Degreaser tank idea needed ?
Discussion in 'The Hokey Ass Message Board' started by Frenchy Dehoux, Dec 29, 2012.
  1. Frenchy Dehoux
    Frenchy Dehoux
    I am thinking on building a tank to put various greasy parts in to clean. So that I do not have to pay someone else to clean them for me. Can you guys show me what you are using to clean your greasy parts. If you have a tank that you build that is doing the job for you. I was thinking a tank that would have various pipes with holes at every few inches and having a fitting that you could install an air line to it with an adjustable valve to give more pressure to clean the parts that would have more grease or adjusting it down for the parts that are not as bad is there such a cleaning tank that is design to do the job. I remember back in the 70's we had a tank similar to this to clean parts.
    Thanks
    Frenchy
  2. Mike Miller
    Mike Miller
  3. SloppyEggs
    SloppyEggs
    Hey, That's a good idear :)
  4. kennkat
    kennkat
    After my last divorce and the subsequent liquidation of my business ***ets (including a hot tank, jet washer, etc...) I needed a cheap way to clean parts. (yea she kicked my *** in court!) So I came up with this stainless steel tank with 30 gallons of "Purple Power" straight to clean engine blocks and the like. The tank was a "Hydro Therapy" unit so it has a 110v heating element, but I only use it in the winter. As you can see by the pix the "Purple Power" works fine when kept about 80 or 90 degrees... Usually 24 hours is plenty. I pressure wash after with cold water and keep it covered to prevent evaporation. Xlnt with alloys too...
  5. kennkat
    kennkat
    Yes, I owned one of those tanks between 1989 & 2001, and it came with a "rinse booth" also. Used it daily in a 2 man machine shop. Was made by the "GUNK" company. The aerator was a worthless deal, never really helped. Heat & the right chemicals are MUCH better options.
  6. silversink
    silversink
    Goodwill here I come
  7. kennkat
    kennkat
    :eek: Oops, almost forgot..... I picked it up at a salvage yard in Madera, Ca for $50... :D
  8. maddog
    maddog
    from So Cal
    Purple power? thats it? straight or deluted?
  9. usa1
    usa1
    Pick your tank of choice and a way to heat it. The hotter the better.
    For ferrous metals only (steel, cast iron) use crystalized Draino, otherwise known as sodium hydroxide, lye, and or caustic soda. This is the same stuff that machine shops use in their hot tanks for ferrous parts. Mix 1 can of crystalized Draino per 10-20 gallons of water. Do not put aluminum parts in this solution as it will eat the aluminum and also ruin the solution. This also goes for cam bearings and any other non-ferrous metals.
    If you have a gas tank that has years of old gas and varnish in it, fill it with hot water and add a can of crystalized Draino and let it soak overnight. You will be surprised as to how clean it will be when you rinse it out.
    If you want to clean aluminum in the same tank you will have to change out the solution for a detergent like Purple Power or the likes. You can also purchase specialized detergents from Hotsy or Landa just for non-ferrous metals, but they will be spendy.
  10. kennkat
    kennkat
    :eek: Sodium hydroxide is VERY DANGEROUS and HIGHLY TOXIC to our environment :eek: PLEASE be carefull!! I have been "doing this" professionally for near 40 years now and though that was "the way" IT IS NOT FOR NOVICES... in my opinion. How can you argue with the results clearly shown in my pix?:D:D:D"Purple Power" WILL do all, nearly as good... Want more cleaning power?? Heat it to about 120/130 degrees....:D
  11. mustangdug
    mustangdug
    I got an old solvent tank for free at a swap meet, it worked too! I fill it with the degreaser from Harbor Frieght and I put a hot plate under the tank against the bottom with a peice of 1/4 alum plate between the two to help transfer the heat. Works great for degreasing and cleaning small parts in a basket and it circulates too!
  12. Mike Miller
    Mike Miller
    Totally agree, the stuff is a major pain in the *** for shops an the home hobby guy. Kind of a detailed process to dispose of responsibly and legally.
  13. lawman
    lawman
    That is very good info Guy's !!!! Thank's
  14. usa1
    usa1
    Dont want an argument but here are some facts.
    The major ingredient in Purple Power is sodium hydroxide, also known as NaOh, Lye or caustic soda which is why it cleans so well.
    Most all hosehold detergents including bath soap have sodium hydroxide in them. The key ingredient in soap making is sodium hydroxide (lye).
    Sodium hydroxide (lye) is used in the commercial preperation for cleansing fruits and vegetables that we consume on a daily basis, not to mention other foods.
    If you are contemplating needing several gallons of solution for a hot tank then you would be money ahead to mix up your own solution of caustic soda using crystalized Draino as I posted above.
    NOW...I would hope that anyone planning on building a hot tank would have the common sense to keep it covered and away from children and pets, and use gloves and eye protection.
  15. roughneck424
    roughneck424
    Don't use the wife's dishwasher.
  16. bigblock69n
    bigblock69n
    I use a 55 gallon drum cut in half with an electric frying pan under it to heat it i set the heat control and use either dish soapr an industrial cleaner depneding on the material. I use an old crock pot for small parts or carburators.
  17. kennkat
    kennkat
    Really? Show me please -
    http://www.clean-rite.com/msds/Purple Power 2010.pdf
    http://landjsupply.com/msds/1032 Purple power.pdf
    http://www.paynesmarine.com/do***ents/CaptPhabPurplePowerCleaner.pdf
  18. kennkat
    kennkat
  19. Smokin' Joe
    Smokin' Joe
    Sounds like the voice of experience :D
  20. 28dreyer
    28dreyer
    from Minnesota
    Right, but use your own dishwasher.
    A production engine rebuilder I am familiar with incorporated one in his facility for small parts. No diferent than a Jet Spray washing cabinet only smaller.
  21. usa1
    usa1
    FROM PURPLE POWER PRODUCT LABEL:
    Purple Power Concentrated Industrial Strength Cleaner/Degreaser is non-abrasive, non-flammable and biodegradable and phospate-free.
    DIRECTIONS: 1) Test an out of sight area to determine surface acceptance and colorfastness to avoid damaging surfaces, especially on aluminum, painted surfaces and fabrics. 2) Wear rubber gloves, protect eyes and skin from direct contact. Use with adequate ventilation. 3) Cover surface with Purple Power allowing time to dissolve dirt and grease. DO NOT allow drying on surface being cleaned. 4) DO NOT use on exterior car surfaces, gl***, painted surfaces, or wheel rims.
    INGREDIENTS: Water, Sodium Hydroxide, Sodium Metasilicate, 2-butoxyethanol, and surfacants
    MANUFACTURER: Aiken Chemical Co., Inc., Greenville, SC
    <TABLE><TBODY><TR><TD height=10></TD></TR><TR><TD><TABLE><TBODY><TR><TD vAlign=top><TABLE><TBODY><TR><TD vAlign=top>
    MSDS </PRE></TD><TD vAlign=top>: </TD><TD>
    PURPLE POWER CLEANER/DEGREASER</PRE></TD></TR><TR><TD vAlign=top>
    CAS </PRE></TD><TD vAlign=top>: </TD><TD>
    1310-73-2
    111-76-2</PRE></TD></TR><TR><TD vAlign=top>
    NAME </PRE></TD><TD vAlign=top>: </TD><TD>
    sodium hydroxide (cercla)
    ethanol, 2-butoxy-; (polysolve eb)
    surfactant
    alkaline; (other alkaline ients)
    </PRE></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE></P>
