Help ID. a Deck Lid
Discussion in 'The Hokey Ass Message Board' started by Chopd48pan, Dec 6, 2012.
  1. Hey Guys, a buddy laid this deck lid on me for my stalled Model A project.
    Well Model A, it isn't. I'd like to return the favor by figuring out what it does fit. It measures 41 1/2" x 27 1/2" and roughly 28 1/2" along the radius. Thanks in advance. Howard
  2. Really..... Nobody ? Huh oh.
  3. It may take a while. I had a later Mopar deck lid and it had round holes inside like that, but that might not mean a damn thing.
  4. rpivinton
    rpivinton
    It's for a '33-34 Chevy Coupe. Appears to be in good shape, too.
    Bud
  5. Thanks for the replies.
    "It's for a '33-34 Chevy Coupe. Appears to be in good shape, too. Bud"
    Yeah, it's real nice, with one low spot and some rust thru on the inner structure. As soon as he handed it to me I knew it was to wide for my coupe, but in that shape I had to test fit it..... about 5" wider. Thanks again Bud.
    Howard
  6. MRTS33
    MRTS33
    Agree!!
    Looks like my 33 Pontiac. I will measure tonight and report later.
  7. bronco gasser
    bronco gasser
    from GB WI
    It looks like a pontiac, not ford or chevy.
  8. So MRTS33, is the hinge mounting area like your Pontiac? Or is that Chevy? As far as I know there was no association between the two at that time.... right? So no interchange from one to the other. Mitsubishi wasn't making both like now.:rolleyes:
    Also are trunk and rumble lid the same or different?
  9. Actually, even that early they could be the same body shell from the cowl back.
    Rumble lid has the handle on top, side hinges and mounts for the upper seat in it.
  10. TagMan
    TagMan
    I looked it up in the 16th edition of Hollander's Interchange, but their listings only went back to 1935. Maybe someone might have a slightly older edition and can check out the interchange between Chevy & Pontiac deck lids for you.
  11. Thanks Tagman. I wouldn't have thought so, but, Rustynewyorker may very well be correct .
    Howard
  12. Rustynewyorker, yeah I know about the handle location difference. I was thinking that the hinge area was rather substantial for a trunk lid. Leading me to think rumble lid. But hey I'm not that savvy about the Model that I own yet alone other brands.
    Howard
  13. Torkwrench
    Torkwrench
    Looks like a 33-34 Chevy coupe. If so, it should be for a Master series. If I remember right, the 33-34 Standard Series decklids were still wood framed???
  14. MRTS33
    MRTS33
    My original lid was shot. The mounting holes look right though. The one I have now is from a Chevy. And fits perfectly. So they do interchange. MAY fit Olds & Buick too.
