These are brand new and pretty faithful to the original early 60s design. http://www.summitracing.com/parts/sun-fz88r/media/images
What era are you looking for??? The year the car was built ('60)? From the mid 60's?? Late 60's??? The 70's???? Maybe even the 50's?????
Here's a repop of a late 50's early 60's Sun that you can buy from Cl***ic Chevy: http://www.cl***icchevy.com/chevy-tachometer-sunpro-retro-1949-1972.html
Choose one. Depending on when it was built/hot rodder and who was building and cash flow virtually anything in this thread could have landed in it. if you are looking for something cutting edge from the time period that the car came off the ***embly line a football tach would have been the real deal. http://www.jalopyjournal.com/forum/showthread.php?t=224785&highlight=tach
Just because it says "Bonneville" on it doesn't make it a Pontiac. Are the Salt Flats Pontiac? Here are Pontiac tachs.....
That Bonneville tach is probably made by dixco .... they did that alot, let other folks put their name on the Dixco brand ... I got one that says Napa, looks the same.
it may have had one of these, S&W makes a real authentic copy of these gauges now only with modern movements.
Actually many people believe that the sun super tach was a later '60s tach. I have a very early one that has a date code on the back of Febuary '64. But many would argue the point.
Bought a Mooneyes half sweep tach brand new off eBay for $65. Has sixties look and does everything a tach is supposed to do.
Honest Charley has a half sweep tach that might work. http://www.honestcharley.com/tach-half-sweep-8000-rpm-no-name.html
SW 765 J tach, date code 1963. Going under the dash in my 30 coupe. 6K RPM range isn't a problem with the nailhead. They were also available in different ranges. Found at a local swap meet for $20 still in the original box. Required sender took a little more searching. Mounting bracket is a custom fabrication for the tach and a ****on that will be used as a horn switch. Rolled lip around the edge, heavily textured face and 1 inch sides for looks. Canuck
