Nitro And Superchargers!
Discussion in 'The Hokey Ass Message Board' started by 38FLATTIE, Dec 27, 2012.
  1. 38FLATTIE
    38FLATTIE
    from Colorado
  2. oj
    oj
    Now, we're talkin! I can't give advice other than take a lot of spare parts and hold on!
    Well, what about your ignition? Magnetos are very good, like an MSD but i'd be looking for a MSD 10+ box, coil etc They are hard to find, MSD quit making them, but they are wicked powerful and tuneable. I think Willie Glass used one. I've used them on tubo & nitrous drag cars and they will light off a heavy dose with lots of turbulance and no unobtanium spark plugs - off the shelf autolite racing or ngk.
    But, they be hard to find. They get snapped right up if somebody cuts one loose, i hear they are going for over $1K.
  3. gas pumper
    gas pumper
    Steep costly learning curve is what I've been told.
    Learn an alcohol setup first and then sneek up to 25%. After 25% everything changes and you really need someone with years of experiance to help to keep the damage down.
    I'd be running alcohol first and maybe that's enough to solve the power problem.
  4. dreracecar
    dreracecar
    from so-cal
    Rule #1
    " THOU SHALL NOT BE LEAN "
    Rule #2
    " SEE RULE #1 "
  5. spot
    spot
    from usa
    we used to run alcohol and 5% pop in my brother's racing cart. Needed to keep a spare cranks around on race day. No other experience with real motors and nitro.
  6. Ahhh,,,,,POP,,, now that is an old term,,,a cool old term.
    They say when you get to where you can light 100 dollar bills and not flinch,,then you are ready for fuel !
    Tommy
  7. 38FLATTIE
    38FLATTIE
    from Colorado
    We'll be running a crank trigger, HEI, boost referanced MSD box, etc.
    We'll be trying to stay on lower levels of pop-just enough to raise us from 570HP to 800HP.
  8. fenderless
    fenderless
    from Norway
    Buddy, you know that I'm also learning, but I have gotten the same advice as Gas pumper said here. Tune it on Alky, then try with a 25-30% blend. Less meens you have to lean, more enritchen. It's also said that with 25% you don't have to do anything with the setup if it runs correct with alky.
    With the flow mods. etc. that you will do and with straight Alcohol a litle more boost, I wouldn't be supprised if you see 700+HP!!:)
    Kjell
    Taildragger&fenderless
  9. afaulk
    afaulk
    Rule #3 Adding fuel (which is carrying an extra oxygen molecule) can contribute to a lean condition, all other things being equal. Hmmmm, Confucious say WTF........over.:confused: For questions, reference Rule #1 above!
  10. ibuild
    ibuild
    i like what yall are doing and wish you luck i know nothin about that stuff, just gas with a little racing fuel
  11. khead47
    khead47
    Get more money!!!!!
  12. blackZ
    blackZ
    from indiana
    I scaned through your origional thread but didn't see if you were using carbs or if it was injected. I'll assume you're using gas now and with some math you can get pretty close. The only reason I would use a lower percentage (less than 80%) even to start with, would be if your fuel system couldn't flow enough. Then you could taylor your percentage to what you can flow. It's not the percentage that will get you introuble, it's the volume. It's far easier to set the fuel system on kill and leave it alone, then use timing to calm it down or step it up.
    Before I too much farther, tell us what your existing combo and tune up is on gas and we can go from there.
    There seem to be a lot of myths and misconseptions about nitro going around, but with some solid science and math it's not as mythical as it appears to be.
  13. Locomotive Breath
    Locomotive Breath
    from Texas
    I think you will be surprised at how much more power just going from gas to alky will make. You can spin the blower a little harder and add some port nozzles if you still need more power. Have you given much thought as to what are you going to do with the intercooler? It won't be needed anymore either.
    Nitro is fun, but its hard on parts, and flathead Caddy parts aren't easy to come by.
  14. 38FLATTIE
    38FLATTIE
    from Colorado
    We currently run a racing mag, locked at 26 deg, an Enderle bug catcher with 26 nozzles, Hilborn 1/2 size pump, and a 105 return jet at 14.7 psi boost. That combo produces 570 HP, and 544 ft/lbs torque at 5500 RPM.
    We'll have 2 tunes- the current obe for the gas classes, and the HEI setup for fuel. WE'll continue to run the chiller- may not help with fuel, but it won't hurt us!
    We can go straight alcohol, and spin it harder- in fact, we'll tune it like that on the dyno. I doubt, though, that alcohol alone will move us from 570 HP, to 800 HP.
    So, a little POP in the tank will be necessary!:eek:
  15. H.G. Wells
    H.G. Wells
    This is the guy I go to for fuel injections advice. Look for his section Nitro Notes.
    http://fuelinjectionent.com/
    As others have said get more money. You will break stuff and the nitro itself is expensive. I tune a blown alky boat and the owner (brother) wants to see how fast he can go with an iron block BBC on nitro.
    Much carnage is expected.
  16. blackZ
    blackZ
    from indiana
    Do you have a flow sheet for the pump or know what the gpm @ a specific rpm is?
    Nossel pressure?
  17. dragsled
    dragsled
    from Panama IA
    Buddy like has been said above Lean is BAD Tim Jones I sent you a PM
  18. blackZ
    blackZ
    from indiana
    Lean or rich isn't good, but don't you think it's better to burn something than to have it expload?
  19. Spud Miller knows his stuff.
  20. dragsled
    dragsled
    from Panama IA
    Need to find the happy medium:) , Worked on a lot of cars that didn't try to kill themselves every pass, it's all about getting a good tuner , Me, I was a diver , mostly fixing what a bad tuner can do:eek: Tim Jones
  21. Jimmy2car
    Jimmy2car
    from No. Cal
    I would contact Flathead Jack. He runs his dual engined flathead dragster on 94%.
    I have no idea what differences would be necessary with a supercharger, but wouldn't think too much.
    Too bad John Bradley is no longer with us. He was the flathead nitro master
    Jim
  22. Locomotive Breath
    Locomotive Breath
    from Texas
    Just curious, does adding, lets say 25% nitro move you into a faster class at Bonneville? Do the rules differentiate between a car running 25% and a car running 75%?
  23. WhitePunkOnNitro
    WhitePunkOnNitro
    from Middle Tn
    Rule of thumb is double the volume from gasoline to alcohol, and then double it again for nitro. The optimum amount of lead you can run is more or less dictated by bore size (ie. 4 inch bore will take 40 degrees the same way a 4.25 will take 60). Exhaust valve opening point is the key to making power. The longer you hold it closed, the more power you're gonna make...too long and you run into bottom hole detonation.
    The whole thing is super load sensitive. Engine will pick up and drop cylinders based on the amount of resistance the crankshaft sees, and the engine does not care if the difference is through weight, traction or aero.
    Your initial tune-up should have zero fuel returning to the tank...only return it to the tank after you've tried to burn it with load first. Higher percentages are easier to tune and keep clean than lower percentages. You're less likely to break shit at 80% than 30.
    Plugs only tell part of the story, learn to read the top of the pistons and cylinder walls. When you click the motor at the end of a run, everything uner the heads should be wet and oily.
    Treat the Bitch-Goddess Nitro with care and respect, and she'll be gentle as she rips off your face. Have fun with the sickness....
  24. 296 V8
    296 V8
    from Nor~Cal
    Probably no help but …… I was once told the blowers just there to push the Nitro out :D
  25. 38FLATTIE
    38FLATTIE
    from Colorado
    Nozzle pressure with gas was 90 psi. I'm sending both pump in to get flowed, as I have no numbers now.
    Thanks Tim- I'll try and call you today or tomorrow.
    Thanks for the info!
  26. WhitePunk knows what he is talking about,,I remember him from a long time ago. A racer,,,magazine guy,,from far away.
    Now he sells fuel,,,,,so to speak,,,LOL.
    Tommy
  27. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    You could optain the HP desired w/ nitrous........it would be cheaper all the way around, unless the rules do not allow it....It has been around longer than most would like to admit.....Ran it on my six-two 94 carb setup...had 12 jets in the carbs to get right and another 12 jets to get right in the nitrous system in order for them to work in concert and make the most power w/o going pop another way.........Doing it this way can be as catastrophic as running nitro by making the wrong move as well.........Littleman
  28. Before you put the engine on nitro and make a pass, buy a good pair of fire proof underwear............. ): That shit will burn you up if your not veeeeerrrrryyyy careful.
    Speaking from experience.
  29. 38FLATTIE
    38FLATTIE
    from Colorado
    There's a thought!
    No carbs though- how hard do you think it would be to set up with a Enderle bugcatcher? It is legal in the fuel classes.
  30. Locomotive Breath
    Locomotive Breath
    from Texas
    It wouldn't be hard to do. In fact someone even used to make a nitrous plate that was sized for a bugcatcher opening.
