Projects 270 Dodge Poly Before and After
Discussion in 'The Hokey Ass Message Board' started by buckhog, Nov 21, 2012.
  1. buckhog
    buckhog
    Well after months of machine work, hunting and waiting on parts, cleaning, painting, and ***embly, my red Ram Poly is fresh and better than ever. So happy how it came out, that I just had to share!:D
  2. hotcoupe
    hotcoupe
    very good lookin` motor! is that a 390 holley?
  3. buckhog
    buckhog
    Thanks, Yes it is.
  4. honeyman
    honeyman
    from Steiner
    Super looking motor AND Savoy!!!
  5. George
    George
  6. OLD HEMI
    OLD HEMI
    Looking Good!
    Lee
  7. Harris
    Harris
  8. servi53
    servi53
  9. ezdusit
    ezdusit
    Thanks for sharing. Beautiful engine.
  10. 73RR
    73RR
    Any details that you'd like to share?
  11. Yes, do tell . . . stock, overbore, cam, compression etc.
  12. deadgearhead
    deadgearhead
    from Washington
    It's even better when you put it in the car and get to hear the horses sing. :D
  13. Going in your avatar 56 ?
  14. I applaud your efforts, would have been easier and cheaper to go the SBC route. I took the same course as you with my 59 Fury poly.
  15. fab32
    fab32
    Turned out great. Will look even better nestled down in the engine compartment making the fan go round and round.:)
    Frank
  16. buckhog
    buckhog
    Hey all, and thanks for the positive comments. It will be soon going in my (avatar) 56' Savoy, which was originally a 6 popper that needed a rebuild. So I figured I might as well make the switch now and re-build a v-8. I'm hard headed and wanted an engine from the time period of the car, which did cost me a little more but made me happy. The engine was originally a 270 from a 56' Dodge Coronet. Someone last had it in an old truck that was running when parked. I took most of it apart and started cleaning stuff up. Then I took the techinical hard stuff to a friend of mine who owns and operates a engine machine shop, mostly working with dirt stock car and sprint car motors. He did however grow up running these cars and is very good with early engines as well. I, myself am not an expert at engine building, and know just enough to be dangerous. anyways, we foud it to be .030" over from a previous rebuild and took .050" to clean up the cylinders, leaving me .080" over. I was a little weary bout this, but had the block sonic checked and found it to be fine. Egge had a set of pistons on the shelf for it. Predator cams reground the cam, and crank was remachined in house. Heads were all re-done in house too. Also has a 4bbl intake from Hot Heads, with a Holley 390 carb. So now it's up to me to make everything work. (Linkages, wiring, belts, exaust, hoses, ect...)
    Anyone have any recomendations on mufflers for these motors? I want to hear it, but also want to hear myself think. Going with a new dual exaust, once I get it up and running.
    Hope I didn't bore everyone to death!
    Brad
  17. George
    George
    Duals with turbo mufflers,perhaps?
  18. kennkat
    kennkat
    Turns into a beautiful Swan!!:D:D:D
  19. conormulroney
    conormulroney
    Very beautiful engine! Excellent job
  20. buckhog
    buckhog
    Got an update! It's in the car! Worked all weekend in the garage, and I'm totally suprised how well things went. I have just a few things to go yet before it's first fire.
      191.5 KB
      183.1 KB
  21. 4msfam
    4msfam
    Looks fantastic!
  22. Hot damn! I bet it was a little easier to squeeze into that Savoy engine bay than my 259 Poly was to squeeze into a '49 Plymouth Special Deluxe! It looks like it was made to go in there - awesome work! There's just something about the valve covers on a mid-50's Polysphere motor, like they are grinning at you with those teeth.
  23. buckhog
    buckhog
    Yeah, very happy with how it turned out. It went in fairly easy as the poly was available in my Savoy in '56. I just had some things to change over from the six banger. Got just a few more things to do before the moment of truth and the first fire up. I too like the looks of the Polysphere and actually p***ed on a nice set of Hemi heads and valve covers before my rebuild.
  24. DYNODANNY
    DYNODANNY
    The engine looks good, the dual turbos sound good.
