Best Intake for a Ford 300 six
Discussion in 'The Hokey Ass Message Board' started by jack orchard, Dec 29, 2012.
  1. jack orchard
    jack orchard
    Gentlemen: I would like to run an Autolite 2100 2 barrel carb (356 cfm) on my stock 300 six. What would be the best intake manifold to use with it? I plan to use split EFI exhaust manifolds with true dual exhaust. Also, i am open to suggestions for a low RPM torque/good-mileage cam. Thanks to you all for your input....jack
    Happy New Year!
  2. carbking
    carbking
    I used an Offy with a Carter 9400s four barrel on mine. REALLY improved power and fuel economy over the Holley 1 barrel.
    Jon.
  3. jack orchard
    jack orchard
    carbking: thanks for your response. 400s Carter is a rare carb, isn't it? I like the size (CFM) of it. When you say Offy, do you meam the C-series? thanks again,...jack
  4. carbking
    carbking
    The 400 CFM Carters are available. You can use either 9400s or 9410s. The 9410 has an EGR port and a plug if you don't need the EGR port; otherwise identical.
    I don't remember the part number or series for the Offy. I just called the speed shop and asked for an Offenhauser intake for a 300 CID Ford 6.
    Jon.
  5. FrozenMerc
    FrozenMerc
    I used the Offy Dual Port intake with a Holley 500 cfm 4-barrel. The 3x2 Hedman Header and Comp 270H Cam really caused the old 300 to come alive. I also put a 1 inch phenolic spacer (not shown in the pic) under the carb in order to gain linkage clearance.
  6. FiddyFour
    FiddyFour
  7. jazzbum
    jazzbum
    The Autolite 2100 is a fantastic carb, and I know from experience that those work great over a wide band on the small ford sixes--200 cubes--but I think a 300 is going to be underfed on 356 cfm. Unless of course you don't plan on any high-RPM use (over, say 3500 revs), in which case it won't matter.
  8. 55willys
    55willys
    I ran a 300 with a Clifford Research intake and headers. I ran a Holley 4 barrel 425 cfm carb from a T-Bird. It really livened the engine up and got some better mileage. You have to consider that the 6 is only 2 cubes smaller than a small block ford 302 so you should be able to do the same things to your 6 as a V8.
  9. Kinky6
    Kinky6
    If he doesn't reply to your post, you might want to send a PM to The Frenchtown Flyer. He knows quite a bit about the 300" 6 cyls.
    Later, *****6 :cool:
  10. jazzbum
    jazzbum
    Nevermind, you do want low-rpm. In that case, you can't beat a 2100. Check clifford performance for an intake, they make beautiful stuff.
  11. sunbeam
    sunbeam
    Jack you want to run a manifold that is split front 3 back 3 thats like using a 180 degree manifold on a v8.
  12. CTO
    CTO
    For low RPM the Offy dual port is good. It splits the primary and secondary on a 4bbl.
