I've checked the archives and couldn't quite come up with an answer. Is there a speedo cable, aftermarket or otherwise, that will work with a '51 Ford speedo and hook up to a TH350? Thanks in advance
Stock one if it is long enough should work ,otherwise get one from a late60s early 70s ChevyPU. Those come in2 different lenghts as I recall.
I had one made to length for mine. There should be a shop near you that still fabs them. The place I went to here deals in truck parts and makes drive shafts it is Fleet Pride. I don't know how far they extend around the country.
Lokar makes a u cut to fit kit. SP-1500-U108 fits GM trans to 3/4-20 speedo. This is what the Tech guy at lokar said to use. Same kit I used for T5 manual to ford speedo in a 1950 and I am doing a 1949 now.
