Weld or buy new?(brake pedal)
Discussion in 'The Hokey Ass Message Board' started by rpkiwi, Dec 10, 2012.
  1. rpkiwi
    rpkiwi
    from Truckee CA
    Ok I have this what I think is a cast steel(maybe forged)brake pedal that was a little to long.I shortened it a little so that it wouldnt go through the firewall.I was planning on migging it,and from the pictures I have doweled it with two rollpins to give it that extra shear strength after I finish the weld.Am I being over cautious thinking that maybe I should go to a non welded flame cut shorter version.:confused:
  2. 50dodge4x4
    50dodge4x4
    Should have been a forged part, weld it and use it, providing you know how to make a good weld. If you have doubts about your welding ability, take it to someone with whom you have more confidence about welding it. Gene
  3. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Weld it up with proper penetration. If it makes you sleep better at night, add a gusset on either side of the welded joint.
  4. ct1932ford
    ct1932ford
    V it and Tig it with silicon bronze rod. Should be fine!
  5. F&J
    F&J
    I think the dowels make it weaker than a chamfered weld **** joint. Those dowels may not be a problem with the forces needed, but the dowels can't really help with shear, on that type of joint.
  6. rpkiwi
    rpkiwi
    from Truckee CA
    Thanks guys,I am capable of a good weld.Am interested to know why you would Tig though as I was going to mig but can do either.If it was just a plain old mild steel pedal I wouldn't have hesitated.Thanks Roger
  7. welding will be fine. ***uming you can lay a bead with good penetration.
  8. Blue One
    Blue One
    from Alberta
    Forget the silly con bronze and all that other stuff. Lose the dowel pins, that would just weaken it.
    V the pieces more and tack together with a Tig. Leave a gap so you can get a full peneration weld.
    Weld with ER70S-2 and when you are done smoothly blend the weld into the pedal arm with an 80 grit flapper disc on the grinder.
    It will be as strong as you will ever need it to be.
  9. Dan Timberlake
    Dan Timberlake
    I'd probably use a dye penetrant like Spot Check to look for crackers in and adjacent to the weld, and the rest of the pedal while I was at it.
    I used my Lincoln AC-225 to successfully magnetize some 1.25 inch shafts for Magna Glo inspection. That's even better better than dye pen inspection.
  10. dreracecar
    dreracecar
    from so-cal
    When shortening a peddle like that, one should shorten it from the top down and not the middle. Right now you have grain pattern and high leverage forces in the middle of the peddle that you are asking the weld to hold. If you had just "topped" the peddle the leverage force is reduced, grain is not interupted,and just dealing with a mild shear weld, then add a gusset to the corner if you are worried.
  11. Dave Zapatka
    Dave Zapatka
    Rodger That ! Not building a Spaceship
  12. J. Clear
    J. Clear
    When I did mine, I made the cut diagonal. This way I had almost twice the length of weld.
    J.
  13. rpkiwi
    rpkiwi
    from Truckee CA
    Very good point,I should have thought about that.I did it down lower so that I would have room for a couple of 1/8"dowel pins and still get good weld penetration.Do like your idea better though,especially by adding a little gusset in the corner.Live and Learn!Thanks Roger
  14. Blue One
    Blue One
    from Alberta
    For the umpteenth time, no dowel pins !!
  15. ct1932ford
    ct1932ford
    There are alot of welding rods you can use but I have had good results with cast steel.
  16. Blue One
    Blue One
    from Alberta
    Cast steel is just that, steel that has been cast rather than rolled.
    The ER70S-2 Tig wire is what we use on A106 mild low carbon steel piping for high pressure piping, an application where you will never see silicon bronze.
    For general low carbon steel Tig welding ER70S-2 is still your best choice.
  17. ct1932ford
    ct1932ford
    Well if we were welding high pressure pipe I would agree. I have found that when welding older materials and not always being 100% sure of what you are working with it is more forgiving. If you know it is low carbon steel then your choise is correct. Oh and we do agree on not using dowl pins. It is not oak:rolleyes:
  18. Morrisman
    Morrisman
    from England
    ^^ This!
