Projects *************
Discussion in 'The Hokey Ass Message Board' started by skidmarks, Jan 4, 2013.
  1. skidmarks
    skidmarks
    from USA
  2. blyndgesser
    blyndgesser
    from Georgia
    Sounds like it would be fun in a lightweight roadster.
  3. gas pumper
    gas pumper
    223/6x4=149.6 c.i.
  4. junkyardjeff
    junkyardjeff
    I remember seeing something about those motors in those small hotrod magazines,I should have it and can find what I done with them I will look it up.
  5. Blue One
    Blue One
    from Alberta
    The economy for running will be there, but power will be lacking as will the fun factor.
  6. 4-port Riley
    4-port Riley
    They used to run the earlier version from the 9N, a flathead, in midgets. It won't have enough torque to make you happy on the street. Tractors get their torque from gearing.
  7. blyndgesser
    blyndgesser
    from Georgia
    It'll have some pretty serious limits, true. It depends on what you put it in and what you do to it. It could be fun, but it won't be fast. Keep it really light.
  8. Rocky
    Rocky
    Classified Editor
    I worked for a place that had one of those powering a big conveyer belt...it was my job to keep it maintained. Always started and ran good and had the early bellhousing with a '39-style ****** attached to it for 3 speeds of the belt.
  9. 48 Chubby
    48 Chubby
    These are tough little engines. Hop up parts are available but hard to find. Check out some of the "tractor Pulling " sites. I helped a feller with one he had in a hot rod tractor used in pulling compe***ions. Cam, mill the head for a little more compression, fab up a pair of manifolds for two Harley-Davidson carbs, and make more power than you would likely get out of a Model A or B banger for less money. A light weight T track roadster should make a good home for it too.
  10. Blue One
    Blue One
    from Alberta
    Light or not, at the lights getting taken out by the old ladies in their Hyundais and Kias would get old :D
  11. Moonequipt13
    Moonequipt13
  12. Worst case you can always put a deck under it and mow the lawn too.
  13. Dan Timberlake
    Dan Timberlake
    that's a pretty big 4.
    inline 4s have significant "secondary vibration."
    Did the previous installations hard mount the low rpm engine?
  14. flathead okie
    flathead okie
    ha :d
  15. Blue One
    Blue One
    from Alberta
    Yes, but the engine is usually what puts the "hot" in Hot Rod. :)
  16. Bruce Lancaster
    Bruce Lancaster
    The small mag...I think this was Car Craft at the time these were release, roughly 1953-4. They did a series on the rodding potential of the new Ford engines, including this four.
  17. Blue One
    Blue One
    from Alberta
    You are quite welcome :) I'm sure you will have some fun with it.
  18. Why would you want to?
  19. elmitcheristo
    elmitcheristo
    What a cool little engine! What kind of distributor does it use? Y-Block?
  20. walls
    walls
    I have a strange fascination with 4 banger stuff the past year. I decided to use a Model A engine in my Model A. Crazy, I know.
    Fast is cool too but, it's nice to see something different every now and again.
  21. 53sled
    53sled
    from KCMO
    t5 swap made my chevy feel much faster, as big and underpowered as a 235 was with the 3 speed. faster shifts, higher speed, more mileage. Sometimes you can have cheap, fast and good.
  22. hugh m
    hugh m
    from ct.
    Been messing with the Iron Duke Pontiac lately, pulls a T just fine, but that little motor is pretty neat as well, hadn't thought of it, but the cubes are virtually the same. Plus, it oughta confuse some people, lots of folks think mine is a model A motor.
  23. JonF
    JonF
    The Ferguson 4-banger was also used in a midget driven by Wayne Weiler and it was compe***ive.
  24. Bruce Lancaster
    Bruce Lancaster
    The Car Craft covering this is June 1954...found it!
    Considerable coverage, some practical, some theoretical.
    (PS...look at other issues near this, as it was part of a series on new Fords and the 6-cyl article might be useful too)
  25. JonF
    JonF
    was OHV
