Projects Why do projects always snowball
Discussion in 'The Hokey Ass Message Board' started by junkyardjeff, Jan 4, 2013.
  1. junkyardjeff
    junkyardjeff
    I decided to remove the modern stereo from under the seat into a gutted 8 track player under the dash in my 55 Ford,the seat had to come out to remove the stereo and then I noticed the pile of rotten foam under the seat. There are broken springs in the drivers backrest so this weekend I will be on the hunt for a 4 door seat to get the springs out of,I was going to fix the springs and add new foam to the seat and reuse the covers but being 57 years old they need attention so I need to make a decision. I dont want to do the whole interior right now but if I redo the front seat the back wont match,I want to s***ch up the seats myself but it would be faster to get covers so I am thinking about installing the extra front seat for now and seeing if I can find some material that matches and redo the seats this winter.
  2. 60srailjob
    60srailjob
    from nowhere
    HA! I know not funny.... I think its suppose to be that way......it always is for me....
  3. dana barlow
    dana barlow
    from Miami Fla.
    My Dad in 1954 told me don't open a can of worms if your not going to use them all:eek::cool:;)
  4. fastrnu
    fastrnu
    from shelton,wa
    Its just the way we are wired. We are car guys. If we dont like it we jump in and get after it. We get done and dont like how it came out we do it again.
  5. 55willys
    55willys
    They are always worse than you think. Just ignore it and you will forget about it. unless you are like me then you can't stop till you have fixed everything (ie blow the car apart start over) spend thousands of dollars countless hours and maybe get your car back together in 5years.
  6. 2 yrs. ago I pulled the C4 trans. out of my non-HAMB friendly car for a T5 swap. The "While I'm here" that ensued included pulling the entire interior including the dash and steering column. Installing all new sound deadener and insulation. Rewiring the dash and replacing the ignition. Then, because everything was apart anyway, I replaced the stereo and speakers. HEY! Long as it's this far, right?
    The transmission swap did wonders for the interior. :rolleyes:
  7. junkyardjeff
    junkyardjeff
    I am glad I picked up a extra front seat so I dont have to rush the repair to the seat and can drive it,after 3 trips to Florida fighting numb legs from the lack of foam in the seat and springs poking me in the back its time to fix it.
  8. Elmer Rodger
    Elmer Rodger
    from San Diego
    my Ol' lady is always asking me the same thing
  9. DadsBlueFord
    DadsBlueFord
    from Hayden, ID
    Oh man, I've got the mother of snowball projects. I was just going to rebuild the 8ba in my '50 Fordor. In the process of pulling the motor and trans, found a huge mess of rust in the floor that I didn't know was there. Well long story short, I go from this:
    To this:
    Body's going to come off the frame once all the rust and old-***, piss-poor damage repair is done.
  10. junkyardjeff
    junkyardjeff
    I am stopping at the seats but that is what I am saying now.
  11. falconsprint63
    falconsprint63
    from Mayberry
  12. 60srailjob
    60srailjob
    from nowhere
    his law ****s....
  13. Along the same lines, I always wonder why I usually have to take 20 tools out of the toolbox to remove one bolt? Nothing is ever easy.
  14. chopped
    chopped
    What do ya think they make Mexican blankets for?
  15. LittleBritishCar
    LittleBritishCar
    from Napa, CA
    Tell me about it! I bought an old MGB that I intended to paint flat black and have on the road within a week tops. That was nearly two years ago. It is now a bare shell that is getting a Camaro V6 and T5 powerplant.
  16. bsa_bob2
    bsa_bob2
    Man if i lived by murphys law.i'd probably have killed my whole family fooled with the next door neighbors wife and beat my kids. Damn good thing i don't believe in murpys law.Build, repair, change. then do it again! Next time you see a kar that looks bettr away you go again..Its called "hotrodding at its finest"and we will probably do like this!........... til they put us in a box.
  17. junkyardjeff
    junkyardjeff
    Mexican blankets will be covering the temporary seat,the original will be reupholstered. I upholster for a living so its time for a nice seat for me instead of customers.
  18. black 62
    black 62
    from arkansas
    funny ..we are looking for something to drive and end up with something to work on!!!!great car advice never take it down as long as it is a driveable car---i never follow it but it is good advice
  19. junkyardjeff
    junkyardjeff
    Now that winter has arrived in Ohio its time to do the repairs that are needed but dont want to get carried away,I still need to track down a valvetrain rattle in the 55 and put a new spindle on the 37.
  20. fastrnu
    fastrnu
    from shelton,wa
    Yeah OK Sure Gotcha! We're here for ya brother! Post up later and let us know how it goes. Keep coming back it works!
  21. When I did the motor swap in my '50 Chevy it was supposed to be quick and get it running... eventually the whole front clip came off, I was wire brushing and painting it and seeing more stuff I could do while I was at it.
  22. Jalopy Joker
    Jalopy Joker
    "This Will Be Easy and Cheap" - HA!!!! my wife has a good laugh every time I buy a good quality part made for my ride that should just bolt on and I end up cutting, grinding, bending, etc to make it fit. sometimes end up buying another part to replace the "new" part.
    so, do you have a Y-block in the '55? they are known for not have a proper oiling system for upper end. why you will see copper tubes running across top of motor to valve covers..
  23. 40FordGuy
    40FordGuy
    Yep !!! Always happens that way..... Which is how I ended up with a running pickup, as well as 2 "parts cars".........
    4TTRUK
  24. S.F.
    S.F.
    man, to be honest...i'd just leave it alone...It looks great, and as long as its still comfortable to sit on I'd just go with it.
  25. '51 Norm
    '51 Norm
    from colorado
    Why do projects snowball? I don't know but I live it.
    This weekend I went to the local pick a part looking for a battery cable. I came home with a radiator? It don't even look the like a battery cable but I'm thinking that the radiator will go nice in my '51.
    Naturally while there I saw an engine that I just have to have. But the barn is full and the new shop isn't done yet.
    Typical.
  26. 49ratfink
    49ratfink
    went from a quick buy and sell to a blown headgasket to a "why not pull the motor and detail the engine compartment while I'm at it" to a bare metal rotissirie deal on an OT 65 Mustang. got it all back together to a point where I could drive it but no paint, gl***, interior or door guts got layed off and sold it for $4500.00 with $7500 invested in parts.
    we do these things because we are all nucking futs
  27. junkyardjeff
    junkyardjeff
    Legs went numb going to Florida due to not much foam left,springs poking me in the back so its time for some attention. Our suppliers at work have nothing close so it might take some time to get some vinyl that comes close,I dont want to buy covers since it has a factory screw up that I want to retain so I need to get some phone numbers and see if I can get some material.
  28. oj
    oj
    I don't dare to comment on the 'snowball' part, but i like your re-engineered 8track idea! I'd ask for a tech article but i can see it'll take a couple years before you get to doing what you planned to do!
  29. junkyardjeff
    junkyardjeff
    There is a thread on here about making them and that is where I got the idea,its ***led like hidden radios and CDs or something like that.
  30. Because if things didn't snowball they wouldn't be considered projects.
