Projects 1956 F100 Build Thread
Discussion in 'The Hokey Ass Message Board' started by tlmartin84, Mar 24, 2012.
  1. tlmartin84
    tlmartin84
    from WV
  2. 53mercury
    53mercury
    Nice rack! That didn't come out quite right.:D Did you pressure test after you tig'ed it up? Hadn't seen that done before, but seems pretty straight forward as long as everything is setup in a jig for welding. Nice job. Mike
  3. Oldskooloval
    Oldskooloval
  4. tlmartin84
    tlmartin84
    from WV
    There is no fluid where it was tig'd... no need for pressure testing.
  5. 53mercury
    53mercury
    Even better. Thanks, Mike
  6. dirtbag13
    dirtbag13
  7. FoMoCoPower
    FoMoCoPower
  8. Clean build. Nice work so far
  9. PRENDI P.
    PRENDI P.
    Hi.. Do you think this set up will work in a 59 f100??
  10. tlmartin84
    tlmartin84
    from WV
    Sure will if you don't mind high offset wheels. You won't have to narrow it.
  11. willymitch
    willymitch
    from Minnesota
  12. tlmartin84
    tlmartin84
    from WV
    Yeah mine has been slow too. HOWEVER I have a ton of parts and all of my spring chores are done. Tommorrow I mount the new front bearings and start brake plumbing. My mounts for the engine are on the way so stay tuned I gotta lot of cool stuff coming.
  13. tlmartin84
    tlmartin84
    from WV
    As promised more pics.
    Battery drop down brackets, engine mounts, supercharger and throttle body mounts/adapters, and clutch pedal arms.
    Front Suspension Finished. Everything is like new, bearings, ends etc.
    [​IMG][/IMG]
    Ford blue brake rotors.......I know everyones are red....I happen to bleed ford blue though.
    Starting brake lines tommorrow.
  14. tlmartin84
    tlmartin84
    from WV
    Got the braided lines on today as well as the thru frame bolts.
  15. tlmartin84
    tlmartin84
    from WV
    Motor Mounts welded up........thanks to my buddy Ron for the Plasma Table!
    Ford 300 and T5 paired up.
    In the frame....
    Hopefully I can get the transmission crossmember in tommorrow. One issue I have ran into is that with the motor and transmission setting level the driveshaft is going to run right through the mid crossmember, I guess I will have to put a hoop in to make it work.
    The length of this motor and transmission are turning out to be quite a challenge.
  16. tlmartin84
    tlmartin84
    from WV
    Here is the transmission crossmember...........
  17. willymakeit
    willymakeit
    I've followed this build since it started. Nice work. Keep us posted.
    Building a 56 myself.
  18. 4rod
    4rod
    rad on the welds and great build...I love building old ford trucks...had a 54 that was a shame to sell...
  19. tlmartin84
    tlmartin84
    from WV
    Thanks Fellas!
    I got my steel lines ran this weekend......still debating on painting them or not.
    This little tool was AWESOME! absolutely the best flare tool I have used. Bought it from across the pond in the UK $45.00 shipped here. The bender was $20.00, when I got it, it was buy one get one free (I didn't know until I opened the box and it happened to be a special, SCORE). So dad got one too.
    I ended up using regular steel tubing and the typical rubber coated steel brake clips. I used 1/4" stainless screws with nuts for it all. I was going to tap the frame but I wanted a nice smooth outer rail so thats where I left the screw heads.
  20. willymakeit
    willymakeit
    Keep posting. Gives me ideas for another.
  21. Stormin' Norman1
    Stormin' Norman1
    Nice build. Like the frame color.
  22. oldskewl
    oldskewl
    Always loved that body F100. Very interested in the thread.
  23. tlmartin84
    tlmartin84
    from WV
    Well after some work I have the rear end blasted painted and ***embled.
    Before:
    During:
    Welded up the perches, and axle tubes to the housing, taped it off for blasting and painting.
    After painting and ***embly. It got 3 coats of KBS which blistered because I painted them on a hot humid day so It has a couple coats of enamel over it after resanding. I polished the cover using a kit from harbor freight, worked like a charm.
  24. tlmartin84
    tlmartin84
    from WV
    Swiss Cheese Repair.....
    New hinge buckets, these things are a PITA. I had to undo the bucket and reweld it to the pillar to get them aligned properly.
    New brace and firewall patch.
  25. lowtrkn2k
    lowtrkn2k
    Very nice job!!!
  26. tlmartin84
    tlmartin84
    from WV
    Here was the P/O attempt at a chop.... it has complicated my efforts of getting everything lined up. I'll get it there.....
    Salvaged the top of my original doors and swiped the skins off of the to replace the chopped cabs:
    Checked header clearance, looks like I am gonna have to modify these but they do look WICKED in place.
    Removed the left corner and started working on patching it and the door:
  27. CharlieLed
    CharlieLed
    Wow, you ARE ambitious! Too bad you don't live closer I have a cab in storage that is in a lot better shape than that one. The worst part about a chopped 56 cab is finding a windshield to fit, better do your homework before investing too much time here.
  28. tlmartin84
    tlmartin84
    from WV
    Got my super charger intake cut this week!
  29. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    this thing is nice! i might go and section this crossmember for my fairlane instead of running a mii
