I hope I know what I'm doing!!!
Discussion in 'The Hokey Ass Message Board' started by demonacm50, Dec 13, 2012.
  1. demonacm50
    demonacm50
    Starting the road to a smaller roofline. 2 inches to be exact! First time for something like this for me, so I hope it goes smoooth. Done a lot of research, seems easy enough.
  2. demonacm50
    demonacm50
    So far the cab is completely gutted. Still need to line up the door gaps prior to cutting and then install some cross bracing.
  3. Are you planning on leaning the a pillars, or stretching the roof?
    Keep us posted, looks like an adventure! :)
  4. mackster
    mackster
    nice man! take lots of pictures! where did you get your steering wheel?? I want one just like yours!
  5. demonacm50
    demonacm50
    I was initially going to three inches and keep the back window the same without leaning the pillars and stretching the roof, but I saw pics and video of a two inch chop with leaned pillars and it looks WAY easier to do. Two inches of leaned pillar might not be so noticeable. I've seen some that lean way back and I don't like the way it looks. I've also seen some chops that stretch the middle and you can see where the roof dips down at the stretch. My skillset is amateur and calls for minimal metal work. Don't want to end up with a roadster. Haven't had any cl***es, just surf the net and ask questions at different shows.
  6. demonacm50
    demonacm50
    I got mine at Moon. I have another one. Smaller and has holes on the bars instead. It's for sale.
  7. mcmopar
    mcmopar
    from Strum, wi
    I would like to here what not to do after the roof is cut off. Everyone has a moment where they say I should have done this. Looks good so far and, you learn things the way I do just ask people will try to help.
  8. Rick S
    Rick S
    Measure twice, cut once, nothing to it. How are you going to do the cut across the roof?
    Here's what I did.
      39.8 KB
      41 KB
      40.6 KB
  9. demonacm50
    demonacm50
  10. demonacm50
    demonacm50
    I'm also installing a front clip from an 84 Jaguar.
    Still need to finish boxing it in and making it one with the truck.
  11. Gulfstream87
    Gulfstream87
    Good luck, look forward to following your progress.
  12. demonacm50
    demonacm50
    More updates. Cut the roof today. 2 inch chop and leaned back the pillars.
  13. Hey demonacm50,
    Wow, that looks good so far. So you cutting the back window the same 2"?.
    Keep us posted. More pics too...!
  14. LeftCoastCruiser
    LeftCoastCruiser
    from So Cal
    Yeeeeaah...get down Demon! (can you guess the movie?)
    So far so good man, keep at it!
  15. demonacm50
    demonacm50
    Yeah. The whole top got the two inch treatment.
  16. demonacm50
    demonacm50
    Can't figure it out. Tried Googling it too. No luck.
  17. badshifter
    badshifter
    How will the windshield align with the lower opening since it didn't get leaned back at the bottom? I think you'll have a problem there. The gl*** will be kicked forward below the angled cut line of the A pillar. May want to seriously check into that before you finish weld it.
  18. Frankie47
    Frankie47
    from omaha ne.
    Cuba gooding....dog sled......nice chop in progress by the way!:)
  19. metalman
    metalman
    I'm with badshifter on this, I think you need to rethink the windshield cuts. At this point I'd make up a mock up windshield gl***, a piece of 1/4 masonite or plywood would do. Hold it up to the pinchweld and make sure the pinchweld (where the w/s rubber fits) is level and tight against the gl*** or board in this case. Easier to bend metal now the bending gl*** later!
    Pretty gutsy project for your first chop!
  20. demonacm50
    demonacm50
    Ill try to post some pics, but the pinch welds actually lined up ok. I will take your advice seriously and double and triple check it though.
  21. demonacm50
    demonacm50
    Thanks for the advice. I was planning on using some cardboard to get the dimensions of the gl***. I now think the wood would be more representative of the gl***. Might even take it one step further and actually install (temporary) the wood in the windshield rubber to see how it lines up.
  22. demonacm50
    demonacm50
    Here are some pics to show how the pichwelds are aligned.
  23. LeftCoastCruiser
    LeftCoastCruiser
    from So Cal
    Looking really straight.
  24. richie rebel
    richie rebel
    i like it,i think its going to work out great............
  25. pecker head
    pecker head
    The windshield rubber is very forgiving !
