Tig - Mig Regulators
Discussion in 'The Hokey Ass Message Board' started by Dave Zapatka, Oct 31, 2012.
  1. Dave Zapatka
    Dave Zapatka
    Why a TIG uses a Gas Flowmeter and a MIG uses a Gas Regulator ?
  2. flt-blk
    flt-blk
    from IL
    I have a flow meter on my MIG
  3. I've got one of the floating ball bearing type flowmeters for more accurate metering of gas on my MIG. All welding gas is expensive over here and you don't want to waste any. I also have a regulator.
    I have the regulator wide open and do the metering on the flow meter.
  4. nmpontiac
    nmpontiac
    from Taos, NM
    Flowmeters on both MIG & TIG here - I think they control gas delivery better.
  5. pbr40
    pbr40
    from NW Indiana
    I use a flow on both
  6. Dan Timberlake
    Dan Timberlake
    Some Very basic MIG machines come with a non-adjustable pre-set flow regulator. I think that is what the conversion kit for my flux-core Lincoln WeldPak 100 has.
  7. dad-bud
    dad-bud
    Regulator will give a constant pressure, while the flowmeter will allow you to set the volume flow.
    Regulator is kinda a must, the flowmeter is a close second.
    Pressure and flow rate are kinda related, but both is better and if you use your MIG and TIG a lot, you'll pay for the flowmeter with the gas saved.
    Cheers.
  8. Ramjet
    Ramjet
    I just purchased the Millermatic 211, so where would I find the correct flow meter to use?
