Beautiful, well placed wiring. Picture thread.
Discussion in 'The Hokey Ass Message Board' started by AstroZombie, Jun 24, 2009.
  1. chaos10meter
    chaos10meter
    from PA.
    Well this is how it starts off
  2. Larry T
    Larry T
    Kinda late, but for the plug wires.
  3. Lurk king
    Lurk king
    Wiring can definitely make or break a clean engine compartment.
    Here's some of mine.
    Here's something funny, when I built my hotrod I was a auto wiring novice so I turned to the Internet for help, I found a great article on wiring a 1934 ford hotrod and it said to install all the components an a piece of plywood with a good common ground. It seemed like a good idea so that's what I did. in retrospect it was totally unnessary for me as they were wiring a gl*** car.ha
    Oh well it still worked out.
  4. GeezersP15
    GeezersP15
    from N.E. PA
    Here's one of my 48 Plymouth
  5. masracingtd1167
    masracingtd1167
    from ct
    t2 003.jpg Some of my son's work
  6. ct1932ford
    ct1932ford
    Don't show this to The37kid:eek:
  7. ct1932ford
    ct1932ford
    Wire loom from Sacramento Vintage Ford also braided wire. Nice stuff!
      183.6 KB
      234.9 KB
      312.2 KB
  8. butch27
    butch27
    The '48 Plymouth wiring looks like it could be the "space shuttle" wiring. WOW
  9. need louvers ?
    need louvers ?
    Here's my humble contribution. It's a gauge cluster for a '49 Olds that I up dated with aftermarket gauges, wired, then set up with a connector so it can be pulled out with out screaming and yelling...
  10. dt50chev
    dt50chev
    What happens when you hit 88 miles per hour?
  11. roundvalley
    roundvalley
    Sbc
  12. Kamp
    Kamp
    from Peoria, IL
    Front mount distributor.. well Mag, which makes the wires really really long this way. Run under the headers and up, because I don't like them thrown over the valve covers.
    They are actually different now, attached to the side of the valve cover and run down to the plug. I can't find a great picture, they aren't attached to anything here but you get the idea.
  13. Jim Stabe
    Jim Stabe
  14. GeezersP15
    GeezersP15
    from N.E. PA
    Ha Ha....I find myself back in 1948, as just a gleam in my parent's eyes.:D
  15. langy
    langy
  16. need louvers ?
    need louvers ?
    Shure Langy, just throw a picture of the waxed cotton cord tied stuff up there like it's no big deal... 'Course some of us have been trying to figure that out for like, forever!
  17. Lowrders
    Lowrders
    from DUBUQUE IA
    I THOUGHT THE SAME THING!!!!
    lol!
  18. Kirk Wilmes
    Kirk Wilmes
    from Altus, OK
    No kidding. Where can you get that stuff?
  19. CTaulbert
    CTaulbert
    from Detroit
    Here are a few of my stuff.....I used to be into hiding everything as much as possible, but I've grown into making it look functional and good. Most recently, I've been cable lacing cloth wiring in the original colors from Ford.
  20. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Louvers,
    I like your wiring but tell me, how long did it take you to learn to write upside down like that?
  21. 32 hudson
    32 hudson
    Yeah where do you get the lacing. I should have got some from my work (navy yard ) before I retired.
  22. K13
    K13
    Here is a link that someone posted up on another thread at some point.
    http://www.dairiki.org/hammond/cable-lacing-howto/
  23. 1951Streamliner
    1951Streamliner
    from Reno, NV
    Lights and Ignition... that's all I need :)
  24. Roadsir
    Roadsir
    Here is a link on lacing. I find it works best to read the instruction while practicing with a piece of string. I think I will try this on my next wiring project. I like the idea of no bumps from the plastic tie wraps.
  25. Apittslife
    Apittslife
    Thankyou for the link!
  26. [​IMG]
    Uploaded with ImageShack.us
    Mine looks pretty good for a first timer....waddaya think??
    Seriously, you don't realize the quality of work on this thread until you do your own.
  27. need louvers ?
    need louvers ?
    Yes, thank you a bunch.
  28. jfreakofkorn
    jfreakofkorn
    Its nice and neat ......
  29. This is the wiring I did when I first built the Roadster, I'm in the process of tearing it all out and putting in a 9 + 3 kit from Todd at Rebel Wire. I just like things to be as perfect looking as they can be. I also re-did my engine when I put the new MSD dist. in. I'm glad this thread got started because I need some ideas, thanks. I'll post up some pic's on this thread when I'm done with the new and improved set-up.
  30. 34toddster
    34toddster
    from Missouri
    Geezer, what on earth do you need 14 relays for, looks neat and tidy though!:confused:
