Projects 1930 Model A Pickup Build (my first build thread)
Discussion in 'The Hokey Ass Message Board' started by Grudge, Jan 4, 2013.
  1. Grudge
    Grudge
    Hey everyone, bought this in 2011 but started working on it seriously last summer.
    Here are my plans:
    -I'm using the original rails but 40-ish rear and 32 front crossmembers. There will be a custom x-member of sorts also.
    -6" rear frame kick up
    -4" channel
    -5" or so chop
    -reversed firewall
    -Flat pickup bed. No fuel tank, battery or other stuff back there.
    -The engine is a 55 265 SBC, trans is 4-speed manual, axle is 66 Bronco
    Before really getting started
    Body off
    Frame kick up
    Pancaked rear crossmember
    Starting on the x-member
    Flipping the bones and caster correction
    More x-member work
    Starting on the channel, height of frame
    Starting to flip the firewall
    More pics to follow
    volvobrynk likes this.
  2. Grudge
    Grudge
    Firewall in, still need to make the transition to the floor
    I'm using an f100 steering box
    Chopping up my nice tank *weeps*
    Starting on the floor
    Shameless use of dimple dies
    Starting on the radiator mount, I'm using a 60s falcon/mustang style
    Shell mount
    Pedals, Tardel style
  3. Perrorojo
    Perrorojo
    Like it. Nice job so far.
  4. Grudge
    Grudge
    Mounted the master cylinder today
    Picked up this heater, does anyone know the manufacturer? It's missing its tag.
    Also picked up a 70s ish driveline and had it shortened and the Ford rear u-joint installed.
    Been working on the firewall to floor transition. For some reason this has been the single biggest pain in the *** on the whole build. I'll post some progress shots later.
  5. porkchop4464
    porkchop4464
    Nice work, moving quickly! I am thinking of flipping my firewall on my Dodge. Is the model A fire wall spot welded all around or bolted? My Dodge is spot welded and bolted in a few spots as well. If yours was as well, how did you locate the spot welds and then get them apart (drill, chisel)?
  6. voodoo1
    voodoo1
    Looking good. I was planning on starting mine ('31) this weekend. I like how you're doing your build. I'm just over the river from you. Mike
  7. Grudge
    Grudge
    It's bolted at the top and spot welded on the sides, sounds similar to your Dodge. If you hit the welded area with a flapper disc the spot welds will show up really well. I cut them out with a spot-weld cutter, like this:
    http://www.amazon.com/Blair-BLR1322...0GTOOC0/ref=pd_sim_auto_1/175-4331747-6032858
    Good luck on your project,
    Aaron
  8. Grudge
    Grudge
    Here's the transition. I have lots of sheet metal work to do. I think it would've been easier if I hadn't flipped the firewall; there's just not a natural transition to the frame now.
  9. Grudge
    Grudge
    Thanks Mike. 31 pickup? If you have questions let me know.
  10. GeoZ1
    GeoZ1
    from Illinois
    Looks great, nice work on the floors.
  11. voodoo1
    voodoo1
    yes '31 pickup.
    I've got a Flathead and a smallblock. So many choices. Pm me. I'd like to come over and see your work.
    Are you using a drop axle?
    Mike
  12. Grudge
    Grudge
    Yep, 4" superbell
  13. 75ford
    75ford
    from burlington
    looks great so far! my say is dont chop it, i love the look of a channel and no chop
  14. Grudge
    Grudge
    Finally made some progress on the firewall/floor transition. Sort of a faceted stealth bomber look, since I'm not too great with sheet metal.
    Pieces
    Many welds later (my frame makes a nice workbench)
    And finally back in position.
    I still have all the inside welding plus grinding, sanding, etc., but it's a huge relief to have a foundation I can work with. For a long time I just sat and stared and thought "what the **** is this going to look like?"
    Today I'll focus on the transmission cover.
    Aaron
    barrnone50 and volvobrynk like this.
  15. HOTRODPRIMER
    HOTRODPRIMER
    Looks like you have made a lot of progress,,I love the old Model A pickups and built a 30 pickup back in the mid 70's. HRP
  16. fleetside66
    fleetside66
    Really nice work, Aaron. I like the stance. When you make your trans cover, you might consider working on your seating & right leg & foot positioning in regard to the transition from the gas pedal to the brake. Perhaps you could experiment with a small cantilevered deck in that area so that you could slide your right foot smoothly from the gas to the brake. Obviously, you're going to have to rest your heel on the trans hump to engage the throttle. It's always nice to have a place to rest your heel for the brake, too, so that your leg isn't hanging in the air. Just something to think about. Keep up the good work.
    oneredryderone likes this.
  17. Grudge
    Grudge
    Good advice, thanks. Judging by your avatar (pickup) you are probably aware of how cramped I will be, especially because of the flipped firewall. The pedal layout, leg position, steering wheel diameter, shifter and parking brake are swimming around in my head right now.
  18. fleetside66
    fleetside66
    Yes, you're right...mine's channeled 5," with a flat firewall & I do have similar room constraints. However, if you're not a real big guy, it's all perfectly doable. It's just good (at the stage you're in) to really start fooling around with the ergonomics. If you find that your right hip area might be interfering with the shifter, you can bend the handle to the shotgun side for more room. I got lucky & found a shifter handle in a junk yard that was already formed that way. Also, you could even lengthen your pedals if need be. I see that they're solid, so that wouldn't be a huge undertaking. But, if you're comfortable with their height, leave 'em be. My wheel diameter is 15," by the way, and I do have a floor mounted dimmer switch the the left of the clutch pedal. Everything works, but, man, it's close. As far as the parking brake goes, that would be on the right side of the hump, so not to worry. After all, the p***enger should be able to feel what a hot rod is really like, too.
    brEad likes this.
  19. 60srailjob
    60srailjob
    from nowhere
    that;s looking great. Nice build.....I like the pick up...cooooooool
  20. choptvan
    choptvan
    I too had my firewall flipped on my 31 pickup. After seeing the amount of legroom, and I am a short guy, I changed it back and cut the firewall and made a tunnel for engine clearance. Just made more sense once I got that far. Love the rad mount idea. And is that a mustang radiator?
  21. Grudge
    Grudge
    Thanks. Exactly, falcon/mustang. With 4" cut out of the grille it BARELY fits, but fits nonetheless. Coolant ports are on the p***enger side so perfect for SBC.
    Aaron
  22. Grudge
    Grudge
    Here's the bed, picked it up from a fellow HAMBer, can't remember his name though, nice guy.
    Also thought I'd show what the firewall looked like before I started. Somebody put in one of those manifold heaters. Whoever did it did a really nice job for a guy who only owns a hatchet and a torch.
    I actually ended up using part of the heater cover plate as a patch panel, so it worked out.
    Somebody has a thread on cab mounts, so here's mine
    Got the mounts from McMaster Carr, they have a durometer similar to a hockey puck, but they are actually designed for higher temps, oil exposure, (and mounting things). Best of all they are cheap and come with a 3/8-16 hole. I'll post a part number later.
    Aaron
    LCGarage and volvobrynk like this.
  23. Grudge
    Grudge
  24. Jersey Joe 67
    Jersey Joe 67
    from J Town
    Love the engine chioce. I've got a 56 265 with tri power sitting around waiting for a future project.
    Very informative thread on the 265 by Jeffrey James you should check out.
  25. farmer12
    farmer12
    Great work so far, love where this going!
  26. 31-5window
    31-5window
    from Michigan
    Looks pretty kool nice work
    Sent from my DROID device using the TJJ mobile app
  27. Noland
    Noland
    looking like a awesome pickup. I like that you not putting a gas tank in the bed. I always think it looks alittle ****py. Frame looks nice. Good luck
  28. choptvan
    choptvan
    Same thing I am doing as well. And you can't beat the cost of $120 for a brand new radiator with a lifetime warranty either...
  29. Grudge
    Grudge
    Hell yeah!
    Quick update, managed to get most of the transmission cover done.
    Turned out ok, still need to grind and smooth it out. Looks a little like a toilet seat. There, I said it, now you don't have to :)
    Aaron
    brEad and volvobrynk like this.
  30. Buddy Palumbo
    Buddy Palumbo
    Nice work , it's lookin' good !
