stewart warner tach
Discussion in 'The Hokey Ass Message Board' started by joe morrison, Jan 5, 2013.
  1. joe morrison
    joe morrison
    from ind
    can anybody tell me anything
    about this tach
    what year it is
    does it take a box to work
    thank u very much for the help :eek:
  2. joe morrison
    joe morrison
    from ind
  3. landseaandair
    landseaandair
    from phoenix
    I think it's referred to as a "pedestal" tach and uses a sender or "ignition monitor" that looks like this.
  4. landseaandair
    landseaandair
    from phoenix
    I think these were late 60s and should not be connected direct. Sender needed.
  5. joe morrison
    joe morrison
    from ind
    ok thank u i will look for a sender
  6. landseaandair
    landseaandair
    from phoenix
  7. joe morrison
    joe morrison
    from ind
    well i think i may just use my other tach that does not need a box
  8. joe morrison
    joe morrison
    from ind
    thank u for the help have a good weekend.
  9. joe morrison
    joe morrison
    from ind
    wow thats pricey
  10. Canuck
    Canuck
    SW 970 series tach. Available in pedistal or dash mount. Vintage mid 60s.
    Requires appropriate sender, depending on your ignition.. Points style, vintage electronic, magneto. Do not try without appropriate sender. Don't know if electronic version would work with modern HEI set-ups.
    Senders show up on E-bay quite often and quite often for less than $100, if you watch for them. Recently picked up a NOS sender for a older and rarer tach for $50.
    Good luck
    Canuck
  11. willys36
    willys36
    Anyone have directions for hooking up this combination?
  12. Tim_with_a_T
    Tim_with_a_T
    At one time, I had a diagram saved on my laptop computer. I can check when I get home to see if I still have it.
  13. landseaandair
    landseaandair
    from phoenix
    I think that's for a transistor ignition, may also have batteries inside. If so, all the 3 wire senders with a silver adjuster plug I've run across didn't as well as the little gold ones that mount directly to the tach.
  14. willys36
    willys36
    Great! Someone somewhere must still remember how these things worked.
  15. Tim_with_a_T
    Tim_with_a_T
    Sorry for the delay. I forgot for a bit what it was I was supposed to do when I got home. Here is what I have. Hope this helps.
    tach_wiring_3.jpg tach_wiring_2.jpg tach_wiring_1.jpg tach_wiring.JPG tach_wiring2.JPG tach_wiring3.JPG
    Elcohaulic likes this.
  16. Tim_with_a_T
    Tim_with_a_T
    I cannot say for certain that all of those pictures go together. They are just pictures I've saved over the years. I know the instructions go together, and the 3 with the black tach go together, but the 4cyl one is an oddball I'm pretty sure.
  17. willys36
    willys36
    I the final ****ysis it doesn't matter. That red box is a battery box and the replacement batteries are long extinct. What a dumb design even in the 60s. They had plenty of 12V power to work with and chose to go with short lived batteries.
  18. USMC RED DOG
    USMC RED DOG
    I know this is late by years but it may help someone that may be looking. This is my first post in the H.A.M.B. I do own this complete setup in new mint never installed condition and I have read where the 970 Series was used in the Yenco Camaros.
