Holley 94 fuel inlet fitting help needed
Discussion in 'The Hokey Ass Message Board' started by justpassinthru, Apr 29, 2012.
  1. justpassinthru
    justpassinthru
    I would like to plumb my Holley 94 carbs with 5/16" steel line for the fuel.
    I am not having any luck finding fittings with the proper 1/2-20" straight thread with the SAE 45 degree 1/2-20 Inverted female flare for the 5/16" line.
    Any of you guys have any ideas on if the fitting even exists and where to get them?
    Thanks, Bill
  2. Revrev
    Revrev
    I used (per George MacNicholl's book) a Weatherhead 7915 br*** fitting from Napa (Weatherhead No. 7915. BRAKE LINE ADAPTER. Male Pipe Thread: 3/8” Dia. Inverted Female: 5/16” Tube.) beveled the tread end (little at a time) until it seated correctly in carb.... some Teflon tape and a year later, 3x2 with no leaks. :0)
    revrev
  3. jimvette59
    jimvette59
    You could use a Model A Gas Line Fitting # 0442707/CB it is 1/2x20 for a 1/4" line with a feral. If you can drill out br***, I mean grinding a drill bit so it wont bite and chamffer it to 45 degs. You will have to drill out the carburetor because it is made for 1/4 tubing or your 5/16 will not go in to and have the feral not seat correctly.
    I just had a thought why don't you make a manifold large enough to supply the fuel into 1/4 lines into the carburetors ?
  4. Blue One
    Blue One
    from Alberta
  5. jimvette59
    jimvette59
    WOW thank you from an old timer. Jim.T.
  6. Nailhead Jeff
    Nailhead Jeff
    from fresno
    If the threads are rough they retap to 1/4 pipe without drilling.
