How do you correctly lower a Model A with PRE war parts?
Discussion in 'The Hokey Ass Message Board' started by JTW, Dec 1, 2012.
  1. JTW
    JTW
    What does it look like when you lower a modelA with correct period parts? Ive seen modern underslung brackets, ETC... But how would I do it if I were looking at it in my shop in 1940? Do I use a 37-42 style car rear?
    As always Thank you Fellow HAMBERS... I love to learn traditional styles, and I think you older crowd is disrespected a lot... I would have given anything to ride in 1955!!!
  2. cadillacoffin
    cadillacoffin
    beings its a model a, if you still have the model a frame or are using a model a rear crossmember switch out the a spring to a t spring. on the front, drop axle and reverse eye spring. beyond that is going to require m***aging the crossmember to allow the springs to mount higher.
  3. Rickybop
    Rickybop
    And of course, a set of 16" wheels and tires.
  4. gwhite
    gwhite
    SUPER MODERATOR
    Front suspension - 32-34 axle (1 3/4" drop), 32-34 spring perches (to maintain alignment for mechanical brakes), reverse eye spring (1" drop), #'s 2,3 & 4 leaves removed (1 1/4" drop) - total 4"
    Rear - Stock A crossmember with 1916-1927 8 leaf T spring - approx. 4" drop. If you need more rear drop you can reverse the main spring eyes or heat/bend the spring.
    MADster likes this.
  5. Rickybop
    Rickybop
    When did the "spring behind" rear axle setup come in? '41? That's still pre-war, but I doubt it got implemented until a little later.
  6. Carter
    Carter
    The spring moved to mounting behind the rear axle in 32.
    Sent from my DROID device using the TJJ mobile app
  7. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I like gwhite's answer. That seems to about cover it since guys really didn't start dropping axle's to 4" until late 40's.
  8. Rickybop
    Rickybop
    Thanks, Carter. Proof below. I couldn't remember...obviously. So the '32 thru '41 rear suspension setup would be an option if you move the Model A crossmember rearward.
  9. zibo
    zibo
    from dago ca
    You can flatten the front crossmember a little too.
    Easy to get 1" lower for a couple hours work.
    TP
  10. fiftyv8
    fiftyv8
    from CO & WA
    Also take out a couple leaves out of both front and rear springs.
    Usually two out works OK.
    Take them off the top for starters, may get a 3rd if you like the ride soft...
  11. Chris
    Chris
    On my old A roadster I used a T spring out back, and reversed the eyes on the front spring and took a couple leafs out. It lowered it to what i thought looked very period for pre-war
  12. JTW
    JTW
    Awesome answers, yes, I actually have a nice 35, I believe that is under slung, but it would require some cross member movement. Yes I've got several sets of the 16 from 35 Ford, but I really would like to stay with the original tallies! Got several T springs as well. I knew about the reverse eye deal and flatten out cross X. Rear was the concern. Like I said, I don't want a big O drop axle in the front. Another question... Did they speed hole the wishbones, visor, front axle... Etc, or will that kill the look? Real 32 grill shell I ***ume had to be shortened by 2" to run hood, and Zepher dual down draft. I guess technically drop axles were not really implemented utile post war?
    Thank you gentleman.
  13. Murocmaru
    Murocmaru
    from Van Nuys
    In addition to everything mentioned above, an old timer told me that before the war, they used longer spring shackles
  14. wbrw32
    wbrw32
    This was for the rear only....and watch for side movement on corners,,or install a sway bar. I ran 6" shackles on my 39 cpe back in 1952
  15. V4F
    V4F
    from middle ca.
    reversed eye springs with leaves taken out , 4" drop axle .
  16. Chris
    Chris
    Can't on a model A, the springs are over the axle. Any longer shackle then stock and the spring will hit the axle.
  17. Chris
    Chris
    Here is my old roadster: 32 front axle, reverse eyed spring, couple smaller leafs removed. On the rear, it was a T spring with one leaf removed. Nothing post war about the car.
  18. manyolcars
    manyolcars
    reversed eye springs with leaves taken out---of the rear???
    Do the tires hit the rear fenders?
  19. Chris
    Chris
    This is my old coupe. Same as above roadster, but it had a dropped axle...so it could not technically be pre war. A's are pretty easy to lower if you don't want it slammed.
  20. manyolcars
    manyolcars
    Does the bent spring pictured work OK? I have one on my A and suspect it causes my steering problems
  21. Chris
    Chris
    I have one under the rear of my 34 roadster and it drives fine.
  22. manyolcars
    manyolcars
    speed bumps cause my A to turn left and I feel sure all the front end is correct and in good condition
  23. brokenspoke
    brokenspoke
    You got some bump steer
  24. Chris
    Chris
    Yep, shorten the pitman arm.
  25. JTW
    JTW
    That makes sence about the leaf removals. I gues same ol question, so A stock axle with like a 2" drop is definately.. post, or is kinda iffy, or completely out as they did not do it? I would say for now Im leaning tword stock wheels white walls, Fender-less, HC head, ZEPHER dual intake, with dual Y header. The only thing I am going to do, because its hidden, and for drivability sake.. I will go ahead and add a 12V harness. BUT I will go with cloth correct wire wherever it is in view. Now when did the aftermarket dizzy come out for the A, is that pre or post.. SIGH, like I said I am so used to post that I dont have to be this picky about parts.
    Thanks guys
  26. JTW
    JTW
    i like this!!!
    1stGrumpy likes this.
  27. Angry Frenchman
    Angry Frenchman
  28. OoltewahSpeedShop
    OoltewahSpeedShop
    Yep, this is great info and all in one spot. Thanks guys.
  29. JTW
    JTW
    Any one else? got some pics?
  30. Mr.Musico
    Mr.Musico
    from SoCal
    is a 36 axle an option? Seems like it has about a 2" drop, or is it the same as a 32-34?
