dodge disk
Discussion in 'The Hokey Ass Message Board' started by muffmullins, Nov 26, 2012.
  1. muffmullins
    muffmullins
    from acme
    hey guys new to this site but im building a 1950 dodge truck so far iv body dropped it 3 foot (yes it drags but looks so kick ***) chevy 307 motor 700r4 trans 6 lug chevy rear end cobolt rack and pinion. i need to find a way to convert the front drums into disc the cheapest way posiable anyone got any hints. also how is everyone doing ***le work on these cl***ics
    thanks muff
  2. supervert
    supervert
    3' really:confused: does the frame go though the dash? we need to see pics, and isn't the front a straight axle? how are you using a rack?
  3. propwash
    propwash
    from Las Vegas
    you've dropped it THREE FEET? wow...that really must drag - what was it before, a mud racer?
    I, too would like to see your R&P setup. You'd be way ahead to install some replacement front end for which disc brake conversions are common.
    If you're going to cut corners ("cheapest way possible") you'll have to really pay attention. There really isn't anything more critical on a driving vehicel than the brakes.
  4. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    3 feet? We must be using the same tape measure. I say its 9" online too :D
  5. propwash
    propwash
    from Las Vegas
    OP must be having trouble getting his tail out from between his legs....
  6. brad chevy
    brad chevy
    You need to do a tech thread on how to do a 3 ft. drop when the truck is only 11 inches off the ground to start with.Post the pics.
  7. 56 Dodge Pickup
    56 Dodge Pickup
    I would like to see the three foot drop it must have been on a lift as far as the disc brake conversion I did one on mine using the stock straight axel and a kit from aajbrakes.com there was some fab work but they have been working fine for five years. Jim
  8. muffmullins
    muffmullins
    from acme
    cant figure out how to up load the picks and floor pans are right up tight to the dash. it is a a straight axle i took the rack and welded brackets to the axle mounted the rack on it and put a 4 inch slip joint in the steering bar. could i use a disk brake kit off of a ford or chevy?
  9. muffmullins
    muffmullins
    from acme
  10. muffmullins
    muffmullins
    from acme
  11. n847
    n847
  12. supervert
    supervert
    where are you located?
    how do you sit in it with it channeled (body dropped) that much?
  13. muffmullins
    muffmullins
    from acme
    acme pa about a hour out side of pittsburgh and your head hits the roof and my knees r in my chest
  14. B Ramsey
    B Ramsey
    sounds very comfortable.
  15. muffmullins
    muffmullins
    from acme
    any one have a idea of about how much the whole disk conversion cost? trying to get it done this week its the last thing i got to do before i take this ***** out and burn some tire in it
  16. muffmullins
    muffmullins
    from acme
  17. badshifter
    badshifter
    Sounds awesome. With the rockers 2 feet below pavement, I don't think you need brakes.
  18. You are in Penn.? You also mentioned something about ***leing as well right? My advice is stop right there and first go to the state D.M.V. web site and get the information you need for ***tleing. You sir are in a ball breaker of a state for any ***le issues, that's one. You are also in a state that's has some pretty tough motor vehicle laws, don't be surprised if that frame s****er you built won't even get a mile from home without being h***led or more tickets than carter has liver pills. Sorry to rain on your parade, you sound pretty stocked about your build, but I truly think you are in for a few harsh reality checks.
    I wish you the best with the ***le issues and hope for all involved you build something safe, TR
  19. Sorry muff, everything about this paragraph has " your gonna get yourself or some innocent person/persons killed ". If you have a state vehicle inspection, and I'm pretty sure you do, safe to say this truck will never p***.
    I'm going to sleep better tonight knowing I said this, hopefully made you think a little, TR
  20. kennb
    kennb
    Floor pans up to the dash? I gotta see a picture of the interior. Where are the gas and brake pedals. Coming out of the dash? Ken
  21. trollst
    trollst
    Oh-Oh, I sense the "R" word coming on.....get the popcorn....
