Projects Widening 18"wire wheels
Discussion in 'The Hokey Ass Message Board' started by percifab, Dec 5, 2012.
  1. percifab
    percifab
    from Dixon,CA
    Anyone ever widen wire wheels? I just finished my first one. At first I didn't think it would be that hard. The easiest part was cutting and welding the wheel back together. The hard part is making sure you have 100% penetration and making it look like it came that way. The best compliment is "what did you do?" I added 2 inches one 1" strap to each side. Going from 3 1/2 to 5 1/2.
    ImageUploadedByTJJ1354764542.660933.jpg ImageUploadedByTJJ1354764505.808618.jpg
    ImageUploadedByTJJ1354764577.311418.jpg ImageUploadedByTJJ1354764606.260464.jpg ImageUploadedByTJJ1354764639.433859.jpg ImageUploadedByTJJ1354764659.007032.jpg
  2. GreenMtnBoy
    GreenMtnBoy
  3. curbspeed
    curbspeed
    Have you used a dial indicator to check for runout yet? That's the true test.
  4. Nitro Breath
    Nitro Breath
    from Eugene, OR
    Wow, that's a challenge. Nice job. Did you lathe turn that outside rim?
  5. jratz1966
    jratz1966
    looks good,any pics of work in progress?
  6. zibo
    zibo
    from dago ca
    Yeah I did a 16" wheel,
    and it was easy to get it 90% true,
    but that last 10% was tough!
    Lotsa hammering.
    Next time I'll check beforehand if the rim is true!
    What tires are you gonna run on these fat rims?
    TP
  7. brokenspoke
    brokenspoke
    Danny at Bruces rod shop has done some...he did a post somewhere
  8. percifab
    percifab
    from Dixon,CA
    The wheels were true before I stated. I marked the wheel before I cut it so it would get it back in the same place. I'm putting 750 heavy duty truck tires. The tire should be mounted on a 6" wide rim but I think 5 1/2" is good enough. They are for the rear of my 30xl model a pickup
    ImageUploadedByTJJ1354801291.710967.jpg ImageUploadedByTJJ1354801327.345918.jpg
  9. percifab
    percifab
    from Dixon,CA
    Now I'm on to the second one. Now that I know how to do it I'm keeping track of my time. I got it cut and prepped.
    ImageUploadedByTJJ1354845697.728460.jpg ImageUploadedByTJJ1354845777.593598.jpg
  10. You already missed a step.....
    HOW did you cut it, cut-off wheel? lathe?
    weld on.......
  11. percifab
    percifab
    from Dixon,CA
    A big cut off wheel on a grinder. It's a hand full. I had an extra spindle and hub so I clamped it in the vice to hold it while I work on it
  12. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    Two words of advice, Next time widen the drop center, you're wheels will be somewhat difficult to mount a tire onto. Also, You didn't take it too extreme, so I think you'll be ok, but widening these old wire wheels is generally a bad idea because they're so weak. The only reason they're usually ok is because they're so skinny they cant get enough traction to hurt themselves, but when you start you widen them, they are a lot more stressed. But like I said, you didn't take too extreme and will probably be ok, but keep an eye on them.
  13. alchemy
    alchemy
    Is there a new hoop that anybody has used when widening these? Maybe cut one side of the new hoop wider, and weld that to the center of the '32 wheel. Then you have a fresh lip, and one less weld to keep straight. No bending of a fresh band required.
    I'm thinking there's got to be a tractor hoop out there somewhere that is the correct inner diameter.
  14. Kevin Lee
    Kevin Lee
    Super Moderator
    Believe Josh Shaw detailed the process of adding a tractor hoop as you describe, alchemy.
    As I remember it was kind of of a "using up the leftovers" side note to a thread about making 18" salt wheels with solid centers and hoops cut from 18" wires... And I believe the Dynaliner Coupe is running those wheels. (wires with tractor hoops)
  15. alchemy
    alchemy
    Here's Josh's thread: http://www.jalopyjournal.com/forum/showthread.php?t=263768
    He does similar, but not what I was thinking. But I guess I just need to get a tape measure out and give it a go. I found a couple online tractor parts suppliers.
    I did like Josh's method of cutting the wheels with a clamped plasma cutter.
  16. percifab
    percifab
    from Dixon,CA
    I made the rings for the wheels today. I bent a 8' piece around a 15" wheel. I made 8 bars and tacked them to the center to clamp the ring to on the wheel. You have you round the corners so they fit in the bead of the wheel. I used the short ones first witch are 4" long. Once I got it all strait and true on the hub I tacked it heavily. Then cut the short bars off and tacked on the long ones that are 5 1/4" long. Bough sides of these have to be rounded to sit in the bead. Then I started on the other side with the second ring doing the something. I got it all tacked together and was about to put it on the hub to weld it up and it rolled off the work bench and broke into 5 pieces. Now I have to start all over again. ImageUploadedByTJJ1355025970.696666.jpg
    ImageUploadedByTJJ1355026081.991538.jpg ImageUploadedByTJJ1355026163.877070.jpg ImageUploadedByTJJ1355026214.090665.jpg ImageUploadedByTJJ1355026310.959640.jpg
  17. moefuzz
    moefuzz
    Great Tech! Thank for sharing!
  18. lrapso
    lrapso
    from Costa Rica
    very good work, stay posting
  19. Joshua Shaw
    Joshua Shaw
    The Tractor Hopps are extremely poor quality. They are designed to run at 30 mph. They'll work in a pinch, but if you really want them true and perfect buy actual wheel hoops from suppliers. (about triple the cost of the tractor hoops though.. :cool:)
    Biggest KEY to doing any of this succesfully is CHECKING THE STOCK WHEEL FIRST!! Sounds simple, but a lot of guys forget this step, and chase there tails to get the finished widened wheel perfect..
    Great thead by the way! Love seeing guys do "serious" modifications in there home shops and just "figuring it out". That's what it's all about!
    Enjoy looking at how you did it your way!
    Joshua Shaw
  20. alchemy
    alchemy
    Any favorites?
  21. Joshua Shaw
    Joshua Shaw
    Well.. No. Unfortunately Scott (Owner of Dynamat) found and bought the hoops. The supplier he found would only sell in BULK, so Scott said "screw it, I need em'" and bought like 30 or 50 hoops. 19x3 and 20x5.5 He then, slowly sold them to guys all over the midwest. I have 4 of each I'm hording.. The down side is, I never knew who that company was.. BUT, If Scott can find em' I'm sure there on the interweb somewhere.. ;)
    Sorry.
    J Shaw
