Projects Who's building a model A pickup
Discussion in 'The Hokey Ass Message Board' started by chevydave1965, Oct 11, 2012.
  1. schoum
    schoum
    from france
  2. I am in the planning stage of building 1 of these.
    Mtw fdu.
  3. Nick O
    Nick O
    from Ohio
    Here is mine. Still working on it. Have owned it 48 years, drove it to high school.
    IowaMercMan likes this.
  4. chevydave1965
    chevydave1965
    from Iowa
    Nice guys ! Thanks again for posting all the great pics !!
  5. Rok 51
    Rok 51
    A bit late, but I'll add mine.
  6. treb11
    treb11
    that is straight up bas *** sir!
  7. How much do u want for the one youre selling ??
  8. tjmercury
    tjmercury
    mine is still in the "big pile in the corner of the shop" phase, so I didn't figure I'd even bother posting pics after seeing some of these awesome machines. It's a 29 rpu.
  9. alchemy
    alchemy
    Hey Dave, as you know I've collected a pile of '28 CC parts. I'm either going for the Scorchik full-fendered look, or a simple highboy like that Aussie pickup from a couple years ago. I'm also going to collect as many early '28 AR parts to use as I can afford. I think it woud be fun to screw with the restorers by wasting the hard-to-find parts on a hot rod. Drum taillights and beavertail fenders, here I come!
  10. kingpins
    kingpins
  11. rusty1
    rusty1
    ...a friend of mine owns this one...
  12. flt-blk
    flt-blk
    from IL
    Kind of a dark picture, but mine has a lot of miles on it.
    Chaneled and no chop.
  13. fiftyv8
    fiftyv8
    from CO & WA
    I'll ask here since a lot of guys on here have closed cab pickups.
    How do you install a front door gl*** into the door of a 28/29 closed cab pickup as they don't seem to be the same as tudor or coupe doors?
  14. gimpyshotrods
    gimpyshotrods
    That's because the '28-'29 CC/PU doors are leftover '27 Model-T doors.
  15. 27 Tall T
    27 Tall T
    from Butler Pa.
    my 29 project
  16. retroted
    retroted
    from USA
    Mine, the day I brought it home.
  17. wingedexpress
    wingedexpress
    Nice truck 27Tall T.
  18. mullskull
    mullskull
    1931 Pick-up with a 31 wide bed.. 56' 324 Rocket... T-5 trans..Ford 9", 40 steering box, brakes(front) and steelies... what ever isn't original Ford, was either fabbed in my garage, or at Pete & Jakes-
    i have been meaning to start a build thread( for the last 3 years)... but at this point it's to overwhelming...too many photo's!!
  19. 31Apickup
    31Apickup
    Here's a few of mine through the years. Got it in 1975 when i was 13, finally had it drivable in 87.
  20. jvo
    jvo
    Here's mine. I added 4 inches in the middle of the doors for a little more leg room, but I reversed the firewall, which effectively placed the toe board about 4 inches back towards the seat. I have a Dodge Dakota pickup seat in it, narrowed and its not just too bad, although I wouldn't want to drive it 500 miles without stopping. Good for scooting around town though.
    The wheelbase is also stretched 4 inches. I have a bunch more work to do to it, but its on the road, so it will have to wait till I get another rod up and running, before I tear it down again.
  21. fiftyv8
    fiftyv8
    from CO & WA
    BUMP...
  22. carmuts
    carmuts
    I had a 28 rdstr pu, I was restoring it up until my battle with cancer. Had to sell it to pay for the bills. One thing I regret doing, but necesary at the time. Rod
  23. brewster55
    brewster55
    you already got answered...
  24. fivelitreford
    fivelitreford
    from Nova,Ohio
    Doing a 29 roadster pickup, ch***is 2/3 done.
  25. Hotrodhell35
    Hotrodhell35
    Just picked mine up!! Mid to late 50s east coast style... Low, channeled, no chop, fenderless, LOTS OF CHROME, too many carbs, wraparound dash, etc...
  26. Last edited: Dec 8, 2012
  27. fiftyv8
    fiftyv8
    from CO & WA
    Nope, no answer to my question on how to install the gl*** into these doors...
    If you know where the answer is that I have missed please posted again for me...
  28. 55willys
    55willys
    I am building a 28-29. Sorry no pics (camera broke) I am planing to use a 32 frame , kicking up the back till it is parallel to the middle and 8" up. When this is done the bed rail and belt line of the cab line up and the bed has a flat place to bolt down. The axle is moved ahead of radiator and the spring is hung from the bottom of the bones. engine is a reverse flow flat 8 with a front drive blower (shaft will run through crank hole of radiator) intake through exhaust ports and exhaust out the top. Fordson tractor dual cowl steering (no tie rod) Hope you can picture all that from the description.
  29. wingedexpress
    wingedexpress
    fiftyv8 Is the gl*** out now?If it is get new window runs ( i think thats what they are called, u-channel with felt) and cut them to length.Its been a long time but i think i put the back one in then gl*** and slid the front one in from the top last. new rubber at the top and put the molding and regulater arm back on.
  30. fiftyv8
    fiftyv8
    from CO & WA
    Thanks for your comments.
    Yes, I have new gl*** that I will need to install in the future and was wonder what the easiest way of install gl*** into thes doors.
    The doors do not have a removeable top piece so the gl*** can not be installed from the top.
    See the attached pic's.
    I figured with so many folks built or building pickups as well as T's somebody must have done this install before.
    My doors originally had no gl*** when aquired.
    I even posted on a T Coupe thread which have the same doors and no help from there either.
    It does seem that the gl*** needs to be put inside the door and maybe the channels slid in along each side of the gl***, but that is just my best guess.
    If knowledge of this install is so hard to obtain, then there must be a lot of guys like me needing to know.
