HEI condensor ?
Discussion in 'The Hokey Ass Message Board' started by ago, Dec 29, 2012.
  1. ago
    ago
    from pgh. pa.
    Which terminal on the HEI module does the condenser connect to? What is the purpose?
    Ago
  2. GREENBIRD56
    GREENBIRD56
    from Tucson, AZ
    Goes on terminal "C" which connects to the primary lead of the coil.
  3. CutawayAl
    CutawayAl
    from MI
    The purpose of the condenser is to prevent electrical interference generated by the ignition system from effecting radios, tape players, etc. It is not needed for the engine to run properly. For the same reason, it's common for the output of the alternator to have one too.
