1926 essex whet to do
Discussion in 'The Hokey Ass Message Board' started by clamdgr41, Nov 29, 2012.
  1. clamdgr41
    clamdgr41
    from maine
    dragged home this es*** and wondering what people think of using the frame with leafs on all four wheels and what i can swap the es*** front spindles out for to get something more updated the rear is no problem i guess i can just put a newer style rearend in? help needed
  2. Adapt a ford or Mopar axle to it. you can out Ford spindles on either ( the Mopar has to have the king pin bumgs reemed to fit the ford king pin).
    So the es*** has parallel leafs on all 4 corners correct?
  3. 32 hudson
    32 hudson
    clamdgr did you see my post #22 on the other thread where you asked about a g***er axel ?
  4. Southfork
    Southfork
    If a remember correctly, back in the day 26/27 Es*** ch***is were sought after for hot rod platforms. There were some nationally know race cars built on that ch***is, with some modifications. Is your Es*** frame actually two frames deep in the middle? Hard to describe what i mean, so do you have a side-view picture of the frame?
  5. clamdgr41
    clamdgr41
    from maine
    i didnt see it
  6. clamdgr41
    clamdgr41
    from maine
    it seem like it is deeper in the middle like another set of rails to stiffen it up??
  7. clamdgr41
    clamdgr41
    from maine
    yes it has parrell leafs on all corners
  8. Ghost28
    Ghost28
    That's a good looking and solid car, but depending what you are gonna do for a power plant the frame is gonna be the week point. I like the idea of using the leafs on all 4 corners, but lowering the car is gonna be a problem. a dropped axle of some sort could help on the front. I would try to incorporate a model A crossmember and front suspension under it with the transverse spring, with either split bones or hair pins and a 4 inch dropped axle that would get it lower. As for the rear springs they should be updated or modified also. Think about boxing the rails for strength.
  9. hoggyrubber
    hoggyrubber
    i will be interested in what you find out. i am going thru the planning stage for my '27 es***. i bought a little later front end with springs from a es***. it is a little wider but i might make it work. i was thinking about trying to get ford kingpins and spindles and trying to make them work. i really want to keep it all in the hudson family as far as parts go. i can tellyou this- a 52 hornet rear with springs looks like it will work great in the back. i will have to remake the rear perch.
  10. 32 hudson
    32 hudson
    post some pics of your es***. are youpaning on full fendered or no fenders ?
  11. pasadenahotrod
    pasadenahotrod
    from Texas
    You'll find the rear leaf springs are not parallel like the fronts. This was an effort by Hudson/Es***/Terraplane to limit ch***is sway by spreading the back of the rear springs further apart than the front.
    Theses ch***is were very popular in the racing community throughout the late 20s through the 50s. Stout rails with the lower reinforcment braces made for a great base for both one and 2 p***enger racers. The Niekamp car, winner of the 1st AMBR tropy was built on a modified Es*** frame.
  12. hoggyrubber
    hoggyrubber
    you are right pasadenahotrod, the original springs were way wider in back. i wondered the reason. it's close to the same angle as the latter stepdown springs. not trying to hyjack this thread or anything, i have a 40 ford axle i had bought to maybe use awhile back. i didn't get the spring or anything. maybe i need to get off my high horse and consider using it. it would prob be a lot easier to make work as far as parts go than the es*** fram i got later.
