Fan Blade To Radiator Clearance
Discussion in 'The Hokey Ass Message Board' started by 3quarter32, Jan 7, 2013.
  1. 3quarter32
    3quarter32
    Getting ready to weld mounts to frame for radiator. How much fan to radiator clearance should I leave. My thought was if close enough I wouldn't need a shroud. Is that correct? 350 sbc, 6 blade fan, and can center to fan blade.
    Thanks, Lee
  2. verno30
    verno30
    I have ran several cars without a shroud but anyone will tell you, a shroud is way better, specially down south.
    I use to run 1/2 to 3/4" to start and tailor it from there. If you're running a flex fan, make sure there is adequate clearance when at higher RPMs.
  3. OneBad56
    OneBad56
    I have 2 inches clearance between the rad and mechanical fan.
    Also have a shroud and according to the cooling theory, half the blade should be outside the shroud for maximum effectiveness.
  4. tfeverfred
    tfeverfred
  5. I followed the same advice given by OneBad56. Works great. Go with the shroud.
  6. 3quarter32
    3quarter32
    Looks like time to open up the fab shop. Thanks for the replies.
    Lee
  7. 3/4" to 1" depending on your motor mounts
  8. fastrnu
    fastrnu
    from shelton,wa
    How many times have you had to fight a little 7/16 belt between the radiator and the fan blades. I set mine around 3/4" like Fred said. If the fan holds a dollar bill to the other side you know its pulling well. My question would be is this fenderd or open?How much area of the radiator is the fan covering really helps determine if you need a shroud.
  9. I have about a 1/2" on the wagon. HRP
  10. Make sure you leave enough room so you can unbolt the fan to change the water pump without taking out the radiator if ya gotta.
    -Pat
  11. HellsHotRods
    HellsHotRods
    I have 3/8"....I have seen 1/4" clearance before.
  12. 3quarter32
    3quarter32
    The fan is according to my figures is drawing 70 percent of the area. Fan area = 227 sq.in. and the radiator 320 sq. in.
    Lee
  13. On most of our cars it's 300x easier to take the rad out.
    I have about a inch.its tight but fits.I run a shroud and it still gets hot
  14. Toast
    Toast
    from Jenks, OK
    Use a shroud if you can, it gets too hot here in the summer as you know!:eek:
  15. Don's Hot Rods
    Don's Hot Rods
    from florida
    Air will take the least path of resistance, so without a shroud instead of air being sucked through the radiator it will be pulled in from the sides. Some cars get away without a shroud but if you can put one on it will be a lot more efficient, especially in August.:eek::D
    Don
  16. Muttley
    Muttley
    No kidding, I'd rather spend the extra time to remove the radiator and gain the extra room than have to repair/replace it after you punch a hole in it.
  17. Deuces
    Deuces
    Bingo!....;)
  18. Deuces
    Deuces
    ......And DON'T use a cheap ass flex fan.......
    Fucking things are dangerous!!!..:mad:
  19. skidro69
    skidro69
    from Dothan, AL
    You need enuff room for a wrench and also enuff to remove the threads from the water pump flange, bolts should be as short as posible and maintain proper thread protusion through the flange, 3-5 threads past the back side of the flange. Also you have to consider removing the fan, spacer, and bolts as an assembly, from the pilot shaft on the water pump. So...3/4" the lenth on the pilot shaft plus 1/4" for the bolt heads= 1". that my .02 worth.
