Hot Rods Wheel id
Discussion in 'The Hokey Ass Message Board' started by salazarich, Dec 24, 2012.
  1. salazarich
    salazarich
    Can any of you id these wheels? They are 15-1/2 and 4-3/4 five lug by five inches wide. Are they mopar, jeep, ford,fomoco, willys or gm buick, chevy , cadillac, pontiac?
  2. Texas Webb
    Texas Webb
    Gotta picture?
  3. salazarich
    salazarich
    I will post the picture of the wheels when I can get to a computer. the wheels have tabs on them as well.
  4. brad chevy
    brad chevy
    You did mean 15 not 15 1/2 didn't you.
  5. 302GMC
    302GMC
    from Idaho
    If you mean clips for hubcaps and 4 3/4'' pattern, they're '49-'53 Chev p***enger.
  6. salazarich
    salazarich
    this is the picture of a wheel. I have three of them.
  7. salazarich
    salazarich
    I can sell these treasures I need some books for this semester of school.
  8. Look like a bent Gm wheel. So I guess they would be the bent type.
    Sales happen over in the cl***ifieds by the way.
  9. salazarich
    salazarich
    they are not bent. They are wet.
  10. gassersteve
    gassersteve
    For the guy building a three wheeled car. Perfect.
  11. traffic61
    traffic61
    from Owasso, OK
    I guess the bottom of that wheel looks wetter than normal.
  12. Rocky
    Rocky
    Classified Editor
    The pin striping tells me they're 49-50 chevy p***enger car wheels. I don't think 51-up wheels had pinstriping from the factory but of course you could pinstripe any wheel. Will fit any drum-brake chevy from '49-up. Hubcaps will have to be older than '54 to fit these wheels tho.
  13. salazarich
    salazarich
    thanks for the information. These wheels can be used again, my uncle had these in his garage for at least ten years. They belonged to his dad and he had them for a few years as well in Los Angeles, California.
  14. tommy
    tommy
    Are you sure about the bolt pattern circle? The smaller holes between the lugs make me want to think that they are MOPAR which used lug bolts intead of nuts but they would be 4 1/2" bolt circle.
  15. salazarich
    salazarich
    I will measure again tom.
  16. You measure from bead seat to bead seat. They are most likely 15".
  17. Squablow
    Squablow
    Measure from the center of one hole to the OUTSIDE of an opposing hole. Not center to center, that will give you an incorrect measurement.
  18. salazarich
    salazarich
    I took some more measuremnets.
      330.8 KB
      327 KB
      83.7 KB
      425 KB
      231.8 KB
  19. F&J
    F&J
    looks like a 5" bolt circle, Olds, Pontiac...must be more, like Packard...
    16" dia x 4-3/4" or maybe 5" width, from what I can see.
  20. chris' 38
    chris' 38
    looks mopar. i had a 47 plymouth with the same pinstripe
  21. salazarich
    salazarich
    There was a pontiac in the family at one time.
  22. Buick was 5x5 with 15" wheels using lug bolts through '58.
