Putting mag wheels on a '59 Buick
Discussion in 'The Hokey Ass Message Board' started by Chuck Carman, Jan 8, 2013.
  1. Chuck Carman
    Chuck Carman
    I'm having trouble finding anything about this in the tech archives. I want to put aluminum slots on my '59 Buick, but the car has lug bolts. I'm curious as to how to do it without converting it to an open driveshaft and front discs, which I plan for the future but not right now. Thanx.
  2. 40FordGuy
    40FordGuy
    Have you checked with any of the wheel mfgr, or dealers ? They may have just what you need.......
    4TTRUK
  3. Tim
    Tim
    from KCMO
    i'm not sure I grasp your issue.
    I ***ume that you have bolts that come all the way out instead of having a nut spin off the stud but that seems like then you just need a wheel that's the correct bolt pattern and not super thick so you can re use your existing lug bolts?
    what am i missing?
  4. Model A Gomez
    Model A Gomez
    A friend of mine bought allthread allen bolts about 2" long and lock***ed the lug nuts to them and used them as bolts.
  5. HOTRODPRIMER
    HOTRODPRIMER
  6. 38Chevy454
    38Chevy454
    I know exactly what you are talking about. There is no wheel stud. The hub is threaded and the lug "nut" is really a lug "bolt". You might be able to put threaded studs in the lug holes. Then use a std alum wheel lug nut on the stud. How to keep the stud tight in the hub?? Maybe you could deform the threads slightly at the point the stud is tight in the hub to be a mechanical locking? The stud will be tight once the lug nut is in place, it becomes in tension once everything is tight. Someone like ARP may make a short stud that could work, originally for some head stud or main stud application, but if it has the right threads and length it should be good?
  7. Chuck Carman
    Chuck Carman
    Thanx guys, some great suggestions. I'll check them out and post some results.
  8. Chuck Carman
    Chuck Carman
    Tim, the problem is that the aluminum slots I have take deep shank "mag" lug nuts, so even if the originals were long enough they won't be thick enough.
  9. Deuce Roadster
    Deuce Roadster
    Buy a set of these ...
    They thread into the hub/drum ... and have a allen set in the end to install them. I usually LOC***E red them.
    Once installed ... regular lug nuts will work.
  10. landseaandair
    landseaandair
    from phoenix
    One issue that comes to mind is whether there are left hand threads on one side.
  11. Hnstray
    Hnstray
    from Quincy, IL
    I have converted several MOPARS with the same issue (lug bolt vs studs). I use a suitable lug stud, selected from the huge ***ortment available in the Dorman Products catalog, and press them into the holes in the hub. In your case, the rear has axle flanges, but same deal.
    The key is selecting a lug stud from the catalog that has a suitable serrated shank length and diameter, and a threaded length that is also correct for your purposes. Not as complicated as it sounds.
    Ray
  12. It's obviously been done............
  13. landseaandair
    landseaandair
    from phoenix
    Not sure but I think the front hubs on the '59s have blind holes and machining would be required. The threaded rod idea is much easier and could even be lock***ed in the mag lugs themselves. Left hand threads if needed http://www.mcmaster.com/#standard-left-hand-threaded-rods/=ky8qmi
  14. raidmagic
    raidmagic
    That's ***uming that car wasn't swapped from stock running gear which I doubt
  15. sololobo
    sololobo
    Steel wheels are your friend. Damn I wish I could like those race car wheels on street cars. Set in my ways. Love 59 Buicks however! ~sololobo~
  16. Chuck Carman
    Chuck Carman
    DeuceRoadster, where do you get them? landseaandair, they are all right hand thread, and Waddayacare, thanx for the ****. Hnstray, thanx, I'll check them out.
