WARNING HARBOR FRIEGHT 2 Ton Capacity Heavy Duty Load Leveler
Discussion in 'The Hokey Ass Message Board' started by jimcaf, Dec 20, 2012.
  1. czuch
    czuch
    from vail az
    I had never used one before. The idea intrigued me so I got one. I hooked it up and it seemed to bind and was too high on the cherry picker to clear the core support.
    I've used it on other things but didnt like it on the engines.
    Generally I consider H/F one time use.
  2. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Same here; been using some beefy lengths of chain that I've had for years.
    Wonder how many injury and accidental death lawsuits HF has settled? Several close calls listed in this small HAMB thread alone on one product.
  3. 53sled
    53sled
    from KCMO
    You can make one yourself from USA steel. It is a fun project. I like making tools.
    Sent from a Chinese electronic device using an app developed by spies. :) Just jerking your chain.
  4. Vimtage Iron
    Vimtage Iron
    The hardware stores are loaded with cheap **** also, the Ace hardware stores here are owned by a local family for many years, their bolt and chain supplier has all the imported junk, I've asked for grade 5 bolts instead of the grade garbage and they just won't go that route, these people want to deal in the cheap import stuff, the rolls of chain also, I'd be very careful on some of that stuff.
  5. GEEZZER
    GEEZZER
    You're gonna pull an engine out with a harbor freight tool? c'mon
  6. jimcaf
    jimcaf
    from san diego
    here,s my fix,I used a big honken chain I had around I used for pulls in a body shop and a 3/8 bolt,but even with that my old faithful load leveler I built some years ago is looking pretty bullet proof.I went for the HF because I liked convenience of cranking the screw to adjust.
  7. Bigdaddyhemi
    Bigdaddyhemi
    All of the offshore stuff should be safety rated with load capaciy plates. The same as any of the north american mfg companies. OSHA regulations.
  8. Vergil
    Vergil
    USA Made http://www.norcoind.com/norco/products/model/78606.html
    chiro likes this.
  9. Nitroholic
    Nitroholic
    from SoCal
    Say "Thank you Corporate America. Thank you for trading product quality, customer satisfaction and American jobs for increased profits".
  10. I have that tool and even though it's made offshore from more than likely inferior materials, I like it and have used it many, many times.
    I did remove the handle and weld on a 1/2 x 13 nut so the tilt could be adjusted with my cordless drill.
    It's a shame that these tools are made in countries that don't require any kind of laboratory testing or need for customer satisfaction.
  11. You can't point load those things !
    Its 1000 lbs evenly loaded , build a small cradle to transfer the engines weight to the entire dolly and you'll have no trouble.
    3 SBCs, 2 hemis, 3800 sc and trans, all on a HF 1000 lb dolly with zero trouble
  12. NINE INCH
    NINE INCH
    Harbor Freight....good only for work gloves. Buy cheap, get cheap.
  13. A chain is only as strong as it's weakest link and that bolt is a weak link.
  14. ac duster
    ac duster
    have one too will swap out chains thanks for info
  15. mynode
    mynode
    The (very) last item I bought from Harbor Freight a vice. It looked identical to a more costly vice sold under a name brand and I figured that they were manufactured by the same company in China. When I received the vice I discovered that the jaws were not parallel so that I could not clamp a part in it securely without damaging the part.
    What I realized was that this vice was likely rejected by the name brand company's quality control process and was subsequently sold the HF at a reduced price to be sold to the ****ers who buy "tools" from HF.
    Dwell on this before spending your money: When you buy from Harbor Freight you may be buying the rejects from a Chinese tool manufacturer.
  16. slefain
    slefain
    from Atlanta
    Hmmm. I ******ed the engines/trans out of my O/T '90 Ranger using the 2-ton HF load leveler. I read the thread on here about the poor guy getting his hand crushed, so I was a little leery. Before I did anything I lubed the whole leveler threaded rod with lithium grease and ran the screw adjuster back/forth the whole length of mechanism. Worked pretty well. Only problem I had was the crank handle needed to be lock-nutted in place next time I use it.
  17. fsae0607
    fsae0607
    FWIW, just looked in my Machine Design handbook. A good safety factor in the case of hoisting an engine would be at least 3, preferably 5+.
    So multiply the expected weight of the engine by 3 or 5 and pick a chain and hardware to meet or exceed your calcualtion. I myself would use a 5,000 lbf chain, etc. or better.
  18. 550Coupe
    550Coupe
    You get what you pay for. I made my own and have lifted a big Olds v8 with hydro several times with no problems.
  19. jimcaf
    jimcaf
    from san diego
    550 COUPE,,,if you get a chance post a photo of your home built one.
  20. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Maybe bolt on a high rated rigging hook to sling the chain over.
  21. slammed
    slammed
    Someone build one of these levelers for a tech thread yet?
  22. Bcometfx
    Bcometfx
    from NC Indiana
    We had the same leveler start spreading open and the wheels almost came off while a 302 was hanging on it. That was scary as hell. Don't trust anything of theirs that lifts thing. Also craftsman jacks are junk. A friend had 2 blow out on him in one day. It's scary how they rate this stuff and don't give a **** if its gonna crush someone or have thing fall on them.
  23. williebill
    williebill
    Stop the Presses
    News Bulletin
    Harbor Freight stuff ****s
    "I'm shocked!" in my best Claude Raines voice
  24. swade41
    swade41
    from Buffalo,NY
    I move my cars around on these all the time, right over the expansion joints too and never had a problem.
  25. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
    this has already happened a few years back to notebooms here on the hamb some thing worse out come glad yer alright
  26. TR Waters
    TR Waters
    from Vermont
    It is funny no one admits to buying at HF ...until they have a problem.
  27. Sonicjagstang
    Sonicjagstang
    from IL.
    Thanks for sharing this. There is a lot of junk out today. Just bought a hydraulic floor jack from Napa....what a flimsy cheap piece of junk compared to the one I had in the 80's Harbor Freight= Horrible Fright
  28. Fogger
    Fogger
    I have a TD Performance Model #9099 Engine Tilter that is made is the USA. No way would I use a HF product!
    Just checked with Summit Racing, they carry the Trans Dapt Model #9099, it is also listed on Amazon and Ebay. It doesn't indicate if it is still made in the USA. So that would be important to verify.
  29. mynode
    mynode
    I don't know about that. I've run into a lot of HF fanboys who start spraying the holy water around every time someone, like me, relates a personal horror story about their Temple of ****tools.
  30. busajack
    busajack
    from wy
    [​IMG]Most folks can see that the chain is for holding up a parakeet cage.
