Behind a pile of motors, in between some Buicks, and under some tin, Model A find....
Discussion in 'The Hokey Ass Message Board' started by Nick Flores, Dec 13, 2012.
  1. Beachcomber
    Beachcomber
    from Phoenix,AZ
    good stuff! Congrats
  2. reallyrotten
    reallyrotten
    Sweet score! i wish we had cool yards in MI to find stuff like this.
  3. Elrod
    Elrod
    That is a Late 1931 Slant Window Cabriolet. Body style 68-C. Not many of those around.
    Here's what it looks like in it's original skin. :D
  4. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    You're Kidding!!! Great find!!!
  5. kiwicowboy
    kiwicowboy
    from linwood nc
    nice find,now go out and by a lotto ticket
  6. need louvers ?
    need louvers ?
    See, told ya! Late '31 cab...
  7. abone1930
    abone1930
    too cool, great find:D
  8. Nick Flores
    Nick Flores
    It's already driven a couple of restorer type guys up a wall....
    Some specs...
    31 body (as we know)
    49 or 50 Olds 303 with later tri-power set up (2-jet's)
    34 frame
    34-ish banjo rear
    40's Ford brakes
    32 grill
    I hope to get a day of work in on the old girl on Sunday. If I had it my way this would be a four day work-a-thon, but apparently there is some big holiday this weekend.
    Gotta find a cool set of headlights for this thing too...
    volvobrynk likes this.
  9. straightshooter
    straightshooter
    What a find! Would keep the olds rocket.
  10. biscaynes
    biscaynes
    sweet find! tidey it up, make it safe and drive it. :cool:
  11. woodbutcher
    woodbutcher
    :D Hi Nick.Outstanding find.Is that another of your sweet rides in your aviator?
    And guys,I know exactly where that yard is.
    It`s somewhere between the Atlantic and Pacific oceans and the Canadian and Mexican borders.Start looking.
    Good luck.Have fun.Be safe.
    Leo
  12. 300racr
    300racr
    from Phoenix,Az
    Nick, great find lookin forward to seeing it in person.
  13. Nick Flores
    Nick Flores
    I WISH I had me a WWII bomber, the B-25 in my avatar belongs to the Commemorative Air Force.
    I can't wait to bring it out and show it to ya!
  14. Hot Rod Chris
    Hot Rod Chris
    Damn I wish I could find me something like that. The only bad thing is that I wouldn't have the cash to buy it even if I found it!:p
  15. Cris
    Cris
    from Vermont
    Congratulations, Nick.
  16. broey
    broey
    awesome! picks like this are a rarity now a days... How awesome of the previous owner to part with it and let it get back on the road. I cant wait to see this car in person!
  17. LSR 2909
    LSR 2909
    from Colorado
    No pictures of this?
  18. need louvers ?
    need louvers ?
  19. Nick Flores
    Nick Flores
    But wait!!!!
    I gotta a few minutes while the "Fair-er Flores" get ready for.... well whatever it is we're doing, so here's a little update.
    You'd figure we'd be doing burnouts by now, but I'm slow and don't spend nearly as much time as I should on this thing.
    The 31's been chillin' with the Scrambler and Dave's '36 Buick Bonneville car.
    First up, the front brakes. I'll share a little of the information I learned putting these together as I go.
    Dave wanted to run some Bendix binders up front so we sourced a pair of early Lincoln backing plates. I did a search and came up with some info that led me to 1964 F250 1-1/8" wheel cylinders, PN# 364 shoes, a 12" spring kit and hardware, and 2 inch hold-down "nails". I also picked up some new wheel cylider pins. Everything was a near perfect fit, the shoes are made from very thick steel and needed a bit of grinding for the pins and adjuster to fit. Dave cut a few lightening holes in them and ground the edges flush .
    This will be a stealthy upgrade because we'll be keeping the mid 40's Ford drums.
    Dave turned them and clearanced the inner corners a bit to make room for the 12x2" shoes. I need to give these a quick 'blast and get some paint on 'em, but they're ready otherwise.
    Another shot of the brake set up and those rad headers.
    The 40's Ford rear backing plates will go back on.
    Crummy pic, but if you have these wheel cylinders....
    You'll need this kit... I got it at So-Cal here in Phoenix.
    OK! No more out of focus pictures, I promise.
    Maybe just one.....
    Neat-O Edmunds Custom Finned VC's... Look *****in' and clear the adjustable rockers.
    Here's the underside of the cowl. I wonder how long it took to drill out the tank...???
    A few more holes to make a bigger hole. This one for the clutch master cylinder.
    volvobrynk and kidcampbell71 like this.
  20. Nick Flores
    Nick Flores
    Here's some shots of the rear suspention in no particular order...
    Firt up, the "Z".
    Some of this might need some sorting out....
    The front end needs a bit of attention as well.
    So besides all that, I still need to fix.....
    this bit...
    this thing...
    these...
    Some cracked welds underneith the cut-outs...
    Make a comfy place to sit...
    And about a million other things... Gotta have this car ready for the Southwest Nostalgia Drags on March 16th.
    Thanks for following along guys.
  21. kyvetteman
    kyvetteman
    You lucky *******! And I mean that in the kindest way! Nice score man!
  22. thunderbirdesq
    thunderbirdesq
  23. Mart
    Mart
    Hey, don't get me wrong, I like the car, but I can't help thinking you need to blow it completely apart and start from scratch, using what is there as the basis of the build, but seriously reworking the more codged up areas. Some of the things in those pics look downright scary and appear to have been done by someone with not much idea or skill. A lot of that does not want preserving and should be discarded in favour of more carefully considered and well executed work.
    I may be wrong, I only have the pics to go on, if I am, I apologise.
    Mart.
    Edit: I just flicked back and it looks like your rear wheel cylinders are the wrong way round. Long shoes are to the front, which is correct but the larger bore of the cylinder should also be to the front. M.
    Hnstray and rmcroadster like this.
  24. Nick Flores
    Nick Flores
    The goal for now is to get the car safe enough to show around town for awhile, we'd like to find out if anyone remembers it before we blow it completely apart. Things like the brakes, suspention, and body mounting will be sorted out before it comes off the stands.
    And Mart, you caught me on those rear plates, I kinda cheated and mocked them up just for the pic.
  25. novatattoo
    novatattoo
    from Canton,OH
    Awesome find Nick. I stole a picture for my Facebook Ford Model A page.
    Later,Bill
  26. Nick Flores
    Nick Flores
    Its back on the ground tonight, rear suspension mostly sorted out. Still have a few welds to make it 100% done. Good ole' Need Louvers? came by and helped get the wiring started the other night. Still have lots to do, but its coming together pretty quick. Hope to be out tearing *** around town in a week or two.
    Back on the floor....
    Some radical rocker covers Dave's letting me run....
  27. 562roadster
    562roadster
    What a time capsule! Looking great. Be sure to post of video when you get it running.
    -George
  28. 48buickkid
    48buickkid
    That is an awesome find, I can't wait to hear it on a video. To the guys saying fix all the cobble forget it. Fix a few things that need fixing and leave the rest. There are tons of perfect cars why not let some of them be what they are.
  29. gnichols
    gnichols
    from Tampa, FL
    Unbelievable! Totally unreal. Your first two images, taken from above, are just wonderful. When they find our cars 500 years from now, I bet that's what they'll all look like. Too bad there won't be any petrol in the future to run them. Gary
  30. jerry
    jerry
    About time!
    Looking good Nick.
    jerry
