Projects 1928 essex coupe
Discussion in 'The Hokey Ass Message Board' started by CAMSHAFT666, Dec 10, 2012.
  1. CAMSHAFT666
    CAMSHAFT666
    This is my 1928 es*** 3 winder coupe build...
    36 chevy truck frame...
    Sbc...
    4 speed...
    Blah blah blah...
    This is when i first got it home...
    The ol lady cought me making vroom vroom noises...
    the next weekend i brought this frame home...
    Everyone was telling me to just "build a frame" but i think that it takes away from the character of the car...
    Old car+old frame =cool...
    Nailhead A-V8 likes this.
  2. weps
    weps
    from auburn,IN
    good luck, looks like a good start.
    I built my frame, but like the looks of yours.
    I have a few pics of mine here floating around if you have any questions.
  3. J. Fitzhugh
    J. Fitzhugh
    Es*** cars have great style. Rich Venza did a '29 sedan in the seventies. He is on here. You should ask him the details.
  4. CAMSHAFT666
    CAMSHAFT666
    At some point sombody welded the spring hanger on...
    skinny wheel fixed it...
    got the girlfrend in the shop to help clean it up...
    blah blah blah...
    tack welded some cross members and cut the drame horns off...
  5. CAMSHAFT666
    CAMSHAFT666
    I got the rivets drilled out and pulled out all the stock cross members...
    and my girlfreind caught me again...
    Sometimes having a chick that likes to hang out in the shop can come back to bite you in the ***!
  6. CAMSHAFT666
    CAMSHAFT666
    I was trying to figure out how much i wanted to "z" the rear...
    i was worried that this wouldnt be very "traditional" but i did it with a skinny wheel and bent it with my knee. So i guess it could by a punk kid in a single car garoge "back in the day" because i just did it!
    here is how it fit...
  7. CAMSHAFT666
    CAMSHAFT666
    I picked up some 35 ford wheels for 60 bucks at the swap meet...
    So i stuck em up next to the car and did some dreaming...
  8. CAMSHAFT666
    CAMSHAFT666
    I started getting the old chevy frame all boxed and plated so i can beat the **** out of it!
  9. CAMSHAFT666
    CAMSHAFT666
    I set the body on the frame...
    i am channelling the body flush with the frame...
    its starting to take shape...
  10. CAMSHAFT666
    CAMSHAFT666
    I put the mock up engine in so i could start on motor mounts and ****** mount...
    here is the saginaw 4 speed...
    my old lady stole my car...
    But she wont make it far...
  11. CAMSHAFT666
    CAMSHAFT666
    Been getting the floors and firewall tacked in the car...
    Im not running the tunnell ram it was just sitting around so i had to set it on there...
  12. CAMSHAFT666
    CAMSHAFT666
    i used to check out your car wan i was just lurking!
    Love it!
  13. CAMSHAFT666
    CAMSHAFT666
    p.s. I MIGHT AS WELL HAVE JUST BUILT ONE AFTER ALL THE WORK I DID TO IT...
  14. CAMSHAFT666
    CAMSHAFT666
    thanx for the input! I will defenatly do that!
  15. CAMSHAFT666
    CAMSHAFT666
    Well...
    Thats where im at as of now...
    Im gonna quit ****in around and go freeze my balls off in the shop!
    Im gonna kick old man winter in the ****!
  16. BIG-JIM
    BIG-JIM
    from CT
    Looking a little too rat like for my taste but it is early in the build.:confused:
  17. CAMSHAFT666
    CAMSHAFT666
    Really? But it doesnt have rubber rats all over it!
    Hell i dont know. Its going to be chopped and channelled pretty far but other than that... It was never ment to be a r** r**...
  18. Rickybop
    Rickybop
    Cool to see a hot rod built from a less often-seen make. rr? I see no rr paraphernalia, and you didn't mention a rust finish. Engine sits pretty frickin' high though...lol. Good luck.
    <!-- / message --><!-- sig -->
  19. CAMSHAFT666
    CAMSHAFT666
    Thanks. I saw a Hudson at a car show and I fell in love with it. So when I found the es*** it was a no brainer...
    I know it's probably not 100% trad-rod but I figured maybe since it wasn't sitting on an s10 frame and wasn't apoulstered with license plates I wouldn't be condemned to hell...
    Haha!
  20. SuRfAcE_RuSt
    SuRfAcE_RuSt
    Its not uncommon to get condemned to hell on here.. Even if ur building a traditional rod :D
  21. Boyd Who
    Boyd Who
    Good on ya for saving another Es***! Will be watching the build on this. :)
  22. hoggyrubber
    hoggyrubber
    i always like the es*** builds. they always give me ideas. i have a 27, haven't started on it yet, it's all apart. have to finish the 53 hornet first.
  23. 32 hudson
    32 hudson
    Subscribed from another Es*** owner.
  24. CAMSHAFT666
    CAMSHAFT666
    i got the front end mocked up this weekend...
    and i found a 58 GMC column and steering box that im shortening and running as a cowl steering setup...
    i got it mocked into place with a 2 by 4... high tech...
  25. CAMSHAFT666
    CAMSHAFT666
  26. CAMSHAFT666
    CAMSHAFT666
    i have a set of 47? (i think) squareback spindles with juice brakes i was going to rin on this model a axle. i have never swaped spindles before. i was wondering if i can re use the king pins with the 47 spindles? everything still seems tight and they are still in the 47 axle...
