suburban suspesion
Discussion in 'The Hokey Ass Message Board' started by hdcustomizer, Dec 6, 2012.
  1. hdcustomizer
    hdcustomizer
    need your input on lowering my 1948 suburban. would like to bag it but open to anhy ideas
  2. 53sled
    53sled
    from KCMO
    Well you can't get to the rockers without a lot of fab work. what is YOUR end goal?
  3. Mr48chev
    There are tons of Mustang II crossmember setups for bags.
    If you want to spend a bit more and get a custom setup
    One of our members turns out some fine pieces. http://www.industrialch***isinc.com/
    No Limit can build you a good setup http://www.nolimitparts.com/
    Scotts Hot rods also has a good setup http://www.scottshotrods.com/
    Then there is Art Morrison who's new shop truck, ch***is and photos of their crossmember kit for AD trucks is in the Dec 2012 issue of Custom Cl***ic Trucks with the Green AD truck from Oregon on the cover.
    Other than that it is how much you want to spend as some of the above mentioned ones will run up to 3k and a basic name brand bagged MII style crossmember setup will start around 1200.
  4. hdcustomizer
    hdcustomizer
    the end result im looking for is running boards on the ground, if my budget allows. but would settle for lowering at least four inches
  5. hdcustomizer
    hdcustomizer
    thanks for the info ill check out these web sites
