Comet Falcon strait axle info for Autoslim
Discussion in 'The Hokey Ass Message Board' started by Judd, Jul 30, 2007.
  1. Judd
    Judd
    Autoslim asked about info on the strait axle set up on my Comet so I'm posting info here. Y'all jump in with any info you have.
    My set up is based on an Econoline axle.
    I have Streetrod manufacturing disc brake kit part#1190, calipers P# 3100, braided steel hose P# 3702-16
    front brake pads Carquest BMD 154
    78 to 83 chevelle calipers
    Carquest master cylinder P# 20-1485
    Wildwood adj. proportioning valve P# 260-220
    Stock 65 Comet steering box HCC AM 4M23B
    48" tie rod and adaptors from Speedway
    Rear brakes (Speedway)
    hats 170-0317
    rotors 160-0471
    caliper R 910-31045R GM metric 7/16"-20
    caliper L 910-31045L
    pads 919-1562 GM mSuper Stopper metric
    slide bolts 910-31099
    brakets 916-41010 GM metric brake braket
    caliper fittings 617-4132
    flex hose 910-31893
    tee, thru panel 617-4330
    nut for tee 617-6187
    clamps 910-31312
    adaptor 191-787
    More tomorrow.
  2. Chaz
    Chaz
    Isn't an econoline axle an I beam?
  3. Cshabang
    Cshabang
    how about some pics of the car too..haha, I wanna see!!!! haha
  4. dickster27
    dickster27
    from Texas
    Sure is Chaz. I'm sure this tube axle is an aftermarket unit set up for econoline spindles, perhaps?
  5. Chaz
    Chaz
    Ok, now that makes sense. Axle a speedway ?
  6. Judd
    Judd
    The axle is off e-bay from under an unfinished Falcon project. It is based on Econoline and uses Econoline spindles and springs and is cross steer. It is raining tonight and I race tomorrow so I'll try for better pics Thursday.
      53.1 KB
  7. Judd
    Judd
    Took some more shots .
  8. Autoslim
    Autoslim
    from texas
    Judd,
    Your da man! I've been carrying around the Speedway catalog for the past few days and spending all my spare time looking for FE stuff in the cl***ifieds. I also got the HotRod mag with the Mr. Rich altered wheelbase instructions. Pure sickness.
    Anyone ever see a 64 Comet Post Sedan g***er/afx/bfx? Kinda ugly, but then again I ain't cutting up anything collectable.
    autoslim
    64 Comet Post w/ a tissue box on the package tray
  9. Judd
    Judd
    Strait axle in action
  10. Judd
    Judd
    stock Comet steering box
  11. AnimalAin
    AnimalAin
    '64 Comets were a**** the baddest A/FX cars of the day. Most I ever saw pictures of were two door hardtops. The notable exception was the Sox and Martin station wagon. They had high-riser 427 FE motors, gl*** front ends, teardrop hoods, and air intakes thru the inner headlight hole.
  12. Judd
    Judd
    Found a spec sheet.
  13. Cool car. I see the pics and I start hearing FE motors reving.
    Great do***entation, too. I appreciate the part numbers and dimensional drawing.
  14. Judd
    Judd
    p***enger side hook up.
  15. Judd
    Judd
    stock axle parts.
  16. Autoslim
    Autoslim
    from texas
    Judd,
    Thanks for the p***engers side photos. Didn't know if you had a steering arm added or you grabbed the drag link for your cross steer. With the drum econoline drum brakes, it didn't look like I had room for a arm bolted to the top two holes in the spindle.
    Scored a econo axle and a 57 Fairlane 9 inch last Saturday at the boneyard. Bout had heat stroke, but was thrilled to get this project rollin.
    Thanks again, Bud.
    Autoslim
  17. John1964
    John1964
    from BC, Canada
    Autoslim,
    here some info on the set-up I put together. It is for my 64 Fairlane, which is similar to the Comet/Falcon. The stock econo axle will be a little too wide for the Comet/Falcon and will need shortening. Here are parts I used
    65 econo axle (shortened 5½ ")
    stock econo spindles (machined spindles to adapt 65-66 Mustang disc brakes).
    65-66 Mustang 4 piston KH calipers, caliper brackets, rotors and brake hoses (bearings are the same for Econo & Mustang).
    Custom made steering arms (didn't like the look of the original econo arms) Still need to tig weld on steering stops.
    stock Fairlane steering box
    stock pitman arm (modified tapered hole for tie-rod)
    custom drag link and center link (made from 7/8" 4140, 11/16-18 left & right threads machined on either side)
    moog tie-rods ES2221L & ES2223R (spindle to spindle)
    moog tie-rods ES2221L & ES416R (steering arm to box)
    moog adj sleeves ES426S
    custom made steering arm to connect RH spindle to steering box (made from 3½" X 3½" X ½" angle)
    custom leaf springs (car sits exactly 24" from center of crank to ground and axle set aT 7* deg positive caster)
    front view
    p*** side
    driver side
    side view
  18. Gasserman
    Gasserman
    from Tulsa OK
    Guys, Thanks for all the pic`s . It gives me some good ideas for my Falcon. Also appreciate the part numbers that helps alot. G***erman
  19. Autoslim
    Autoslim
    from texas
    Thanks John P...great info. I also sent you a PM.
    autoslim
  20. Judd
    Judd
    I got PMed for info on my strait axle set up. I brought this post back up so they can get the info.
  21. YocumBros.
    YocumBros.
    from Raleigh NC
    Very nice set up and craftsmanship, do you plan on using a sway bar?
    front view
    p*** side
    driver side
    side view
    [​IMG][/QUOTE]
  22. John1964
    John1964
    from BC, Canada
    Thanks, I will not be using a sway bar. Will be adding front shocks after the car is fully ***embled. Need to figure out what shock will fit and then find/fabricate shock mounts.
