Sun distributor amplifier idea
Discussion in 'The Hokey Ass Message Board' started by NITRONOVA, Dec 3, 2012.
  1. NITRONOVA
    NITRONOVA
    I have a 6 volt sun distributor model mdt-50. I would like to be able to test/set up GM HEI, Petronix converted, chrysler & ford electronic as well as MSD distributors. I heard people are successfully using a Chrysler electronic mid 70's era control unit as a power amplifier. I tried to hook one up (using the 5 pin style unit), but my strobe is not happy with the signal. The strobe appears to want to work but has a ghost pulse with the "real strobe". I am not convinced either flash is correct. My tester flashes correctly on points, can someone please explain to me how to use this control unit correctly as a pulse amplifier? (wish I would have coughed up the coin for a good 12 volt machine)
  2. NITRONOVA
    NITRONOVA
    I am open to other ideas to create a pulse amplifier. (hopefully for free)
  3. NITRONOVA, Do you know Marvin Winship???
    Have you done a goggle, EB, CL search for the SUN 12 volt adapter?
    I p***ed on two 6 volt sun machines (one had an adapter) before getting the 12 volt I used for over 20 years (sold it).
    weld on.......
