Butt welding made easy!
Discussion in 'The Hokey Ass Message Board' started by fitzee, Dec 7, 2012.
  1. Never saw that done. But it will probably be my method of choice, it's almost Bozo proof.
    Thanks Bozo.
  2. vtx1800
    vtx1800
    Thanks for my "education for the day"!
  3. nickk
    nickk
    That's what I was thinking, and although I don't have much issues getting the patch to fit a hole usually this still may come in handy sometime. clever thinking for sure!
  4. kgp50
    kgp50
    Man I love this kind of stuff on the HAMB! Very clever. Thanks for sharing.
  5. hammered30
    hammered30
    from west aus
    what a great idea . they say you should learn something new every day and i did from this thanks
    paul
  6. Babyearl
    Babyearl
    Yep,,,I think you have something there. That looks so easy, I think I might even be able to do it.
  7. sr808
    sr808
    Great post, Fitzee! I'm going to use this.
  8. tiquer
    tiquer
    This is one of those WHY didn't I think of that?? Excellent post thanks for the tech .Cool job. What other sheet metal secrets do have :cool:
  9. Dane
    Dane
    from Soquel, CA
  10. 1971BB427
    1971BB427
    from Oregon
    Really great tech write up! Simple and easy to understand! Thanks!
  11. TOMMAY
    TOMMAY
    from MOBILE,AL
    One of those ,slap yourself on the forehead,why didn't think of that kinda posts.
    Thanks
  12. young'n'poor
    young'n'poor
    from Anoka. MN
    That was well do***ented. I'm glad that came up because I have the patches for my galaxies quarter panels but having never done it before I was nervous to try. That looks like a fairly easy method!
  13. Fortunateson
    Fortunateson
    That looks great. My nephew is an awesome metal-man and I think this is what he tried to explain to me once. Thanks. Now, what is the concensus on the corners? Some say always have round corners and others say it doesn't matter.
  14. rosco gordy
    rosco gordy
  15. thesupersized
    thesupersized
    my brother and i do this, makes things easy, "cut to fit"
  16. fleet-master
    fleet-master
    I try to do mine this way wherever possible. One thing I was taught was to always radius the corners to avoid having a concentrated heat build up in those areas. Makes for less distortion and easier to finish the area.
    Nice job Fitzee...your Flatliner sure is looking gooood !! PB
  17. fleet-master
    fleet-master
    sorry Fortunate son..I musta skipped past your post. See my post above :):D
  18. dad-bud
    dad-bud
    Great job Fitzee. A really thin disc is a key to getting it right, I guess.
    To overcome the problem of getting too much heat in the 90 deg corners from using a flat disc (that fleet-master noted), you could cut near the corners at 45 degs or a couple of 30 deg cuts.......?
    Thanks for the post and good pics showing us your style.
  19. GizmoJoe
    GizmoJoe
    Hey Fitzee...
    Nice tech sharing.
    I've found that method easiest given my skills.
    It's hard to beat the Walter cutting discs. I did get a few Mitsubishi (as I recall) discs from Princess Auto not too long ago. They are a little thinner than the Walter and seem to be as long-lasting. Thinner would be better for this method.
    The Flatliner is looking good.
    Here's hoping you folks have a good winter....
    Joe
  20. raymay
    raymay
    I trimmed an end patch for a better fit in a similar manner once and was pleased with the result. After seeing your technique and result, I think I may try this method more often.
    Nice job, thanks for sharing.
  21. dniemi
    dniemi
    Great idea! I'll have to try it this way myself, fitting a panel is always a very finicky thing. I personally never seem to get it perfect.
  22. fitzee
    fitzee
    Thanks guys as for radius the corners.I done this too.. very hard to do this with a 4 inch grinder.lol.You could use a air saw or small zip wheel.. I dont have any troubles with corners. I watch my heat both when welding and grinding. I like to start in a corner and having a radius corner would be harder then this..Im always about saving time.. I would love to have the time to slow down and get right into my metal work but my plate is so full that time is something I dont have alot of..
  23. 1/2done
    1/2done
    from Ohio
    I started doing that when I was working on the filler panels between the trunk and fender.
    A small air powered sawzall works great after you start the cut with a cutoff wheel.
  24. NashRodMan
    NashRodMan
    That is cool Fitzee. Thanks for taking the time to write it up and post picts!
    NRM
  25. brady1929
    brady1929
  26. DamnYankeesKustoms
    DamnYankeesKustoms
    Using a scribe also works very well once you have your piece shaped, most aftermarket patch panels need some m***aging before you can cut,fit and weld in...
  27. chopolds
    chopolds
    from howell, nj
    Great technique...works especially well on looooong patches, like repo quarters, where it's difficult to trim it out and fit it, cause it's too big!
  28. ctfordguy
    ctfordguy
    Hi,
    Don't have a Princess Auto down here in Connecticut. Could you post the item
    number of those nice thin Mitsubishi cutting wheels. I'm using Dewalts. They seem thick. What is the diameter on them?
    Thanks.
    Bruce in CT
  29. Very interesting, can't wait to try it! Thanks for the great tech.
