1959 Ford F100 4x4 Project
Discussion in 'The Hokey Ass Message Board' started by TBUCKETMILLER, Dec 17, 2012.
  1. TBUCKETMILLER
    TBUCKETMILLER
    Just picked up this 1959 Ford F100 4x4 project. Made mistake of not looking at it before getting it. It has a little more rust than anticipated but will have to make it work.
  2. spot
    spot
    from usa
    Well it looks like it is mostly there and I've seen a lot worse. What are your plans for it?
  3. TBUCKETMILLER
    TBUCKETMILLER
    I am planning on restoring it to original condition. Just trying to decide where to begin.
  4. el Scotto
    el Scotto
    from Tracy, CA
  5. TBUCKETMILLER
    TBUCKETMILLER
    Are factory 4x4 1959 Ford F100's pretty rare. I don't see to many posted on the net. The rust is mostly confined to the floor of the cab on my truck.
  6. servi53
    servi53
    looks cool, good luck and take lots of pictures
  7. elroy
    elroy
    59 was the first factory 4x4, earlier ones were marmon-harrington.
    If you need inspiration ertl made a 1/18 die cast of that very truck
  8. 56 ford custom
    56 ford custom
    from Socal
    Bit hen truck! Wish mine was 4x4
  9. slddnmatt
    slddnmatt
    Yep first year, looks pretty damn good to me!
  10. TexasSpeed
    TexasSpeed
    from Texas
    Wish I had one too! Sure would be cool to have one for driving in the winter time.. Heck, even year round. Came across this in town a couple weeks ago..
    Found these two pictures on here..
  11. slddnmatt
    slddnmatt
    Those old highboys just scream TUFF!
  12. schutejame
    schutejame
    from london
    I am planning on restoring it to original condition. [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  13. schutejame
    schutejame
    from london
    Yep first year, looks pretty damn good to me![​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  14. 32Tudor396
    32Tudor396
    Those are cool 4x4 trucks,I am thinking about buying a 60' I found....six and three on the tree...dana 60 rear.
  15. TBUCKETMILLER
    TBUCKETMILLER
    I am going to start with trying to get the old 292 y-block unstuck and running. The guy I got it from said it ran 10 years ago so I imagine it will run again with a little work. Right now can't even turn it over by hand so need to unstick it first.
  16. TBUCKETMILLER
    TBUCKETMILLER
    Here is a pic of the inside after I cleaned up a ton of old rat poop.
  17. Theres lots of good info here on getting an engine unstuck, have fun, I love getting engine running that are stuck/not working.
    Killer truck, I have really warmed up to those years.
  18. 53olds
    53olds
    this one was on craigslist
  19. TBUCKETMILLER
    TBUCKETMILLER
    Here is a picture of my truck after a good bath. Looks good from far away but lots of rust in cab floor and around front windshield. I think the rats that were in it pooped above the headliner and it sat in there for years causing the rust.
  20. willymakeit
    willymakeit
    Not common. I think most were a NAPCO conversion.
  21. elroy
    elroy
    Napco was the builder for GM till I think 55. M H did fords from WW1 to 59
  22. Shane Spencer
    Shane Spencer
  23. Rob68
    Rob68
    My 58 has rust in the floors as well. Also look behind the fuel tank. I found a very small amount of rust there also. Lower fender rust out is pretty common on these also. Good luck with it
    Here's what the rust in my 58 looks like. (Gotta find someone who can help me with that)
  24. TBUCKETMILLER
    TBUCKETMILLER
    That rust is minor compared to the rust in floors of mine. I will get some pictures tonight. I just had my son crack open the oil drain plug and some nasty water/oil mixture came out. This truck hasn't ran for atleast 10 years. I don't know if I should just try to get it to run or just yank the engine out and rebuild it.
  25. willymakeit
    willymakeit
    Thanks for correction. NAPCO was the one that came to mind.
  26. TBUCKETMILLER
    TBUCKETMILLER
    Got the plugs out last night. Engine is stuck pretty good. Think I am going to buy some diesel fuel tonight and put down in spark plug holes and let it soak. Does anyone have a successful story they can share and let me know what you did to get your engine un-stuck.
  27. carmuts
    carmuts
    My highschoole buddy has one. I have tried to buy it many times, but he does not want to sell it. It is an original 223 4spd 4X4. It runs good, but is missing both doors. I have been hoping for a long time that he would restore it since he does not want to sell it. But much like his 73 LT Camero it sits in the weeds behind his house. Rod
  28. blucar
    blucar
    I have been messing with the '59-60 Ford F100 4x's for about twenty years, I currently have three..
    The '59 Ford 4x's were the first factory built 4x's that Ford made, except for the military units of WWII.. Prior to '59 all of Fords 4xs were Marmon-Harrington conversions.. GM used Napco conversions..
    The trucks have some very unusual features, not found on the regular F100-250-350 trucks.. The cabs have added diagonal bracing in the corners of the cab at the rear corners adjacent to the fuel tank. The front clip, core support and fenders is spring mounted in lieu of being bolted directly to the frame..
    The standard gear ratio for the F100 was 3.89, F250 and 350 are generally 4.56.. As a general rule the differentials will be Dana 44's (F100) with the front and rear drive shafts being inter-changable.. Ford did this on purpose...
    The 4x's had a long list of extras, limited slip, padded dash/visors/seat belts, (safety package) dual heaters (winter package) plus the normal custom cab features..
    All three of my '59's are custom cabs, V8, 4spd, 2spd transfer case.. My best one, pix attached, is a big window cab.. The only one I have ever seen..
    I have a lot of parts for the '59-60 Ford trucks, three extra beds, some doors, heaters, radios, delux steering wheels, etc..
    If you truck has the standard Gemmer steering gears, most of them did, you can replace the steering gears with a unit from a '59 Chevy, the Sag gears were a special option on the HD 4x's and the panel/Courier, intended for emergency vehicle conversions...
  29. TBUCKETMILLER
    TBUCKETMILLER
    Thanks for the info. It is good to talk with people that have the experience you do. I do need some front fenders. I have not seen anywhere available in the catalogs. Mine is a custom cab small window with 292 y-block, 4 speed trans. I traded my 1972 F100 long bed that has a blown engine straight across for this one. Think I did ok on the trade.
  30. blucar
    blucar
    The front fenders for the '59-60 F100/250 4x's fit the 4x's only.. The attachment bolt to the cowl is completely different from the regular pickups.. The fender has an external dip at the lower edge, a visible carriage bolt is used in lieu of the concealed bolt that comes in from the rear of the fender..
    The 4x fenders are not as prone to rust out in the lower portion like the regular fenders..
    What is wrong with your fenders? Not to many aftermarket parts are made for the '58-60 Ford trucks... The '61-66 trucks are just about as scarce, especially the 4x's..
    I have a '66 F250 4x, they only made about 2,500 of these trucks..
    I've had a big love affair with the '59 Ford pickups every since 1959, a company that I worked for gave me a new one in '59... It was a great truck.. I've pretty well had a '59 every since..
    PM me if you have more questions..
