1932 Ford help needed!
Discussion in 'The Hokey Ass Message Board' started by swingkingvintage, Dec 30, 2012.
  1. swingkingvintage
    swingkingvintage
    Hey guys I need a little help!! I'm building a 1932 Ford ch***is and took it apart about 5 years ago and now putting it all back together. On the front wishbone radius ball is there 1 or 2 caps?? Model A's have two I can only find 1 that I took of the frame.Does this 1 and only cap just bolt to the frame? Any help would be great.
    Thanks,
    -Mike
  2. got a 32
    got a 32
    Mike, the wishbone ball only has one cap .cheers David
  3. Floorboardinit
    Floorboardinit
    Well, if you run a dropped axle they used to make spacers that can fit under the cap to keep the wishbones from hitting the frame rails. Thats all I can think of that might give you the impression theres two parts. JohnnyA
  4. Bud Crane
    Bud Crane
    A dropped axle dosn't bring the wishbone closer to the frame. A model A crossmember in a 32 frame will bring it a little closer.
    Stan
  5. Floorboardinit
    Floorboardinit
    Ahh...yeah I guess I was thinking of it wrong. I finally found the photo of the spacer. I dont think anybody makes em. JohnnyA
  6. tommy
    tommy
    This is probably a spacer to clear the starter motor on early OHV swaps.
    An original 32 Ford has only one cap.
  7. swingkingvintage
    swingkingvintage
    Thanks for the help guys!!
  8. HOTRODPRIMER
    HOTRODPRIMER
    Tommy nailed it,,the spacer was for starter clearance. HRP
  9. I have a couple of those spacers and now I now what they are for.
    Tim
