40FordGuy
    40FordGuy
    Is that a clutch shaft, on the right side of the bellhousing ? It's definitely interesting,, and different !!
    4TTRUK
  5. Paulie9fingers
    Paulie9fingers
    I think you guys are referring to an engine that nathan posted in post #13, the original pic shows pedals made to the left side of the engine.
  6. Dave Gray
    Dave Gray
    I will measure the engine next monday when I get back to the warehouse.
    Dave
  7. Wild Turkey
    Wild Turkey
    I'm trying to figure out how it worked with 5 ports for 4 cylinders. Which are intakes and which are exhaust?
    More pix please -- that's an interesting old piece.
    Could it have come off a tractor? Any idea what the gear ratios are like?
    That part on the front where the fan drive would be look like a lot of stuff for just a fan -- could it have been some kind of PTO?
  8. landseaandair
    landseaandair
    from phoenix
    I'd bet the two center cylinders shared an exhaust port as well as the intakes being paired and tractors usually have a pretty substantial transaxle.
  9. the-rodster
    the-rodster
    This kind of stuff drives me nuts until I figure it out.
    I believe that I found it.
  10. landseaandair
    landseaandair
    from phoenix
    ^Bingo!^ What is it?
  11. the-rodster
    the-rodster
    1921-1924 Nash 40 Series 166 Cubic Inches
    Rich
  12. landseaandair
    landseaandair
    from phoenix
    Dang! I even searched Nash and missed it. You're good.
  13. fordor41
    fordor41
    I say that the rockers are offset from the centers and they're ***embled incorrectly
  14. Jaywagner1956
    Jaywagner1956
    That would make sense with casting marks the same,being Waukesha and Kenosha are not too far apart in Wisconsin
  15. Paulie9fingers
    Paulie9fingers
    You're the man
  16. Dave Gray
    Dave Gray
    You guys are unbelievable.
    I knew if anyone could figure it out you could.
    Way to go "the-rodster" You ARE the man.
    Thanks guys,you have been a great help.
    Dave Gray
    Carlisle, Pa.
