There's obviously a problem here. 5 threads a week would cons***ute a problem. Did you read the sticky
Read this one that says > Can't Reply To Cl***ified Ads? Mix up extra will you. I enjoy following these.
Probably the first one..... you can go ahead and ignore that sticky completely..... the one ***led "Can't reply to cl***ified ads?", that one..... go ahead and ignore that.....
Please read this link and you will find your answer..................... http://www.jalopyjournal.com/forum/showthread.php?t=699639 Moderator
In retrospect it might be one of the better ideas,,with the 3 day bump rule some post stayed at the top of the page while others were lost in the twilight zone. HRP
