Features Model A on 1932 frame picture thread. All bodies.
Discussion in 'Traditional Hot Rods' started by Hitchhiker, Jan 1, 2012.
  1. zgears
    zgears
  2. Mr.Musico
    Mr.Musico
    from SoCal
  3. hotdamn
    hotdamn
    Zgears, again words cant do your roadster justice, that thing is rad!!!
    what did you use suspension wise?
  4. hotdamn
    hotdamn
    I found a picture of this guy on the interwebs earlier, I love the stance!
    Oldbill51 and K.L like this.
  5. scootermcrad
    scootermcrad
    I'm with you, Del!
    Anyone have anymore pics of this? How about a straight on side profile shot of this car? Details??
    How about some more profile shots of 30/31 coupes on 32 rails?
  6. jackandeuces
    jackandeuces
    One that we just finished....
  7. Justin B
    Justin B
    Just finished this one a month ago
  8. zgears
    zgears
    Thanks. I've got a stock frame with model A rear cross member. 4" dropped front axle. reversed eye springs. front tires are the same size as stock 40' Ford 16x6.00. wishbone is unsplit original 32 ford
  9. 63dan63
    63dan63
    B4 and after ch***is change ...
  10. Junk Hunter
    Junk Hunter
    from The Ozarks
    I agree..here's one I'm working on.
  11. Mo rust
    Mo rust
    Here's mine in line at the Hamb Drags
    Kan Kustom likes this.
  12. YAPP
    YAPP
    Junk Hunter,
    Do you have any more pics of your truck? I've got a 32 ch***is and I'm partial to trucks but I haven't seen enough 30/31 P/U on 32 ch***is combos yet.
    Thanks, Terry
    Sorry for the distraction...now back to the thread.
  13. Junk Hunter
    Junk Hunter
    from The Ozarks
    There are a few pics of the truck on my build thread: http://www.jalopyjournal.com/forum/showthread.php?t=668482
    I've only seen a handful of 30-31 pickups on '32 rails and most of them have used the small model A bed. Although some look good, getting that smaller bed to look right over a '32 frame is hard to pull off in my opinion. I think the key to getting the proportions right is to use a wider/taller L'31-'34 bed in back.
  14. Dusty56
    Dusty56
  15. Harms Way
    Harms Way
    We have to raise the rear back up the 2" and change the front wheels.
  16. Brog
    Brog
    I never thought a cream/yellow colored car could look so vicious! Awesome
  17. Jack Luther
    Jack Luther
    Mine is in my avatar.
  18. Mr.Musico
    Mr.Musico
    from SoCal
    bttt for a great thread..any more?
  19. novatattoo
    novatattoo
    from Canton,OH
    Here is mine from about a month ago. It's all apart again. Later, Bill
  20. Steadfast mfg
    Steadfast mfg
    [​IMG][​IMG]
    This is or latest & its equipped with our Steadfast Mfg. sub rail kit
    to put a Model - A body on Deuce rails .
  21. Mr.Musico
    Mr.Musico
    from SoCal
    mine again, a little further along.
    Hotrodmyk likes this.
  22. speedy383
    speedy383
    [​IMG]work in progress.
  23. Mooseman
    Mooseman
    Has anyone modified the bottom of the body to follow the frame like the 32 does?
  24. FlatheadRoadster
    FlatheadRoadster
    from Sweden
    if you mean bottom of body or subrails to follow the frameline?
    go to my profile and check my album 28 roadster if you want to see the subrails and floor
    to follow the 32 frame.
  25. Mooseman
    Mooseman
    I was actually meaning the bottom of the cowl, doors and rear quarters but cool.
  26. FlatheadRoadster
    FlatheadRoadster
    from Sweden
    but you have to cut the bottom of the cowl to make it
    fit the kickup in front of the 32 frame.
    doors and 1/4 panels fit good.
  27. Mooseman
    Mooseman
    No no what I meant was that if you sat a model a body on the ground it would sit flat front to back, where as on a 32 it would rock as the bottom of the body follows the sweep of the frame.
  28. ImageUploadedByTJJ1365234860.293797.jpg friend of mine kelly odonnel from auckland nz 390 caddy 5 speed manual quickchnage etc
  29. frenchjack
    frenchjack
    from france
    pre-***embly, 3/4" front body lowered
  30. Mo rust
    Mo rust
    I shortened the back of my 30/31 roadster to fit on a stock dimension 32 frame and have room for a stock 32 tank under it. I took off the heavy metal piece that goes along the bottom of the back of the body which gained a couple inches and then I put reproduction corners on the body, splitting them and installing them a couple inches higher than stock. I then rebent the panel under the deck lid to match the body line and make it shorter. There was even enough room for a working rumble seat. I'm building a 29 with a buddy that we ware planning to do the same thing. It looks like it will be easier on the 29 roadster because there are fewer body lines on the rear edges to retain.
    Jr. Fueler likes this.
