www cleaner
Discussion in 'The Hokey Ass Message Board' started by 59 brook, Jan 6, 2013.
  1. 59 brook
    59 brook
    any tips for cleaning whitewalls? the best i've found so far is the orange cleaner from the dollar store and a brillo. doesn't cloud the wheels like all the others i've used. i had a ****** line split yesterday and the fluid was all over the wheel. i had to pull the brakes to clean them it was so bad
      283.4 KB
  2. wbrw32
    wbrw32
    Westleys Bleach White,,,from any auto parts store
  3. tiredford
    tiredford
    from Mo.
    Mr. Clean product, Magic Eraser. Buy it in the grocery store.
  4. Model T1
    Model T1
    I've tried many. This seems to be the best I've used for years.
  5. 1941coupe
    1941coupe
    I have diamond backs and they don't recommend any bleaches or brillo, I use simple green and tires are snow white
  6. creepjohnny
    creepjohnny
    Westleys will yellow white walls over time. The guys and i use SOS pads from your local grocery store. They are really inexpensive. I used 1 pad for 2 tires and the steel wool scrubs the grim and dirt off with no effort. Gets em clean and white again!!
  7. h2owell
    h2owell
    Best I have found is Harley-Davidson tire cleaner. Does not effect the rubber except to clean it. Bright shiney white.:D
  8. Moonequipt13
    Moonequipt13
    600 grit sandpaper and water, renews black rubber that has been mildly oxidized too
  9. FIDDLER
    FIDDLER
    from VIRGINIA
    I have goodyears that were not real white when purcahsed. I have used everything known to man including sand paper. These tires will not come clean, infact they have dingied even worse with time, dealer says tough luck. No more goodyears. Not my only trouble with goodyears, but that is another subject
  10. GreenMtnBoy
    GreenMtnBoy
  11. Lone Star Mopar
    Lone Star Mopar
    pee pee and voodoo is the key.
  12. Larjk9
    Larjk9
    Simple Green and a magic eraser.
  13. HOTRODPRIMER
    HOTRODPRIMER
    This is what I use,,works great. HRP
  14. eppster
    eppster
    I've used Westleys Bleach White and a hard brush since 1978 . Before SOS pads.
  15. bb55hrt
    bb55hrt
    from Michigan
    I like to use soft scrub and a stiff scrub brush on mine.
    BB
  16. wbrw32
    wbrw32
    Sorry,I have been using Westleys since its introduction,,,Never any yellow tires...
  17. hombres ruin
    hombres ruin
    Same here I have never had any yellow tires. The only thing with westleys is that the bleach content can cause drying out of the rubber and thus cracking
  18. Dizzie
    Dizzie
    I use Simple Green and a plastic mesh coated pad made to remove bugs. works really well.
  19. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Westleys has been my go to forever, even blackwall tires with white letters.
    Had a 2stroke scooter with WWW tires on it. exhaust blew out onto the one tire all the time, it would be black once a month, shot it down and a bit of scrubbing and back to white every time.
  20. NEWFISHER
    NEWFISHER
    from Oregon
    NW winters with lots of rainy freeway time you have to clean them every other day. I use Westley's, Simple green, Purple power ( diluted), Awesome Cleaner ( dollar store) and SOS pads. It comes down what I have on hand, whats next to the eternaly full wash bucket etc. They all work up here and I have been using Wesleys for 30 years. I have had it yellow WW's once and was either left on too long in the sun too many times ( which doesnt happen much here) or was a bad rubber batch?
  21. 59 brook
    59 brook
    ive triedthe wesleys and it cleaned the tirewell but seemed to mess up the wheel
  22. JasonK
    JasonK
    Wesley's and a used green scotch-brite. Will look like new till you change them out.
  23. jdubbya
    jdubbya
    After cleaning the whitewall, (with whatever you choose to use) coat your whitewalls with a liberal amount of Mop-N-Glo. I tried this method after another HAMB member suggested it, and it works fantastic. The Mop-N-Glo acts as a barrier between the dirt and the whitewall, and dirt will just wipe off with a damp rag, not leaving any streaks. I used to do this a couple times a year, and it sure made clean up a breeze.
  24. So-Cal Speed Sacramento
    Alliance Vendor
    from Sacramento
    mr clean magic eraser. no joke- it works phenomenally well!
  25. Ross Galitzky
    Ross Galitzky
    from canada
    If their really yellow and nobody wants them ,use oven cleaner ,just for a couple of minutes you,ll see the yellow coming out then hit it with repeated hits of soapy water you won,t believe how white the,ll get then cruz by the guy who you got them from grinnin...
